Old 12-27-2014, 10:58 AM   #51
Originally Posted by bansil View Post
Looks good, how will slide work?manual,crank,electric or hydraulic?
I vote hamster powered.
http://www.skoolie.net/forums/showthread.php?t=9883 - 7.3L 4x4 Shuttle Bus Toyhauler conversion
headinthetrees is offline   Reply With Quote
Old 12-27-2014, 02:43 PM   #52
Chassis: TC2000 Rear engine
Engine: Cummins 8.3; MD3060
Talking
I am thinking about using 1.5" hydraulic cylinders to push/pull the slide out steel frame. I am not sure yet how many cylinders per slide out to use. The bottom steel frame is very heavy duty all welded, so I might get away with just one cylinder per slide out in the middle.
I wanted to finish building bottom steel frame first but weather is thinking different
Vlad is offline   Reply With Quote
Old 12-29-2014, 01:11 AM   #53
Slide out frame
Here is a small update. I keep building living room slide out frame.
The outside wall frame is done:
The other side:
The same frame is up:
The inside "wall" frame. It is actually just a big opening... I added 2 temp cross brackets to keep it square:
Old 12-29-2014, 01:20 AM   #54
Rivet tool DIY
I use solid aluminum rivets to attach frame members together. I used air chisel and a heavy steel piece:
But after 300 rivets I started thinking about how to make my life easier.... Air chisel works well but it is time consuming and because of strong vibrations I have to clamp everything like crazy.
Today I went to Princess Auto (Canadian HF)and bought few bits and pieces: 2 ton mini hydraulic ram, manual hydraulic pump. After I built a heavy "C" frame from 2 layers of 1/2" steel. Here is what I got after couple of hours:
This tool squeezes 1/4" rivets just like nothing with a few pump strokes. Now what used to take minutes now takes seconds.
Old 12-30-2014, 03:18 AM   #55
once again necessity is the mother of invention. You're gonna have a nice build when this is done, I can already tell.
Old 12-30-2014, 03:44 AM   #56
Thanks...;) Saving money on RV is a good motivator to start skoolie conversion, but it is not enough for most of us here... we love to reinvent the wheel.....
BTW I checked eBay for hydraulic rivet press tools and was shocked buy price tag $600 and up. The tool I built cost me just under 100 CAD+ 2 hours and it works perfectly.
Old 12-31-2014, 05:40 PM   #57
Rated Cap: 40 Prisoners
tools
A man after my own heart. One can never have enough tools. Only addition
to the rivet tool is an air powered pump with a foot pedal so you can have
your hands free to position tool and rivets. Harbor freight makes an air powered pump on a long ram for an engine hoist maybe you could re-purpose the pump unit and save the pumping action for better items like
wrenching and building. You've got a great build going with high quality workmanship, keep up the good work.
Old 01-02-2015, 03:43 AM   #58
Chassis: TC2000 RE
Engine: 8.3l Cummins
So how come you're not just welding the aluminum frame?
aaronsb is offline   Reply With Quote
Old 01-02-2015, 03:41 PM   #59
I was thinking about welding but aluminium welding is tricky. This are just few things to consider when welding aluminium:
1. Welded aluminium is much weaker near the welds unless heat treated.
2. Tig aluminium welding requires major parts cleaning.
3. Aluminium needs raised seam. In my case because I attach aluminium panels from outside of the box frame I will need to grind seam down and this is a bad idea when it comes to aluminium.
Also when I build the frame I use 1 revet at each corner/ "T", so everything is still "flexible". Then I make sure everything is square and straight, then I add extra rivets.
Using hydraulic rivet tool I made makes riveting is not very time consuming.
If I decided to use steel for a box frame I would definitely weld it all.
Old 01-02-2015, 03:44 PM   #60
I use air/hydraulic pump since day 2 (day 1 made me thinking about it) I started using this hydraulic tool. It saves hours and hours of time and elbow grease....
Roof Raise - Building My Own Flat Roof iverSUN Conversion General Discussions 23 06-10-2015 02:15 PM
Roof Raise ~ Cutting Roof ABOVE Windows ?? chev49 Conversion General Discussions 3 12-04-2012 03:07 AM
Roof raise Rod Conversion General Discussions 1 03-08-2008 06:51 PM
1991 Blue Bird TC2000 RAISED ROOF. 1/2 done conversion. bradnjosie Classifieds | Buy, Sell, Swap 3 10-11-2006 01:28 PM
Roof Raise ~ Cutting Roof ABOVE Windows ?? pixemoss Skoolie Conversion Projects 6 12-31-1969 07:00 PM
