09-04-2017, 07:05 PM
#281
Engine: 3800 T444E
Good job! I love the detail!
09-05-2017, 12:16 AM
#282
Chassis: TC2000 Rear engine
Engine: Cummins 8.3; MD3060
Thanks for the real life experience review. It is very important to have a home quality of life in RV set up. It is not easy to achieve but it is doable.
Here is my conversion thread:
https://www.skoolie.net/forums/f11/98-bluebird-tc2000-conversion-2-feet-roof-raise-3-slideouts-9728.html
09-11-2017, 09:35 PM
#283
Engine: 3800 T444E
Originally Posted by REDD
Great build, you've got to be pleased with it so far.
I see you checking for load/weight for strength, function, etc. I don't get my project 'til June and would like to know.... Does the sheet metal floor/cross members have any strength without the plywood? Are the cross members just tin? Building a toy hauler for ATV's [2, 900lb machines] and trying to gain any inches I can without a roof raise. The shortest guy is 5'-10", everyone else 6'-1" to 6'-5". If the plywood has to go back in for strength , so be it. "Dog nose Thomas 6 foot inside"
Calculate Required Tube Size Using Structural Properties | Allied Tube & Conduit | Mechanical Tube Division
Structural engineers will calculate based on lbs/sqft on average. So, I think residential 2nd story is minimum of 40 lbs/sqft, bathroom is 60. To keep it simple, I plan for 60 lbs/sqft.
Now a space moving out of 4 x 8 is 32 sqft. At 60 lbs/sqft that's 1920 lbs. Build for a margin of error or safety factor (2x) and target 4000 lbs.
09-14-2017, 07:40 AM
#284
Originally Posted by family wagon
That Whirlpool unit looks very similar to the one I bought on "clearance" at Lowe's in April for USD$400.
- Maybe it cooks the carrots just a little longer than we'd prefer.
- We've baked a wide variety of things in there: cakes, loaf breads, muffins.
- Fortunately this hasn't been terrible to work around, and we've gotten better at sequencing the food prep so that this conflict comes up rarely.
- One thing this doesn't do is toast or broil.
Could very well be. There are only going to be one or two manufacturers around the world that build them regardless of the brand slapped on the outside.
Mushy carrots; no one likes them. I'm sure there's a learning curve on the amount of time needed.
If it'll do a good job on cakes, breads, and muffins then it's a real enough oven for me. Breads being the most important. Cakes and muffins would be more delicate so if it can do those as well then it should be pretty decent!!
Can you not take out the roast, microwave your carrots, and then pop the roast back in? Wouldn't want to do that with a souffle or maybe even bread but some things wouldn't care.
That's too bad. Would be a nice feature. How hot does it go? +550° would be nice.
09-14-2017, 02:41 PM
#285
Chassis: Blue Bird
Engine: ISC 8.3
I suppose one could pull the roast out, run the microwave, and put the roast back as you suggest. The microwave portion would have to be done with an oven-safe dish since the racks and turntable will be oven hot. I've always tried to let it cool a bit before running the microwave, though honestly the user guid didn't say anything about that so it's probably fine to run the microwave while the cavity is hot from baking.
Somewhere I saw a model that could be chain programmed for microwaving and baking. For example, microwave to thaw a frozen dish and then switch automatically to bake mode. Seems like maybe that was a high-end GE Cafe series unit that had that feature.
I think this Whirlpool model tops out at 430° F, but don't remember for certain.
09-14-2017, 03:03 PM
#286
though honestly the user guide didn't say anything about that so it's probably fine to run the microwave while the cavity is hot from baking.
Other than melting the plastic bowl you forgot, I don't see any reason you couldn't.
One of those features you didn't know you needed.
Change the 4 to a 7 and we're talking. Gotta have a hot oven for proper pizza!! Priorities man.
09-14-2017, 04:36 PM
#287
got that right!!! i havent found a home-consumer grade oven yet that can bake a Pizza the RIGHT way... but then im old-school. I like a Pizza coming out of an old Blodgett hearth oven
09-15-2017, 12:59 PM
#288
Wood or coal fired is the way to go. I'll just have to build one onsite somewhere. Semi mobile on a trailer.
09-15-2017, 01:20 PM
#289
P.S. My current oven comes close but then mine is more restaurant than residential. Dial goes to 550°. Closer to 600° I think before the broiler kicks on. Pizza stone (actually an unglazed tile) on the bottom of the oven gets it even closer to the 700° mark. Let it preheat, then go another 10~15 minutes for the stone to come all the way up, leave the door open for a minute or so, toss in the pizza and close it up. It fires up to reheat the air. If I had one of them there fancy laser thermometers I could measure actual temps.
10-03-2017, 02:44 PM
#290
Chassis: TC2000 RE
Engine: 8.3l Cummins
Hey Vlad!
Good to see you posting again.
Can you tell me about your air helper spring setup? I am beginning to think I want to do something similar. I had looked at a company called donvel who builds class 8 ride management air spring kits, but they don't want to sell to be because they think I have an "rv". I mean, I guess I do, but it's really just a truck under there.
I'm trying to reduce the amount of bounce and sway that I get on highway driving and rough road, and maybe get a better ride management out of the thing.
10-03-2017, 07:15 PM
#291
Coachwork: -
Chassis: -
Engine: -
I think your best bet is either go to a Truck junk yard or start talking to Firestone!!
thjakits
04-13-2018, 04:04 PM
#292
Engine: dt466e
Had to sub. Very impressive work here. Mad props
06-03-2018, 08:43 PM
#293
Amazing work Vlad! Any updates and photos?
11-28-2018, 12:05 AM
#294
I do have some updates. The biggest update is we decided to move to Europe. So I have no other choice but to sell my skoolie.
11-28-2018, 06:25 AM
#295
How far along is it?
11-28-2018, 07:09 AM
#296
That's a hell of an update. You look into shipping it?
12-02-2018, 10:41 AM
#297
Vlad any idea price for it and how far along it is. Can it be driven or is it in pieces still
12-06-2018, 04:15 PM
#298
Chassis: GMC 3500 Thomas
Engine: 6.0 L GAS
ohhhh....that bundle of wires.......didn't you just sell this bus on Kijiji lately VLAD ?
12-06-2018, 06:48 PM
#299
Good investigating skills....
I got a deposit for the bus. We will finish sale sometime in January.
The guy is very eager to finish it and start using it.
If he decides he can join the forum and post updates as he goes.
12-07-2018, 06:54 AM
#300
Engine: 6.0 L GAS
hahaha....no investigation really....I'm just looking here in Ontario and it showed up as "SOLD"......but yeah.......that's gotta hurt you put SOOOO much work into it. I have newbie fear so I'm looking for a good mini .
Best of luck across the ocean !
