Old 06-16-2016, 10:23 PM   #261
Chassis: TC2000 Rear engine
Engine: Cummins 8.3; MD3060
Originally Posted by dgorila1 View Post
Vlad,
I started re-reading your build again before my boss walked in (oops, better get to work) and had a question: Considering the extensive about of fabrication you did adding underbody storage, the roof raise, body bracing, etc would you consider buying a coach bus and using that as your platform if you did it again? Just curious since the coaches are unibody construction with the full underbody compartments, already have good headroom, etc. Would starting with a coach have saved you any time, money or hassle? Either way I love your build, very inspirational!
I think coach is even better starting point. Schoolbuses are built on budget. If you can find coach with good headroom, storage under the floor and low mileage you can use it as a great conversion project.
The biggest challenge in my conversion are slideouts for sure. Without slideouts the whole conversion is really not a big deal.
The other problem for me is a work place, which I don't have right now.
Here is my conversion thread:
http://www.skoolie.net/forums/f11/98-bluebird-tc2000-conversion-2-feet-roof-raise-3-slideouts-9728.html
Vlad is offline   Reply With Quote
Old 06-16-2016, 10:48 PM   #262
Coachwork: -
Chassis: -
Engine: -
Cool
Originally Posted by Vlad View Post
The engine is fully mechanical, no electronics. The only electronic thing I can see is throttle position sensor which is used by transmission.
...then it should be fairly easy to find a few more HP on this one, though certainly will need a GOOD EGT-sensor and if you can get the intercooler to work better - .....probably good enough!!
Working the intercooler will help a lot - better inflow and outflow for cooling air...
thjakits
thjakits is offline   Reply With Quote
Old 06-17-2016, 12:16 AM   #263
Elliot Naess's Avatar
Engine: 5,9 Cummins
The problem with egt is the distance of 40 feet.....
If I understand you right, you have pointed out something interesting.
Millicent's pyrometer (EGT gauge) came with wiring that is specific for the gauge and sender and cannot be modified or replaced with regular wire. I have no idea how it works. But the length of that special wire might be a problem. I seem to remember there were several lengths available, but who knows if there is one that would reach the length of a 40 foot pusher. You would want to talk to a commercial speedometer shop before making extensive plans. Or perhaps you can look it up online.
Elliot
Old 06-17-2016, 01:34 AM   #264
Coachwork: -
Chassis: -
Engine: -
Cool
Today it should be possible to get the reading "back there" and then send it digitally to the front - or even by bluetooth.
If there is nothing on the (after)market - I am sure one could rig something with Rasperry or Arduino, to get the proper signal and then send it wherever you want (even home if you desire!! )
But you are right - probably not going to find a pyro with a 45 ft lead!!
Cheers,
thjakits
Old 06-17-2016, 01:52 AM   #265
Engine: 5,9 Cummins
Well, now I'm beginning to think of this as a challenge. So I googled it.
Took me about three seconds to type "Isspro pyrometer lead", and bang:
Isspro EV2 Gauges Pyrometer Lead Wire
They make it up to 60 feet long! End of problem.
Elliot
Old 06-17-2016, 02:14 AM   #266
Engine: 5,9 Cummins
I said I don't know how these pyrometers work. What always puzzled me is that they use no electric connection to power it. Well, here is the answer:
"If something's too hot to handle, it's no good trying to measure its temperature with an ordinary thermometer. You could try a thermocouple instead—a kind of thermometer that works by generating electricity according to how hot it gets."
It makes its own electricity.
http://www.explainthatstuff.com/how-pyrometers-work.html
So... our kind of pyrometer is not actually a "real" pyrometer, scientifically speaking. Doesn't matter, of course. I'm very glad I installed mine.
Elliot
Old 06-17-2016, 02:18 PM   #267
Coachwork: -
Chassis: -
Engine: -
Cool
WOW!! 65 feet is loooong run!
I think I'd still rather get a short as possible run and transmit the values by othe means....
I think these wires cannot be repaired and are rather stiff - once broken - get a new meter.....
IF there is no other way to get the numbers put a small camera in front of the gauge in the engine room and send the video up front!!
thjakits
Old 06-17-2016, 02:50 PM   #268
Engine: 5,9 Cummins
The lead is not terribly stiff. I remember no difficulty routing it.
I expect it cannot be repaired (without risk of messing up the calibration).
But you wouldn't need to buy a new gauge, nor sender. The lead is a separate part.
Elliot
Old 06-17-2016, 03:58 PM   #269
When it comes to pyrometer in our application we have 2 options. First get egt sensor, special extension wire and gages. Second get egt sensor read it right there by engine transmit digital or analog signal the front via regular wire. Use digital or analog signal to display value.
In both cases thermocouple egt sensor is used. In first case thermocouple wire is used for extension. In second case regular cat cable can be used, but some sort of extra devices must be used. I am thinking about using arduino to use it for this task.
Old 06-17-2016, 05:29 PM   #270
Coachwork: -
Chassis: -
Engine: -
Cool
Vlad,
I believe there is NO extension for pyrometers (unless you have the proper gear to re-calibrate). You buy them with the needed length of wire and that's how they are calibrated at the factory - if you use a given set, you HAVE to replace a broken wire with the same type and LENGTH or your readings become meaningless....
I agree on the Arduino (or Rasperry) approach, especially as you could use the same gadget for other uses! You can send LOADS of data and even control a few items back there if you want too!!
thjakits
Roof Raise - Building My Own Flat Roof iverSUN Conversion General Discussions 23 06-10-2015 02:15 PM
Roof Raise ~ Cutting Roof ABOVE Windows ?? chev49 Conversion General Discussions 3 12-04-2012 03:07 AM
Roof raise Rod Conversion General Discussions 1 03-08-2008 06:51 PM
1991 Blue Bird TC2000 RAISED ROOF. 1/2 done conversion. bradnjosie Classifieds | Buy, Sell, Swap 3 10-11-2006 01:28 PM
Roof Raise ~ Cutting Roof ABOVE Windows ?? pixemoss Skoolie Conversion Projects 6 12-31-1969 07:00 PM
