01-05-2018, 08:16 PM
Coachwork: Amtrak RE
Chassis: International 3000
Engine: T444e
Originally Posted by joeblack5
If I would spend most of the time in the cold then I would take a bus from that area. All the specifics for that climate are already there.
I would imagine that arctic buses are much better taken care of since a breakdown in that climate can turn into a disaster quickly.
my $0.02
good luck, j
We’re actually sub-Arctic here (120 miles south). The local schools buses seem to go to tour operators and such and then get run into the ground by the time they’re finished. There isn’t much locally available.
Most of this state is also pretty empty of people: I was staying at Chena Lakes campground shortly after I arrived, which is much like any campground in the lower 48 (camp hosts, bathrooms, little fire pits, numbered spaces, etc.). Out of curiousity, I checked on Google Maps to see what was behind our campsite. Nothing... no roads, houses, or sign of humanity for 3000 miles. Finding somewhere with 10 miles in the lower 48 is rare and 100 miles would be unheard of without at least a logging road. Most of the other directions were the same. There are 12 roads in the state, numbered 1 through 12. Most towns, including the state capital, do not connect to them.
In any case, the decision is already made. We bought it and now we have to drive it.
01-06-2018, 01:12 AM
We have family that’s moved to Alaska and are always happy for new supplies to come in.
Consider bus things you need, first for its operation and secondly for your build. For example many of the Home Depot’s in this area carry metal studs and track.
Also consider a few southern grocery items that you may never have experienced. I would place a couple bags of slow cooked grits, and a few jars of the only real mayonnaise (Duke’s brand). These should be available in any grocery store around where you pick up your mobile castle.
I look forward to your posts about the voyage and the build.
01-06-2018, 01:24 AM
A somewhat local resource for your build: Ana White | Woodworking Projects
She and her husband are builders. They have built a few tiny houses and she has designed many items for tiny builds.
If you do sketchup (I highly recommend learning this free CAD program for your design phase), she has most in this format and/or PDF. All her computer stuff is free.
01-06-2018, 05:01 PM
Engine: T444e
Brainstorming floorplans
I'm brainstorming ideas. Our bus is a little narrower than most (84"), and my working assumption is we will lose 2" from each wall for insulation/finishing. This adds a major challenge, particularly around the bathroom. It also limits the width of bunkbeds to 28-30". The other big challenge is building around the rear engine compartment and fitting in 1 adult bed and 3 kids beds while leaving space left over for other things.
None of these designs include a utility closet. Not sure if I need one yet. Right now, it's brainstorming. It's hard to know how well any of this will actually fit looking at a picture, but at least it gives a rough idea.
A sideways bed is not ideal - one of us always has to climb over the other. Trading the Queen Bed for a Full Bed could save 6” of space. Worth it or not? (lose drawer space also).
30” high set of drawers on the end of the bed (5 drawers high at 6” each!) No bottom corner drawers (wheel well) means 23 total full-size drawers (or other storage choice)! Wall just far enough away to open fully.
Oven is right next to bathroom door and side exit (other choice is next to couch). Not ideal. Bathroom is also too small to comfortably change clothes in.
Because of Engine Risers, have to cut into bottom corners of the mattress slightly on each side. Rear Shelf depth has to match the angle of engine riser but can go all the way to ceiling. A top shelf across the back would be possible, but would it feel cramped?
We have about 1' around the bed - kind of an awkward amount of space
Having a table/desk gives a lot of flexibility (sewing, folding clothes, kids art projects, etc.). It would be possible to put a washing machine under the desk, but it would be a small model.
Bathroom should feel comfortable inside. Don't like that shower and toilet are in same room.
47" master bed is halfway between a Full (54") and a Twin (38"). Bedroom isolated by 3-1/2" of sound-proof insulation, a heavy curtain, and sound machine.
Lower starboard bunkbed has 12" of shelving. Top starboard bunkbed has no shelves. It is full length but would usually be used for storage. Both are 28" wide, which is pretty narrow. Other bunks are 30" wide.
Bathroom is cramped but usable. Would have to enter kids room to access toilet. Toilet and shower are separate rooms. Lose the tub and just have a shower in one room.
Lots of room up front. What to do with it? I'm curious about trying to fit in a wood stove (dry heat, cheap fuel source, redundancy, cooktop), but the clearances around it are going to be a problem (I also drew it too small - just put it in for conversation). Could also do a full-size fridge, more kitchen counter space, or (most likely) more seating/living room area.
01-06-2018, 05:30 PM
Engine: T444e
There are slow-cooked grits available at the grocery stores in Fairbanks, but not the stone-ground stuff. I figure the wife will get a lot of stuff at various stores in Georgia that are not available here. We're from Georgia. Unfortunately, I'll be doing some government travel during the big game on Monday.
