Old 09-17-2013, 11:58 AM   #421
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Re: 87 Wayne Lifeguard international S1700 CXXVI
Originally Posted by wmkbailey
What does this have to do with placing batteries on the ground to watch them discharge, oh sorry we hijacked your thread.
Exactly why I bowed out of that particular soon-to-be-argument, but some insist on making it a federal case...
What I can vouch for is the fact that when I worked at AutoZone, we had a special on DuraLast top-post batteries of a certain size group. They were stacked on the concrete floor as a display. EVERY SINGLE ONE of the batteries on the bottom row (that sat on the CONCRETE) had problems. None of the others did. Can anyone EXPLAIN that? Call it what you want. Agree to disagree. Back to the OP's build... What's new?
The batteries must have been laid out in an east west direction. That will definitely do that. If you want the batteries topped off, they must be in a north sound direction. Sorry, had to put in my 1 1/2 cents.
Bus is looking great by the way.
I'm hungry!
You Gotta Let Me Fly
Old 09-18-2013, 09:55 AM   #422
Year: 87
Chassis: International s1700
Engine: 6.9 internatiional
Thanks Cal, my progress is slow, but i try to finish at least 1 item a week.
proconsul100 is offline   Reply With Quote
Old 09-21-2013, 08:05 AM   #423
Originally Posted by proconsul100
Originally Posted by bansil
nice,what model is it?
they say it is RV/Marine, but neither the box, instructions, nor anyone on line mentions using it on an RV. Lots of people using them on their boats.
we do have land yachts'
Thanks
Old 10-05-2013, 10:48 PM   #424
Shadoll's Avatar
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
Cute. Gives it a bit of alien mystery. Looks like it works good.
Actually, the front of the bus looks like a dogs face with nose and ears and with a top knot on his head.
Linda Kay
trans·mog·ri·fy Verb: Transform, esp. in a surprising or magical manner.
Shadoll is offline   Reply With Quote
Old 10-05-2013, 10:56 PM   #425
Year: 87
i had a mishap today. was cutting down large branches in order to move the bus forward a couple of feet so i can finish installing the awning. when i got down from the roof i noticed this:
one of the large branches must have bounced up and broke one of the windshield panes. i wonder if anyone knows where i can go for bus windshield glass.
Old 10-06-2013, 05:18 AM   #426
Traveling
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
Old 10-06-2013, 02:38 PM   #427
Shadoll's Avatar
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
I had a small crack in mine and the weather has made it travel all over the place so I will have to replace mine eventually as well.
Linda Kay
Old 10-06-2013, 11:11 PM   #428
Year: 87
i got the other leg of the awing installed and installed the awing on top. i have come to the conclusion that i need a second person. usually i can figure out a way to do a 2 person job by myself it just takes twice as long, but i need help supporting the awning so i can feed the fabric into the c channel that holds it to the bus as it is too damn heavy and awkward. so far it looks ok.
Old 10-21-2013, 10:17 PM   #429
Year: 87
i finished routing the coax cable and power to the antenna amplifier, cut a hole and installed the amp into the bulkhead next to the TV.
Old 12-29-2013, 06:57 PM   #430
Year: 87
I mounted the propane catalyst heater and tested both the heater and stove with my new regulator. i have my 3/8 copper tube, flaring tools and all the hardware to run the propane line out the bottom of the bus to where the tanks will be mounted to both the stove and heater.
Old 01-01-2014, 06:49 PM   #431
Year: 87
i began running the propane lines today:
i used double heat shrink tube to protect the copper tubing
flared my tube
Old 01-02-2014, 05:10 AM   #432
Accordion's Avatar
Year: 1973
Engine: CAT 1160 V-8 Diesel
I love those catalytic heaters. I have three of them.
Old 01-02-2014, 09:24 AM   #433
Year: 87
im thinking about getting a smaller wave 3 for the back of the bus. how do you bring in oxygen?
Old 01-02-2014, 05:05 PM   #434
Accordion's Avatar
Year: 1973
I have three Wave 3000 BTU models. Bring in Oxygen?
Let me assure you that my bus is NOT air tight. If it was, I would leave a window open a half inch. As it is, I have enough air coming in from my front door.
Presently, I also use Electric oil filled heaters, therefore, I only use one of my catalytic heaters. My electric blanket keeps me toasty at night.
I sleep with my coveralls, wool hat, socks, and if it is cold enough, I get in my sleeping bag.
As I am writing, it is 47 degrees in the bus. Yes, it is cold.
Old 01-02-2014, 10:10 PM   #435
Chassis: Ward
Engine: 6.6L Brazilian Ford
Rated Cap: 1
Gotta love those Olimpian heaters; they are the best!!! I'm gonna have one when I grow up
Bus Transformation: My CHEAP project >>> viewtopic.php?f=9&t=466640
gus
gusbus is offline   Reply With Quote
Old 01-03-2014, 09:45 AM   #436
Year: 87
thanks Accordion, im pretty sure my bus is not air tight either, when ever they give a warning like that about adequate oxygen it worries me, but i dont want to be leaving windows open. 47 degrees is pretty cold to hang out in Accordion, try to stay warm where you are at, its hard to type at those temps.
Old 01-05-2014, 06:40 PM   #437
Year: 87
I ran the propane lines to the range today. stove is working well. the line goes from one side of the bus to the other, over the frame and the drive shaft. here are some pictures of how i attached everything together, and secured the line to the bottom of the bus:
Old 01-05-2014, 08:34 PM   #438
Chassis: Ward
Rated Cap: 1
Nice job man
gus
Old 01-05-2014, 09:00 PM   #439
Thats the way it 'otta be--nice work!
Old 01-07-2014, 09:31 AM   #440
Year: 87
Thanks Guys, i need to get another flare T so that i can run another line back to where the water heater will be. i also need to do the soap test on all the fittings.
1984 International s1700 Fully Converted britnich84 Classifieds | Buy, Sell, Swap 6 12-08-2013 01:05 AM
service manual for 1987 Wayne Lifeguard proconsul100 Conversion General Discussions 2 07-10-2012 11:58 AM
CXXVI 87 Wayne lifestar International s1700 6.9 proconsul100 Skoolie Conversion Projects 1 07-10-2012 09:45 AM
1982 International "War-Hog" S1700 Sojakai Short-Bus Conversion Projects 22 05-28-2010 12:19 PM
International S1700 6.9 Diesel Info Needed Please woodyking Conversion Tutorials and How-to's 7 03-31-2008 02:31 PM
