01-06-2015, 09:33 AM
#71
Can't wait to see that puppy in action. Great work Vlad!
01-06-2015, 03:05 PM
#72
Chassis: TC2000 RE
Engine: 8.3l Cummins
Need a picture, stat!
Originally Posted by Vlad
The biggest slide out frame is done(living room dining area). The frame looks very solid and square. Now I start covering it up. I will use 0.051" (a bit thinner than 1/16") aluminum sheets. This time I will use #10 stainless screws.
01-06-2015, 07:33 PM
#73
Chassis: All American RE
Engine: Cummins 8.3
Rated Cap: 90
Vlad,
Don't know what kind of plans you have for hydraulics on your bus, but if you aren't already planning a hydraulics system for something else, one could make a pretty good case for something like this for your 3 slideouts: 24 Inch 1250 lb Linear Actuator
At .31 inch/second, the extend/retract would take about 77 seconds, so maybe a little slow, but you'd save the weight and expense of a hydraulics reservoir, pump, and valves, and they'd never leak. Control is a simple switch. They also have the advantage(or disadvantage, I guess) of being locked in place unless powered(lead screw).
Your conversion is looking awesome, by the way. A testament to your hard work. Looking forward to good pictures of your slide hardware. Thanks a bunch for the information about all the fasteners, I'm buying stainless pop rivets tomorrow on your advice.
JDecker
01-07-2015, 03:46 AM
#74
Chassis: TC2000 Rear engine
Engine: Cummins 8.3; MD3060
Slide out frame
Here are some frame parts:
This is frame assembled:
This is a flange that will be attached over sheeting to seal bus wall when box is in closed position:
The other view of the flange:
Flange from top:
I made flange from 4" flat 1/8" aluminium and 2"x2" angle riveted together.
Sheeting is ready to be attached:
01-07-2015, 04:00 AM
#75
Originally Posted by JDecker
Vlad,
JDecker
I need 48" cylinder/actuator for living room slideout. At this point I have no idea how much power I need to push slide outs. I want to build box and the moving parts first then I will test how hard to push it in/out.
Right now the weather is making me stay inside and work on box instead of working on the bus.
There are some 1.5" hydraulic cylinders. They are cheap, light, powerful. The bus actually have hydraulic pump that turns cooling fan but I have no idea about pressure. If somebody knows the pressure at cooling pump please let us know.
Update:
Here is a complete Hydraulic Fan Drive System explained with all details:
http://www.centralstatesbus.com/2003...s/a3hydfan.pdf
It looks like I will have enough pressure to use for slideouts.
01-07-2015, 09:46 AM
#76
I would think your bus would also have a basic engine driven hydraulic pump for steering. If so, many such "big rig" type steering units take from a thousand to 1500 pounds of pressure. Very likely Ross power steering, many buses are. If so, plenty of pressure there to tap into.
01-07-2015, 11:06 AM
#77
This bus has a large hydraulic pump that provides enough pressure and flow for cooling system and steering system. This 2 systems are complicated but well documented to find point where I can cut in.
01-07-2015, 09:55 PM
#78
Chassis: B3800 Short bus
Holy toledo Vlad... Ever think about moving further east?  I reckon I could learn a thing or two off ya!
01-07-2015, 10:30 PM
#79
Chassis: TC2000 RE
Most hydraulic steering systems (assist or direct) have isolation or are independent of working hydraulic groups. I would suggest you consider an electro hydraulic power pack or a linear electric drive system.
If you use a set of electric screw rams, its easy to put an amp meter on the motors to indicate binding and other issues you night encounter when extending or retracting.
I would try to keep the steering system as simple as possible if you can.
01-08-2015, 12:57 AM
#80
Finally front side paneling is done.... Lots and lots of screws.....:
I tried using #8 stainless screws but they snapped too easy when I drove them into 1/8 aluminum frame. I switched to stainless screws #10 and they hold very well. The screws have "truss head". Here is comparison to regular screw:
I used Basf NP1 polyurethane sealer. This sealer is "very slow" which is good property in my case.
Here is a frame covered with NP1 before sheeting is attached:
