Old 07-28-2012, 11:30 PM   #61
Year: 87
Chassis: International s1700
Engine: 6.9 internatiional
Re: 87 Wayne Lifeguard international S1700 CXXVI
i wonder if something like this might be made to work for grey or black tank. ive seen some a little smaller for 50 each:
http://seattle.craigslist.org/tac/grd/3155126081.html
http://seattle.craigslist.org/sno/grd/3162951172.html
http://seattle.craigslist.org/oly/grd/3169191581.html
proconsul100 is offline   Reply With Quote
Old 07-29-2012, 01:39 AM   #62
crazycal's Avatar
Those tanks are 4 feet tall. No way you have enough clearance. Try a 55 gallon poly drum on it's side. Those are strong as hell and cheap, like free or $5-10.
I'm hungry!
You Gotta Let Me Fly
Old 07-29-2012, 10:11 AM   #63
Year: 87
thanks, you are right, there are a couple people locally that have plastic 55 gallon drums. i wonder if they make fittings that screw into the existing bungs?
Old 07-29-2012, 10:53 AM   #64
they are being sold because they are using the new plastic tanks that have a plastic enclosure for support..
i have some of the tanks as pictured also, but am not using them.
they could be made into grey or whatever tanks, but they would have to be cut down, and a new top made.
for hauling stuff in a trailer, if you remove the plastic tank, they make really good boxes by using the metal exterior as the box.
besides the 55 gal food grade barrels, they also make 30 gal ones that are used for stuff like syrup at the pepsi bottleing plant close to here.
Old 07-29-2012, 11:09 AM   #65
crazycal's Avatar
One of the holes is coarse thread and the other is fine. PVC threaded fittings work on the coarse I think. It's been so long I don't remember.
I'm hungry!
Old 07-29-2012, 06:29 PM   #66
i think the large holes are 2 inch and the small ones 3/4 if i remember right..fwiw
Old 07-29-2012, 07:25 PM   #67
crazycal's Avatar
I think that's correct but the 2" have different threads. Not sure why. Probably means getting one fitting at Home Depot and the other from a specialty supplier.
I'm hungry!
Old 07-29-2012, 08:27 PM   #68
Year: 87
thanks guys, i will pick up a few of these barrels. one for fresh, one for Grey and one for black. i imagine i will have to cut extra holes for the black tank and glue the fittings in. for that.
Old 07-30-2012, 09:27 PM   #69
Year: 87
i cut some computer chassis side covers to seal up the flasher holes. i only did the rear as i ran out of side covers
i also cut a notch in the counter i bought to fit the chair rail. i need to figure out some kind of bracket to screw into the rail to hold the counter in place
no more gap!!
Old 07-31-2012, 09:45 AM   #70
browncrown's Avatar
Rated Cap: 79 at Birth
Light covers turned out good, and the counter installation fits really well. Good job
BC
1984 International s1700 Fully Converted britnich84 Classifieds | Buy, Sell, Swap 6 12-08-2013 01:05 AM
service manual for 1987 Wayne Lifeguard proconsul100 Conversion General Discussions 2 07-10-2012 11:58 AM
CXXVI 87 Wayne lifestar International s1700 6.9 proconsul100 Skoolie Conversion Projects 1 07-10-2012 09:45 AM
1982 International "War-Hog" S1700 Sojakai Short-Bus Conversion Projects 22 05-28-2010 12:19 PM
International S1700 6.9 Diesel Info Needed Please woodyking Conversion Tutorials and How-to's 7 03-31-2008 02:31 PM
