Old 09-09-2016, 10:53 AM   #41
Justin McCormick's Avatar
Chassis: Saf-T-Liner MVP ER
Engine: Cummins 5.9L Diesel Engine
Rated Cap: 83
Great progress!
Follow our bus blog here -
https://www.wildernesswandering.com/
Justin McCormick is offline   Reply With Quote
Old 09-09-2016, 11:13 AM   #42
I actually Love the idea of the floors down before walls.. esp in a bus where the weather conditions change alot.. keeps you from having issues with individual room floors peeling up around the edges.. Lookin good!!
Old 09-09-2016, 11:16 AM   #43
FlyboyHPD's Avatar
Awesome progress, and looks good as well. Keep up the great work.
1999 International AmTran, DT466E, MD3060
https://flyboyrv.wordpress.com/
FlyboyHPD is offline   Reply With Quote
Old 09-09-2016, 01:03 PM   #44
Carytowncat's Avatar
Dawww those fur kids are doing great work. They remind me sometimes the best decision is to nap.
Old 09-09-2016, 07:56 PM   #45
Originally Posted by Tango View Post
"Great Stuff" is not at all metal friendly. Unless the metal is very well treated/painted it will rust it like crazy. You would be much better served using something like urethane based automotive seal sealant.
I totally agree. My buses privious owner used foam in a can😣 I will be learning sheet metal work before any other.
Tootalltechie is offline   Reply With Quote
Old 09-09-2016, 09:35 PM   #46
I miss my fur kids....
BAD!!!!!!
Old 09-11-2016, 08:34 AM   #47
Nice progress! Keep us updated.
superduty_59 is offline   Reply With Quote
Old 10-25-2016, 10:39 AM   #48
rjnye79's Avatar
Engine: T444e
Back with another update! Unfortunately, Hurricane Matthew set us back a couple weeks because we had to evacuate and come home to clean up the mess. I hope any of you in coastal Southeast faired well after the storm. Now, let the conversion resume!
Framed up and started putting some panels on what will be the bed...
This will be the galley kitchen. We also began to install the water system...
Tankless water heater (Eccotemp L7), mounted...
Flojet water pump and in line strainer, mounted...
Ran the hot/cold water through the ceiling and over to the shower stall...
Framed out the shower stall...
Shower stall beginning to take shape...
Closet/pantry, plus extra insulation for the windows...
We still have a ways to go, of course, but it feels like we are finally getting somewhere. She is starting to look like something, if you know what I mean. On the immediate schedule is to finish framing and plumbing, then begin electrical and painting. I am really feeling intimidated by the electrical install upcoming. We have a couple friends who are electrically inclined and hoping they will be of some assistance. Thanks everyone, for checking in again and I hope you all have a great Halloween!
rjnye79 is offline   Reply With Quote
Old 10-25-2016, 10:59 AM   #49
Chassis: B3800 Short bus
This bus is turning out great! Is that blue plastic drum for fresh water, or grey water? The location is great. It's also nice that it's vertical to minimize slosh while driving.
I'm also going to install vinyl flooring. While the plywood floor is serving us well, it'd be nice to have something cleaner looking
For this type of flooring it makes perfectly good sense to roll it out through the entire bus and build on top of it. A) because it comes in big sheets and B) because it doesn't expand and contract with temperature and humidity. It'll be nice around the water pump and tank, too, since a leak will be fairly obvious without soaking through the floor layers. Very nice.
Old 10-25-2016, 12:40 PM   #50
rjnye79's Avatar
Engine: T444e
Thanks! Yes, the drum is our fresh water tank. We have another, smaller one that will be mounted under the bus for our grey water.
Old 10-25-2016, 07:21 PM   #51
Great build!
Subscribed
Old 10-25-2016, 08:47 PM   #52
You be Rockin! Keep the pix coming.
Old 10-27-2016, 10:45 AM   #53
rjnye79's Avatar
Engine: T444e
Thanks, y'all... A question for any of you that have cut holes in the floor pan or body of your bus: did you just use a regular hole saw, jig saw, or some specialized bit?
Old 10-27-2016, 10:53 AM   #54
I've cut a bunch of holes in just about every part of my bus and have used a variety of tools.
My favorite is probably a 4-1/2" angle grinder with a thin cutting disk.
Also bought a 7-1/2" steel cutting blade for my circular saw. Used it at a critical depth setting to remove body panels without affecting the ribs.
Then there is an air powered Body Saw. Great little tool that I often use in conjunction with the grinder to finish squaring corners.
bluebird, budget, full time, international 3800, t444e
