Old 03-10-2014, 10:18 PM   #501
Year: 87
Chassis: International s1700
Engine: 6.9 internatiional
Re: 87 Wayne Lifeguard international S1700 CXXVI
Originally Posted by Accordion
Excellent idea to paint the cabinets.
Thanks Accordion, i just wish i had made them a Little smoother,but they aren't too bad in person. I'm wondering if i should pant the bottom side of the cabinet underneath as well, and if i should use the blue or a white for that.
proconsul100 is offline   Reply With Quote
Old 03-16-2014, 07:30 PM   #502
Year: 87
worked on painting the lower cabinets today. they turned out good, but the flash doesn't do them justice.
couple more coats to go:
new brass knobs:
Old 03-20-2014, 07:04 PM   #503
Shadoll's Avatar
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
I like the idea of using the metal 90 degree strip as the attachment for upper cabinets to the ceiling. hmmm.
Linda Kay
trans·mog·ri·fy Verb: Transform, esp. in a surprising or magical manner.
Shadoll is offline   Reply With Quote
Old 03-20-2014, 08:45 PM   #504
Year: 87
thanks, its pretty strong as well,
Old 03-29-2014, 11:02 PM   #505
Year: 87
i cut the wall for the end of the kitchen, which will also be part of the cabinet for the fridge, microwave and power converter area:
ill post more tomorrow when the cabinet comes together
Old 03-30-2014, 06:38 PM   #506
Year: 87
i did more work on the cabinet. the plywood was bowed so i made things more difficult on myself. the one next to the cabinets wasn't a problem as the cabinets straightened out the bow one it was screwed down, but the stand alone one on the other side was a pain i should have used studs, i would have lost some space but it would be easier. i cant wait to get the fridge and microwave and converter in there.
Old 04-06-2014, 10:55 PM   #507
Year: 87
i completed the first shelf that will hold the fridge. it is strong as hell, i think i overdid it. I'm using the chair rail as part of the support. i can stand in it and jump up and down and it doesn't even creak. once i line it up. cut the vent holes. bolt it down i can add the shelves in for the microwave and power converter, then the plywood front.
i also took a meter to my power converter and figured it out. all DC and AC works. however one of the romex wires remained energized as it was bypassing the breakers. im not sure why they did that. i began removing the romex and replacing it with 20 Amp computer power cable wire, im looking for 30A wire to replace the power input romex with.
i tested it by temporarily hooking up to 15A
1st computer power cable:
Old 04-09-2014, 02:08 AM   #508
Year: 87
thanks Guys,
Im making progress, but not as fast as i would like. i try to post on here as often as i can for everyone to see, and for me to examine the photos and figure out what i need to do next. wkmbailey, i cant wait to see your cabinets
Old 04-09-2014, 11:27 PM   #509
Year: 87
i built a 30A power cable tonight out of 2 used pieces. i had a 30A cable and plug, and i also had a Marinco weather tight connector with a cut cable piece inside it. the hardest part was removing the yellow rubber boot to get access to the connector. i ordered a new Marinco input socket that this connector fits into to be installed in the side of the bus
Old 04-10-2014, 10:33 PM   #510
Year: 87
i finished up the AC wiring to the Converter. the yellow wire is 10AWG 30A AC wiring.the wires going out are 20A computer power cord wires, 12AWG. now i need to clean up the DC fuse box and wiring install the converter box and outlets for it and it should be good to go.
1984 International s1700 Fully Converted britnich84 Classifieds | Buy, Sell, Swap 6 12-08-2013 01:05 AM
service manual for 1987 Wayne Lifeguard proconsul100 Conversion General Discussions 2 07-10-2012 11:58 AM
CXXVI 87 Wayne lifestar International s1700 6.9 proconsul100 Skoolie Conversion Projects 1 07-10-2012 09:45 AM
1982 International "War-Hog" S1700 Sojakai Short-Bus Conversion Projects 22 05-28-2010 12:19 PM
International S1700 6.9 Diesel Info Needed Please woodyking Conversion Tutorials and How-to's 7 03-31-2008 02:31 PM
