Old 09-16-2014, 06:44 PM   #581
Year: 1975
Chassis: Internatinal Harvester
Engine: IHC SV345, gasoline
Re: 87 Wayne Lifeguard international S1700 CXXVI
Hey Pro... we're off-grid and going mobile in the next couple of weeks. I stumbled across the thread looking for ideas on how to rig my deep-cycle batteries in our just-purchased 1975 International 1803. Gotta say, buddy, 'NICE WORK!' So many great ideas for a lot of the stuff that's been keeping me up at night (screens, etc).
Hope you don't mind, but I've bookmarked the thread and will be returning, often, to steal as many of your ideas as I can
Great stuff.
'75 Loadstar 1803
farmerjohn is offline   Reply With Quote
Old 09-16-2014, 07:59 PM   #582
Docsgsxr's Avatar
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
Porkchopsandwhiches I think used that same switch
Guess thats what I'll be going with too! (Although I really did want an inexpensive automatic transfer switch. I hate fumbling around looking for it in the dark!)
Did you upgrade to a heavier alternator? I am curious if you charge too many with the stock one, if it will shorten the life on it?
My build thread - viewtopic.php?f=9&t=467197
Old 09-17-2014, 09:47 AM   #583
Year: 87
Chassis: International s1700
Engine: 6.9 internatiional
Hi Doc,
the alternator on the bus is pretty large and large amps. i have a photo of the id plate around here, ill post it for you. when you think about it it needs to be heavy duty to run all the emergency features of a school bus all day long. its also possible the the school district upgrades to the larger alternator as well. im not worried about wearing it out
proconsul100 is offline   Reply With Quote
Old 10-12-2014, 06:50 PM   #584
Year: 87
not too much going on lately. i have installed a 12V DC breaker and modified an electrical box to mount the Marine battery switch. the photo of the 12v circut breaker is terrible, ill replace the photo asap.
Old 10-19-2014, 09:30 PM   #585
Year: 87
i cut the hole in the floor for the cable leading from the battery switch, then ran the cable on the under side of the bus screwing it to the steel ribs with plastic supports. i then ran it into the cabinet containing the inverter and attached it. after turning on the house battery bank power with the battery switch, i tested the connections and inverter by plugging in the cord from the shore power outlet to the front ac outlet that runs the TV. the TV runs fine on the inverter.
here you can see the cable next to the 30A ac cable from the shore outlet:
Old 03-23-2015, 01:37 AM   #586
Year: 87
I installed an RV door today
Hi everyone, i have been away for a few months but now im back. I purchased an RV door a propane tank door and enclosure. today i installed the RV door. i still need to paint the door the wooden frame and also cut some wood for the top of the door. here are some photos.
Old 03-28-2015, 10:13 PM   #587
Year: 87
painting new door
i began painting the new door, and i bought a used Bargman L300 door handle with a key. i also installed a 2 cylinder deadbolt.
1st coat:
2nd coat:
used handle with key:
Old 03-29-2015, 08:11 AM   #588
REDD's Avatar
Coachwork: Thomsass
Chassis: FreightShaker
Engine: 5.9 Cummins 5 speed
Rated Cap: 8 Assengers 2 ATV's
Sweet! I'd like to put a one piece door in as well, how do you find driving with window behind the door covered as well as the missing glass at the bottom of the new door?
Old 03-29-2015, 11:21 AM   #589
Year: 87
I'm not sure yet as as i haven't been able to drive it with the new door, but the but when sitting in the drivers seat I'm able to see quite a but through the large tinted window in the RV door. I wont be able to see as well as with the folding door, but i should be able to see good enough.
Old 03-29-2015, 06:27 PM   #590
Year: 87
door install finished(except inside trim)
I finished installing the RV door and hardware today. i incorporated the upper rubber piece, everything is painted and caulked.
1984 International s1700 Fully Converted britnich84 Classifieds | Buy, Sell, Swap 6 12-08-2013 01:05 AM
service manual for 1987 Wayne Lifeguard proconsul100 Conversion General Discussions 2 07-10-2012 11:58 AM
CXXVI 87 Wayne lifestar International s1700 6.9 proconsul100 Skoolie Conversion Projects 1 07-10-2012 09:45 AM
1982 International "War-Hog" S1700 Sojakai Short-Bus Conversion Projects 22 05-28-2010 12:19 PM
International S1700 6.9 Diesel Info Needed Please woodyking Conversion Tutorials and How-to's 7 03-31-2008 02:31 PM