Not sure if there is anything we should bring up from the build from the lower-48... Amazon Prime will ship to Alaska for free, but almost every other website has insane shipping costs. We have most chain stores in Fairbanks (Home Depot, Lowe's, Sears, Walmart, Barnes&Noble, REI, Blockbuster(?!?!), but very few specialty stores.
I would suggest that you reconsider the placement of the plumbing fixtures. Nearly all RV's (as well as home builts) have them on the driver side for a couple of reasons. To begin, that is the side all dump stations are set up to service...and...the passenger side is where most folks play when outdoors. With the right bus, you may be able to run them across from the P side to the D side, but unless you have full through bays, it can be extremely difficult.
Just my dos centavos.
01-06-2018, 05:32 PM
I’ve been learning Sketchup, it can be very precise and allows 3D modeling.
The bulk of Sketchup is free and definitely worth the effort to learn. If it seems like something you are interested in, I’ll be glad to help get you oriented. My biggest challenge was the overwhelming amount of help available.
01-06-2018, 05:51 PM
Engine: T444e
Originally Posted by Twigg
Well to start with the drivers do not need any class of CDL.
What they might need is a Class B adding to their Alaska license. I haven't checked the Alaska rules so I don't know. The titling of the bus is irrelevant unless the bus is being driven commercially. CDL rules apply ONLY to commercial driving ... It is the driver who is covered, not the bus.
Put another way ... Commercially driving a bus requires a CDL. Driving a commercial bus doesn't, but there might be state restrictions on a regular license.
The only critical thing you need to do is make sure, as far as you can, that the bus is ready to do the miles. That means a full service with all fluids changed, leaks taken care of and a few decent runs before she attempts 5500 miles. If there are going to be any really cold starts, make sure the pre-heaters (whatever are fitted) are working and a block heater would be a good idea.
It's going to be a 10-day (ish) trip (driving) and I'd recommend removing all the seats except for the front seats needed to make the journey, and have her drive motel to motel along the way.
Get recovery protection from GoodSam.
Have her stock up on spare belts and fluids .. Oil, trans fluid and coolant.
Beyond that I'd leave the work until I got it home. A fully stripped bus would be cold and noisy, and that's a long way home.
Enjoy the ride.
Alaska requires us to register it as a bus, unless we convert it to an RV first according to AK standards. That means it has to be painted something different from yellow. And, I need to sign an affidavit that I have permanently installed independent life support systems and provide at least four of the following items:
1. Facilities - cooking, refrigeration or icebox
2. Self-contained toilet
3. Heating and/or air conditioning systems for the motor home unit.
4. Potable water supply system including a faucet and sink
5. Separate 110-125 volt electrical power supply and/or an LP gas supply.
The bus is listed on the current (Georgia) Title as having a GVWR of 30,000 lbs, which puts it into the Class B category (the GA Title may be going off of max capacity, not actual weight). It's possible that we could have it weighed and come up with something under 26,000 lbs and avoid that requirement.
If it registered as a bus or listed as being over 26000lbs, I need an Alaska Class B CDL if I am reading the Alaska regs right: Commercial Driver's License (CDL), Division of Motor Vehicles, Department of Administration, State of Alaska
Additionally, as a complicating factor, I can't register the vehicle until it is actually in the state of Alaska... Because I bought it out of state, I have to drive it here first and then have a Alaska-certified mechanic do a VIN (safety) inspection. I'm not sure how we'll overcome that one, but I'm sure there is a way. I think there is a temporary one-way registration.
01-06-2018, 05:54 PM
Chassis: Saf-T-Liner MVP ER
Do what you think you need to do, but I am assuring you that you do not need ANY class of CDL.
You might need Class B on your Alaska license, but that's a different animal.
01-06-2018, 06:02 PM
Engine: T444e
I made the floorplan using excel with .25"x.25" cells - then transferred it over to powerpoint and made it the slidemaster - I can easily move and resize furniture around on top of it. It works for brainstorming, but I might want something more robust later on (particularly to view in 3D).
My computer is having issues and sketchup kept crashing, so I tried something else. I may take you up on your offer when I get my software fixed.
That's a good point. The fuel tanks are in the middle of the bus, which may make it difficult to run things back and forth. Because of the weather conditions here, I also need to consider plumbing insulation - if it is -20 (or -50) degrees outside, it's going to be hard to keep pipes outside of the cabin from freezing. Is there a way I could run most of the plumbing inside the cabin without making everything difficult and awkward? It's either that or a whole bunch of heating elements. A heating element in the water tank shouldn't be too hard, but the pipes might be something else.
Something to think about - what's easiest and makes most sense.
