Old 09-11-2014, 11:42 PM   #571
Docsgsxr's Avatar
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
Re: 87 Wayne Lifeguard international S1700 CXXVI
Originally Posted by cschlessman
Off grid we use fans to blow air in low and out high and exit. This way the fan is outside the box. A brushless dc fan is most desirable.
Chuck
Excellent idea. And to boot one could run a ridgid duct and put the fan further away from the box to be sure.
My build thread - viewtopic.php?f=9&t=467197
Old 09-12-2014, 02:38 AM   #572
Year: 87
Chassis: International s1700
Engine: 6.9 internatiional
Chuck
this is a good idea. i have lots of computer server fans. ill look into this as well.
proconsul100 is offline   Reply With Quote
Old 09-14-2014, 07:13 PM   #573
Year: 87
i secured the deep cycle batteries using angle iron, wood, threaded rod, wing nuts, and springs and wire from an old bed frame. here are the results:
[img]http://i1063.photobucket.com/albums/t506/
proconsul100/20140913_165734_zps1a791500.jpg[/img]
Old 09-14-2014, 07:18 PM   #574
browncrown's Avatar
Rated Cap: 79 at Birth
Look like you're good to Power Up
BC
Old 09-14-2014, 10:36 PM   #575
Docsgsxr's Avatar
Excellent work with the recycled materials! What gauge wire did you use to connect your batteries? Are they 12v or 6v? Series or parallel?
-Doc
Old 09-15-2014, 01:18 AM   #576
Year: 87
-Doc
Hi Doc,
they are 4 6V batteries connected in both series and parallel to get 12V. they are interconnected with AWG #4 welding cable i will connect to the marine switch and inverter with AWG #2 once i get it made. this is kind of helpful:
http://www.atbatt.com/rv-battery/how-to ... figuration
Old 09-15-2014, 09:33 AM   #577
Docsgsxr's Avatar
Awesomely simple! I love it and thanks!
So why #4 on the cells and #2 to the inverter? Does the smaller size on the batteries impede current at all? I guess with that size it really wouldn't matter huh?
Old 09-15-2014, 08:34 PM   #578
Year: 87
it shouldn't, the interconnect cables can be a smaller gauge since they are bridging 6V batteries together, and they are a short distance. since there is a lot more power coming out of the bank itself at 12v, i wish to increase the size of the cable. depending on how far away i place the inverter i may go to AWG#1 to compensate for distance.
Old 09-15-2014, 09:22 PM   #579
Docsgsxr's Avatar
Gotcha. I was reading the manual for my inverter and it said to make room for air movement since it will also put out some heat as it operates. So make sure it is vented a bit as well! Have you decieded on how you will charge them when sitting? Are you going to hook them into your alternator with a solenoid for run time charging?
Old 09-15-2014, 11:29 PM   #580
Year: 87
both my coach and house batteries will be ale to be charged by either the alternator, the ac converter battery charging circut, my 2 solar panels, or the generator once it is hooked up. ill be able to decide which one gets the charge by using one of these switches:
http://www.civicsolar.com/product/blue- ... ery-switch
already my solar panels can produce over 10A on a good sunny day, and most of the time they act as a trickle charger around 3 to 5A. right now everything is running from the coach batteries, now that i have the battery bank i can add in the switch, separate everything and start working on installing the generator.
1984 International s1700 Fully Converted britnich84 Classifieds | Buy, Sell, Swap 6 12-08-2013 01:05 AM
service manual for 1987 Wayne Lifeguard proconsul100 Conversion General Discussions 2 07-10-2012 11:58 AM
CXXVI 87 Wayne lifestar International s1700 6.9 proconsul100 Skoolie Conversion Projects 1 07-10-2012 09:45 AM
1982 International "War-Hog" S1700 Sojakai Short-Bus Conversion Projects 22 05-28-2010 12:19 PM
International S1700 6.9 Diesel Info Needed Please woodyking Conversion Tutorials and How-to's 7 03-31-2008 02:31 PM
