02-22-2016, 10:17 AM
#41
Chassis: International 1753
Engine: 6.9 International
I'd say that should work. Not sure how large you plan on making the sleeper or what your plans are for the ramp on the back, but I'm sure you'll figure it. If not, I'm sure you could sell what you have as is and make money. I know farmers that would use that in a heartbeat to haul hay/straw bales and whatever else they desire.
02-22-2016, 06:39 PM
#42
True! It will still likely be used to haul some hay and firewood I'm sure!
I'm planning on building back 8ft and 7'6" tall.
02-26-2016, 11:54 AM
#43
Engine: DT466E International
Talk about making lemonade out of lemons! This looks like a great way for you to turn a disaster into a really cool project
02-26-2016, 02:11 PM
#44
Originally Posted by mr.friend
Anybody know the best way to remove the body, I could still get alot of use out of it around here with just a flatbed. My original plan for it was a toy hauler, I could still haul toys with a flatbed.
I would have just built a skeleton around the body to the frame, skinned it and went on. But your fix works as well.....
02-26-2016, 08:56 PM
#45
Thanks yall!
03-27-2016, 07:11 PM
#46
So, I have decided that the stock floor is way too flimsy for what I plan on hauling, so I am going to unbolt the entire floor and rebuild it with stronger material. I haven't done anything with it since the body removal, work and other crap taking away time...
Also, just order a set of 4" x 96" chrome stacks!
03-27-2016, 07:35 PM
#47
I would glue down a layer of foam insulation, glue and bolt down a layer of plywood and move on. By insulating the floor you will find its easier to heat and cool. Just my 2 cents.
03-27-2016, 09:03 PM
#48
I've decided to cut the entire body off, all the way up to the back of the passenger door, and then build back 8ft with all new materials, hopefully as shown in the picture. And leave the rest as a flatbed. This way I can get bigger toys on it, and then when I'm not out riding, we can use it to haul hay, or firewood, or anything.
I might do that with the living quarters.
05-01-2016, 09:33 PM
#49
05-01-2016, 10:22 PM
#50
Chassis: B3800 Short bus
With the thought of painting our bus's frame and chassis looming, I must say this is the way to do it! None of the silliness of painting overhead!
05-01-2016, 10:26 PM
#51
Rated Cap: 44 or 66? 11 rows
Silly. Just hold the bus upside down.
05-02-2016, 08:02 AM
#52
Haha, true, but I would rather of painted overhead than have to of tore my bus to pieces.
But still, this way I can get a lot more use out of her.
Also, what better bus to do this to, with the body as bad as it was!
05-02-2016, 08:40 AM
#53
are you going to make a flatbed straight truck out of it? or build your own camper shell from the ground up?
theres quite a few of those cut-off busses around here.. farmers use them sometimes.. christmas tree farms around here use them quite a bit for harvesting trees
05-02-2016, 09:27 AM
#54
So what happened to the chicken coop part?
05-02-2016, 10:38 AM
#55
Coachwork: Ward
Engine: Navistar 5.9 Diesel
Rated Cap: A butt-load...
You know...when (IF, really...) we get our larger bus, i want to do something similar to my shortie 5-window: turn it into a monster pick-up truck!
Not chopping the whole rear, though. Think of the look of the Hummer H2s pick-up style/look. So, leave maybe 2 rows of windows, fill up the area with seats, add A/C, fix up the back bed with entry gates from rear and seating area.
It would be awesome.
Love the paint job on yours! Reminds me of "Optimus Prime".
05-02-2016, 11:25 AM
#56
Have you seen any of those buses where they cut the rear portion to look like the back of a caboose on an old train? Back porch?
05-03-2016, 05:57 AM
#57
I'm gonna build, what will hopefully look like a truck sleeper at the front, 8ft long and 7ft tall, and 8ft wide which is as wide as the bed.
05-03-2016, 06:00 AM
#58
Well, yesterday I spent a few pennies on some metal and got the bed started!!
05-03-2016, 06:30 AM
#59
Very cool, friend. Nice shop, too.
05-03-2016, 11:09 AM
#60
Moderator
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Looks good and very red. Is that 2x2 and 2x4 tubing? How much will the bed weight?
