Old 01-08-2015, 01:11 AM   #81
Chassis: TC2000 Rear engine
Engine: Cummins 8.3; MD3060
Originally Posted by aaronsb View Post
Most hydraulic steering systems (assist or direct) have isolation or are independent of working hydraulic groups. I would suggest you consider an electro hydraulic power pack or a linear electric drive system.
I would try to keep the steering system as simple as possible if you can.
You are right the steering system has separate circuit after flow divider:
If I ever decide to use the main pump I will use hydraulic solenoid valve for isolation that will open only when energized. Also I guess I will open/close slideouts only when bus is parked.
I do understand the last thing you want to have is a lost steering assistant when you drive this 40 feet monster....
I am still thinking what way to go. I might go mechanical way: chains or cables or rack and pinion...
Vlad is offline   Reply With Quote
Old 01-08-2015, 01:07 PM   #82
Chassis: TC2000 RE
Engine: 8.3l Cummins
Use a single electrohydraulic pack and ram, and then a heavy duty chain to balance the pull to the left and right side. Use some large threaded rod and nut adjusters to ensure the pull is even on both sides?
Idunno - I've never built a big huge camper slide, just a few hook loaders and rollback chain flatbeds.
I'm guessing you'd want a double acting ram and valving setup, so something like these bits:
http://www.northerntool.com/shop/too...9766_200329766
http://www.northerntool.com/shop/too...ct_10214_10214
Hydraulics get expensive quickly.
Linear actuators are pretty cheap in comparison.
http://www.surpluscenter.com/Brands/...-5-1680-24.axd
http://www.aeicomp.com/Detail.asp?Pr...el+Tracking%29
aaronsb is offline   Reply With Quote
Old 01-08-2015, 04:33 PM   #83
You might check with "Ol' Trunt"/Jack and the thread about his '35 Chevy. He built a slideout for it that is now operational appears to be quite functional.
Old 01-08-2015, 11:34 PM   #84
Chassis: All American RE
Engine: Cummins 8.3
Rated Cap: 90
I'd go with something like the second link provided by Aaronsb. 48" linear actuator, no hydraulic fluid to futz with. Seems simple, lightweight, relatively inexpensive and easy.
I can hear my dad's voice saying "safety first" when you talk about splicing into the power steering.
Regardless of what you use, I'm sure it will turn out fine. You do good work. Just my $0.02.
JDecker is offline   Reply With Quote
Old 01-09-2015, 12:48 PM   #85
I would not tap into the power steering if it was my bus.
A little electric powered hydraulic pump like that used on pickup and trailer dump boxes would take care of your hydraulic needs if you decided you wanted to go with a fluid hydraulic system.
If you have air brakes why not tap into the the auxiliary air tank to power air hydraulic cylinders? If one leaks you won't have a mess to clean up.
Old 01-09-2015, 10:47 PM   #86
Coachwork: -
Chassis: -
Engine: -
Cool
Hi all,
...check this for Rack&Pinion:
http://www.oldboyrecords.com/thebus/
...check this for Jack-Screw:
http://www.pirate4x4.com/forum/exped...-camper-7.html
Fantastic build so far!!
Cheers,
thjakits
thjakits is offline   Reply With Quote
Old 01-13-2015, 12:40 AM   #87
Finally I finished living room slide out box.... Here are some pictures:
Just one window temporary put in. There will be 4 in the front wall and one on each side.... (my wife likes light....)
From inside:
The roof from inside:
Tomorrow I will start working on sliding mechanism.
Old 01-13-2015, 08:02 AM   #88
Outstanding work!
That looks a lot more stout than any S&S slide out I have seen.
With as much strength built in you will have very little issue with racking while going in and out.
Old 01-13-2015, 09:10 AM   #89
So...just how long did you work for Boeing? --- Beautiful work!
Old 01-13-2015, 01:12 PM   #90
Chassis: TC2000 RE
The slide looks great!
Roof Raise - Building My Own Flat Roof iverSUN Conversion General Discussions 23 06-10-2015 01:15 PM
Roof Raise ~ Cutting Roof ABOVE Windows ?? chev49 Conversion General Discussions 3 12-04-2012 02:07 AM
Roof raise Rod Conversion General Discussions 1 03-08-2008 05:51 PM
1991 Blue Bird TC2000 RAISED ROOF. 1/2 done conversion. bradnjosie Classifieds | Buy, Sell, Swap 3 10-11-2006 12:28 PM
Roof Raise ~ Cutting Roof ABOVE Windows ?? pixemoss Skoolie Conversion Projects 6 12-31-1969 07:00 PM
