Old 06-03-2015, 09:00 PM   #181
Chassis: TC2000 Rear engine
Engine: Cummins 8.3; MD3060
I have some silica fume left since I rebuilt my boat. I used it to thicken polyester resin. Silica fume is very lightweight very thin and very inert. I mixed some up with vinegar and spread over very rusty piece of metal. Tomorrow I will see how it all be....
Here is my conversion thread:
https://www.skoolie.net/forums/f11/98-bluebird-tc2000-conversion-2-feet-roof-raise-3-slideouts-9728.html
Vlad is offline   Reply With Quote
Old 06-05-2015, 05:44 PM   #182
Some Rust fighting results
So, I mixed silica fume with vinegar and spread over very rusty piece of metal:
I left piece of metal in vertical position outside. It is very warm and dry outside right now. Here is the next day:
It did affect the heavy rust, but it dried out to quickly... I decided to use the same mix, but covered it with plastic poly. Here is what happened in the morning:
This is after washing it off with warm water and plastic brush (no heavy scrubbing)
This is not bad at all for such a heavy rust, which I didn't even touch.
I think if I mix silica fume with vinegar to make it sprayable consistency I will be able to spray frame over every few hours and It will work great.
The other thing I am going to test is oxalic acid with silica fume and also phosphoric acid with silica fume.
Phosphoric acid is a rust inhibitor and I will use it before protecting steel anyways.
Old 06-05-2015, 05:52 PM   #183
Coachwork: -
Chassis: -
Engine: -
Wow!!
So - ...white vinegar and anything that keeps it on the metal!!
thjakits
thjakits is offline   Reply With Quote
Old 06-05-2015, 05:58 PM   #184
Originally Posted by thjakits View Post
Wow!!
thjakits
This is very true....
The best way is to submerge it but I think I will need a very very big tub to submerge my bus frame, so, dancing around will be necessary....
I ordered some oxalic acid on eBay. It is dirt cheap and people say it works even better than vinegar...
Oxalic Acid 99 5 5 lbs Metal Cleaning Rust Removal with Free Scoop | eBay
Let's wait and see....
Old 06-05-2015, 10:57 PM   #185
I've been working with a lot of hot rolled new steel that has sat in Houston humidity with predictable results. Lots of surface rust on top of mill scale. The only thing that has worked for me so far is Muriatic acid. I have a flat bottom tray that most parts will fit into...leave it for 15-20 minutes and you come back to very clean metal. Just be sure...A., not to breathe it or get it on you...and...B., rinse & dry it thoroughly. It quickly removes both the scale & rust.
Old 06-05-2015, 11:43 PM   #186
Rated Cap: 40 Prisoners
One other item you might try is cleaning vinegar. It has a higher acid
content than regular vinegar.
Old 06-06-2015, 06:43 AM   #187
sojourner's Avatar
Engine: DT408
Ditto on what Tango said for heavy rust removal on heavy pieces. If yu do want a stronger white vinegar (Acetic acid), Sam's Club sells 10% in 55 gallon drums. The last one we bought for use here on the farm was only $75.00. If we want 5% for household use we simply dilute half in half with water. I've used it for cleaning rust from the inside of a fuel tank (didn't want to take a chance on eating through the sheet metal with Muriatic Acid). Muriatic Acid (dilute HCL (Hydrochloric acid)) can be some nasty stuff but is very useful in the hands of someone who knows what they're doing and respects it. The fumes can liquify the linings of your lungs so make sure you're using it in a well ventilated place with the proper safety gear (gloves, apron, safety glasses, etc...). ALlso, it's a good diea once rinsed off with water to neutralize a bit with either baking soda or soapy water and then rinse to stop the working of any residue on the part. Steel is, after all, porous.
I am an sojourner in the earth; hide not Your Commandments from me. Psalm 119:19
Here is the patience of the saints; here are the ones keeping the commandments of YAHWEH, and the faith of Yahshua. Rev. 14:12
sojourner is offline   Reply With Quote
Old 06-06-2015, 12:02 PM   #188
Chassis: TC2000 RE
Engine: 8.3l Cummins
My first go-to for heavily rusted parts, at least parts with some weight to them, is a needle scaler, followed by rust-mort. (Rust-Mort™ Products | SEM Products)
aaronsb is offline   Reply With Quote
Old 06-06-2015, 09:44 PM   #189
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Looks like Ospho.
I'm hungry!
You Gotta Let Me Fly
Old 06-09-2015, 08:48 PM   #190
rvingoffgrid's Avatar
Coachwork: happy camper RV repair
Chassis: international
Engine: 360 international
Rated Cap: 66 passenger
fisherman and proof
Originally Posted by steve.c View Post
I'm looking forward to seeing some photos...
must be a lot of fisherman in here hence the picture rule!
rvingoffgrid is offline   Reply With Quote
Old 06-10-2015, 04:47 AM   #191
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
It's the internet. If there are no photos, it didn't happen
Captain Obvious on deviantArt
Old 06-11-2015, 12:28 AM   #192
Moderator
crazycal's Avatar
Werd........
I'm hungry!
Old 06-11-2015, 10:06 AM   #193
And if there ARE pix...they were probably PhotoShopped.
Old 09-04-2015, 07:09 PM   #194
Coachwork: -
Chassis: -
Engine: -
Hi Vlad,
how ist goin', these days?!
Any news on the "Super Bus" ??
Cheers,
thjakits
Old 10-25-2015, 05:28 PM   #195
Inquiring minds want to know.....
Between you, aaronsb, and wmkbailey I've just gotta get a bus and start! Or I'm going to do a roof raise on my Jetta.
Old 11-01-2015, 10:45 AM   #196
What an amazing thread! You have raised the upper limit of conversions to the stratosphere! Well done sir, well done! If my conversion is a 10th as good as yours, I'll be ecstatic!
jthntrmn is offline   Reply With Quote
Old 11-01-2015, 08:05 PM   #197
I happen to NOT be converting a bus, but building a lightweight trailer. I am still in the ideas stage, but as it will be hauling my mistress' as well as me sleeping in it at night, I needed ideas for added room, insulations, power supplies and all of the rest. I flat got hooked on the craftsmanship in this thread. I can't wait to see and hear the rest of the tail. Thanks !!!
BlipOnTheRadar
BlipOnTheRadar is offline   Reply With Quote
Old 11-01-2015, 09:12 PM   #198
Engine: 190hp 5.9 Cummins
BlipOnTheRadar
Welcome
Head on over to the build thread section and do some reading. You will find all you need to know there complete with pics.
I would only read threads 15 pages or more long.
Asking question will only get you opinions, not true experience and knowledge.
Old 11-02-2015, 07:02 PM   #199
Thank you Nat_ster. I am taking everything i see with a grain of salt. I look at one person does, then go and research it. Hey, there is always more than one way to skin these cats. Right? Thanks for the pointer, heading there now..
"I aim to misbehave." "I am not THAT dude!"
Enjoy the ride Amigo, Blip...
Old 11-08-2015, 02:53 PM   #200
Hi Vlad,
I just got here but want to see the finished product! What a great job so far, judging by the images.
100MPG is offline   Reply With Quote
Roof Raise - Building My Own Flat Roof iverSUN Conversion General Discussions 26 02-18-2019 10:41 AM
Roof Raise ~ Cutting Roof ABOVE Windows ?? chev49 Conversion General Discussions 3 12-04-2012 02:07 AM
Roof raise Rod Conversion General Discussions 1 03-08-2008 05:51 PM
1991 Blue Bird TC2000 RAISED ROOF. 1/2 done conversion. bradnjosie Classifieds | Buy, Sell, Swap 3 10-11-2006 12:28 PM
Roof Raise ~ Cutting Roof ABOVE Windows ?? pixemoss Skoolie Conversion Projects 6 12-31-1969 07:00 PM
