09-13-2012, 09:22 AM
#161
Engine: DT466/AT545
Re: 87 Wayne Lifeguard international S1700 CXXVI
Is that green vehicle a mail jeep? I used to have one that was painted purple. I bought it from a friend's mom who was a mail carrier. What a great little vehicle! Only downside was having the steering wheel on the right side rather than left. But it sure was fun to drive!
09-13-2012, 09:46 AM
#162
Year: 87
Chassis: International s1700
Engine: 6.9 internatiional
Originally Posted by chev49
you need to post whether you want the chair to be moveable or not... if not, simple half round pipe clamps from electric store or maybe lowes will work...
Thanks,
i dont need it movable, but i was wondering how the RV manufacturers bolt them down. i like the pipe clamp idea.
09-13-2012, 09:48 AM
#163
Year: 87
Yes, that is my Postal jeep, great vehicle, i brought it back to life, i found it stuck in a barn.
09-13-2012, 11:05 AM
#164
Thanks,
On my last motorhome they where bolted thru the floor. Any chair that could be used during transit required seatbelts and bolted thru the floor....... Even the sofa was bolted thru the floor.
You want it secured so it will stay in place in case of accident.......
Just food for thought
GreyEagle
Roll - On...
09-13-2012, 12:03 PM
#165
Rated Cap: 79 at Birth
On the blue swivel rocker I have, I drilled out the four rivets holding the stand to the swivel plate, and then bolted it up through the floor. I agree that it needs to be very secure if you're going to use it in transit.
09-13-2012, 04:42 PM
#166
They have to be put in a barn for several years every time they go postal....
09-13-2012, 10:03 PM
#167
Year: 87
i agree, eventually i would like to get the bus to the point where i can tow the Postal Jeep behind it.
09-13-2012, 10:07 PM
#168
Year: 87
so i guess i will bolt the chair to the floor, then rig up some kind of seat belt for it, and find a way to lock the swivel/glide action.
09-15-2012, 11:47 PM
#169
Year: 87
09-16-2012, 08:19 PM
#170
Year: 87
09-18-2012, 09:33 AM
#171
Year: 87
now i just need to find and mount an RV door, the ability to seal is pretty poor on the folding door.
09-18-2012, 10:45 AM
#172
Engine: DT466/AT545
I've been considering this also. I don't mind the standard bus doors so much really except that they squeak loudly when opening and then also I have to slam them closed from the outside, which is loud if people are sleeping inside. I may decide to just modify the standard bus door as others have, so it opens and shuts like a regular door rather than a bi-fold.
09-18-2012, 10:52 AM
#173
You might keep an eye out for a door that includes a "curb viewer" down low or add one to whatever you find. Makes a big difference when parking or pulling up next to things...like fuel pumps and such. I just bought a narrow boat window to add to mine. It will fit vertically.
09-18-2012, 10:33 PM
#174
Year: 87
i thought about doing this too, but the bus door has a gap between the edge and the bus frame that if bridged by rubber. i think it would be hard to lock unless you added metal to the frame, and if im gong to do that i might as well get a scrap RV door.
09-18-2012, 10:35 PM
#175
Year: 87
thanks for the idea, i like the boat window
09-23-2012, 01:26 AM
#176
Year: 87
i started carpeting the bus walls today. here is some progress.
i also bought a restaurant table top for $20. i need to mount it to the wall and floor
09-23-2012, 04:34 AM
#177
I really like that table, the carpet should help with the sound deadening
09-23-2012, 11:42 AM
#178
Your new entry looks very nice
09-23-2012, 06:22 PM
#179
Year: 87
i removed the remaining rubber tread, cleaned the area and glued down form carpet tile with vinyl adhesive:
09-29-2012, 11:08 PM
#180
Year: 87
