Old 06-01-2014, 10:19 PM   #521
Year: 87
Chassis: International s1700
Engine: 6.9 internatiional
Re: 87 Wayne Lifeguard international S1700 CXXVI
i added the next shelf to my cabinet,and began installing the power converter:
proconsul100 is offline   Reply With Quote
Old 06-08-2014, 09:37 PM   #522
Year: 87
i installed my Marinco power connector in the bus today. i attached some 30A cable to it ran it under the bus, attached it to the floor ribs with metal strapping, and cut a hole in the floor under the cabinet and ran it up to the power area of my cabinet where the converter is installed. I sealed the hole with spray foam. i figure i can always drill though the foam is i need to run other wires through that hole. now i need to finish attaching. the twist connector at the other end in the cabinet
hole in bus floor other side of bus:
Old 06-15-2014, 08:57 PM   #523
Year: 87
i did some more work on the power system in the bus i hooked up the power converter installed some outlets so that i can plug and unplug between the converter and inverter once it is installed, and i installed a power strip to provide outlets for the kitchen area and inside the cabinet if needed. i also installed a duplex outlet in the refrigerator access area.
fridge outlet:
Old 06-21-2014, 11:42 PM   #524
Year: 87
i added the next shelf for the RV microwave. and positioned it in there. tomorrow i will install the face for the entire cabinet, and possibly the door for the power cabinet. i also installed an old dome light in the power cabinet which will run off either the battery or the converter same as the range fan and light.
Old 06-22-2014, 10:38 PM   #525
Year: 87
so today i ended up installing a light switch and the 2 RV lights i purchased a while back in the kitchen. they are 12V DC fixtures, but i ran them through a regular 12V AC switch as they are low wattage it should work ok for a while. i plan on replacing the bulbs with LED versions in the future in order to decrease the amount of power going through the switch and coming out from the battery or the converter as this is set up to use either.
Old 06-29-2014, 06:43 PM   #526
Year: 87
I did some more work on the cabinet today. i used some LDPE packing foam to brace the microwave inside its cabinet, and added a piece of wood at the back so it wont slide backward. i cut a front for the microwave out of plywood and built a cabinet door for the power cabinet and started painting. i still need to make a lower front piece for the Fridge.
Old 07-01-2014, 09:05 PM   #527
Year: 87
the paint is dry. the flash on the camera is unhelpful. now i need to work on the bottom cover.
Old 07-02-2014, 10:35 AM   #528
LandLubber's Avatar
Chassis: All American RE
nice work.
Roll Tide
LandLubber is offline   Reply With Quote
Old 07-04-2014, 11:00 PM   #529
Year: 87
i finished up the lower cabinet face yesterday and painted it :
Old 07-05-2014, 08:46 AM   #530
looking good, I like seeing progress on skoolies it gives people incentive to work on there projects
your microwave and fridge install looks great.
keep up the good work
1984 International s1700 Fully Converted britnich84 Classifieds | Buy, Sell, Swap 6 12-08-2013 01:05 AM
service manual for 1987 Wayne Lifeguard proconsul100 Conversion General Discussions 2 07-10-2012 11:58 AM
CXXVI 87 Wayne lifestar International s1700 6.9 proconsul100 Skoolie Conversion Projects 1 07-10-2012 09:45 AM
1982 International "War-Hog" S1700 Sojakai Short-Bus Conversion Projects 22 05-28-2010 12:19 PM
International S1700 6.9 Diesel Info Needed Please woodyking Conversion Tutorials and How-to's 7 03-31-2008 02:31 PM
