Old 08-24-2019, 02:51 PM   #1
Chassis: 3800 Serie
Engine: T444E International,
Rated Cap: 43 Adults
Lightbulb Bathroom Location Options
I really want my bathroom in the back of my 2004 Bluebird 3800 series. I haven't seen any layouts with the bathroom in the back. I have seen a video of young couple from Australia that did just that. It was a great design and gives more of a full bath look. Can anyone point me in the right direction?
campiltons is offline   Reply With Quote
Old 08-24-2019, 03:25 PM   #2
Coachwork: Blue-Bird
Chassis: TC RE 3408
Welcome to the forum. Sorry I can't really help you with your question. I have a rear engine, so my bedroom is going in the back, and the shower and toilet are just in front of the rear axle. And if I had a front engine I would want storage in the back, accessible from either outside through the rear door, or from the inside through a door in a wall that would prevent things from falling or sliding forward during a braking incident.
In my opinion, storage in the back is the only reason for having a front engine, but there are diverse opinions on this site, and I am confident someone will have some suggestions for you.
gs1949 is offline   Reply With Quote
Old 08-24-2019, 03:34 PM   #3
Year: 1980
Coachwork: Blue bird
Chassis: Chevy254
Engine: Chevy 350 Allison At543
Mines in the back but it’s big at 7’-9”x5’-6” then my bedroom is 7’-9”x8’ then the kitchen/living in the front at 7’-9”x12’
just a guy with a bus.
Mista Bus is offline   Reply With Quote
Old 08-24-2019, 03:58 PM   #4
Find the most suitable location for your black and gray tank under the bus for ease in plumbing the drains needed. Bathroom can then go almost directly above that area.
Old 08-24-2019, 04:09 PM   #5
Chassis: TC RE 3408
I think that's very good advice, and it applies to either FE or RE.
Old 08-24-2019, 04:09 PM   #6
CMORGANSKOOL's Avatar
Coachwork: IC
Chassis: FE Bus
Engine: DT-466 7.6L Turbo Diesel
My bathroom is going in the back. Just watch clearances, on mine the exhaust pipe pops over the rear and comes down the one side so no tanks can go there and you have to position the toilet hole between the cross members underneath. Tanks should go as close to the axle as possible.
If you complete your profile with your bus year, make model, length etc we can help you some more.
CMORGANSKOOL is offline   Reply With Quote
Old 08-24-2019, 05:55 PM   #7
I thought these were only 7'6" wide?
Old 08-24-2019, 06:02 PM   #8
Year: 1980
Chassis: Chevy254
Yep mine is actually 7’-3” just measured I believe 7’-9” was the OD
Old 08-24-2019, 06:26 PM   #9
I've seen one rear bath, next to the 54" wide, standard double bed in the back of a shorty. they used a Thetford wet-bath with cassette toilet, which was 27" wide and something like 39" long.
"Reality is that which, when you stop believing in it, doesn't go away" - Phillip K. Dick
JustKip is offline   Reply With Quote
bathroom locations
