08-21-2017, 07:18 AM
#41
Originally Posted by M1031A1
Conversion goes more efficiently when you have help. Doing it by yourself is tougher and takes longer.... HOW do I know.......
Oh I know it well. I'm doing my conversion alone too. 10 months later......
08-21-2017, 07:29 AM
#42
I'm going on three years. But I've done it all for free or for VERY little money.
Slow and deliberate!
And help from friends along the way is always super.
08-21-2017, 07:50 AM
#43
Wow, 3yrs! I wish I could take my time. I'm on a time crunch...sort of...I had promised my Mom I would be down her way (Fla) by the end of the year. So with that it mind, I'm shooting for getting it livable and probably finishing down there. So stressful.
I think I can get the interior done, plumbing and electrical too. I'll worry about solar later on.
08-21-2017, 08:32 AM
#44
Chassis: Saf-T-Liner ER
Engine: 3208 CAT/MT643 tranny
Rated Cap: 87
ECCB,
We're in year SIX..... Second year into the build, but almost four years in the hunt before the find......
08-21-2017, 08:33 AM
#45
ECCB,
I look at my bus like its a fine wine.
08-21-2017, 08:34 AM
#46
Maybe we can give you a hand with it when you get here?
08-21-2017, 08:36 AM
#47
Rated Cap: 87
I look at mine like it's a fine whiskey...... (Let the corny jokes ensue!!! )
M
08-21-2017, 08:45 AM
#48
I would be forever grateful!
08-21-2017, 08:52 AM
#49
My Shorty arrived from Utah on August 3rd, 2011. Been at it ever since. Had to take a little over a year off to beat some cancer and had limited time available for another year or so but now work on it just about daily. I knew it would "take a while" given it's age (and mine) but had hoped to be further along by now. No complaints, just need to stay at it and wrap this sucker up while I can still drive it.
08-21-2017, 10:02 AM
#50
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
All the guys
All the guys with the highest post totals take longest to convert their buses???
I got mine first of the year 2017. Took about 4 months to get it running the way I liked. Am finishing the last of the demo/repair work and then I can start my build.
I tried not to have a date for completion in mind, just accomplish one thing each day on the bus, no matter how small. Forward progress.
Today, am sealing hole where old toilet vent went thru floor. 16 ga steel, riveted over old hole. Seal w/ PL goop.
08-21-2017, 01:13 PM
#51
Most of us "old timers" are doing full-on builds.
I could do what 80% of the folks on here do in a month or two, given ample funds. Most folks just leave the rotten interior in place and build a sort of slipshod camper and call it a day. Nothing wrong with that.
But some of us are really into building an EPIC project, and you can't rush perfection.
08-21-2017, 04:50 PM
#52
Good move. I'm thinking of doing 2.
One now - faster, to learn lessons from. Also probably bigger to handle kids,
One later - integrate the lessons learned and do a better job . Smaller.
WE will see!
08-21-2017, 06:30 PM
#53
My first attempt at bus ownership was a learning experience. 1985 Thomas on a Ford chassis with a gas engine. Total POS.
This current Roll Your Own bus is sorta my lifelong dream, and I'm taking as much time as I want. I have no time constraints, and no imaginary deadlines. Just doing it as I can when I can.
But my shorty is for immediate enjoyment. Other than the paint job that's taking forever due to prep, parts sourcing, other projects and a busy work schedule.
08-22-2017, 08:56 AM
#54
Engine: DT530
This build is going to be somewhere in the middle. I always believed that a job worth doing is worth doing correct. But I will have to do it in phases because I want to be using the bus while I still have children living at home. So my plan is to do the interior the right way and then slowly over time sandblasting the underside and repaint and recoat it.
Sent from my SAMSUNG-SM-G930A using Tapatalk
08-22-2017, 11:07 AM
#55
Traveling
Rated Cap: '00
I hear you. My time constraints are the seasons. I need to be done with the outside- paint by the time it's cold. But then some inside stuff needs to be done before the outside stuff...vicious cycle
My worry is getting to 80% complete...and living with it. Get 'er done.
Are you really sandblasting the underside of a bus? That will be an undertaking and messy.
Maybe lay a pipe with several nozzles pointing upward and hooked to a big bridge-blaster pressure pot. Drive-over slowly for the undercarriage treatment.
08-22-2017, 11:15 AM
#56
Engine: DT530
I will power wash and coat the areas without rust. When I find rust I will sandblast, treat, paint then undercoat.
Very time consuming but the end result will be worth it.
08-26-2017, 01:29 PM
#57
Engine: DT530
I am ready to start welding the patches for lights and rust but is there anything that I need to disconnect first?
08-26-2017, 01:37 PM
#58
If you have an electronic transmission or any other computer controlled nonsense on your rig, it is important to disconnect your battery before doing any welding anywhere on the body or chassis. Some people get away with it, others have fried everything.
08-27-2017, 06:13 PM
#59
Engine: DT530
I am trying to decide how much AC I will need. I have factory road air so I'm looking at AC while parked. The plan is to have 3" of spray foam on walls and ceiling. Insulated curtains for the 12 remaining windows. Solar panels will shade a large portion of the roof. I would like to do 2 rooftop units with one being 5000 btu so it could run of solar and the other 10000 btu when plugged in.
How do I know if this will be enough or excessive?
08-28-2017, 06:55 AM
#60
It depends on how much ceiling height you can afford to lose. 3" foam means you're going to lose roughly 2"of finalized height. And then factor in your flooring...you'll lose more.
The spray foam I used (foam-it- green)will give me an R-value of 7 per inch. So, so far I have an R-value of 14 but I'm not done yet because I plan on putting a layer of something (haven't figured it out yet) between the foam and my wood ceiling to have even more of a thermal barrier. I didn't go any thicker with the spray foam because I figured 14R value would be enough without taking away too much of my ceiling height allowing me to put up something else for my thermal break. I'll also have solar panels on the roof which should help.
Sent from my SAMSUNG-SM-G930A using Tapatalk[/QUOTE]
