Old 08-10-2011, 04:35 PM   #191
Accordion's Avatar
Year: 1973
Engine: CAT 1160 V-8 Diesel
Re: Best Home Yet
Originally Posted by somewhereinusa
Hey Rudy,
The 3208 is the replacement for the 1160, basically the same engine with different injector pump. Neither have oval pistons.
Nice to see a familiar face. I thought that Mark O. had mentioned something about the 3208 oval shaped pistons that needed to get warmed up in order to not leak oil through the cylinder walls. Perhaps I did not quite understand what he meant.
Old 08-10-2011, 04:37 PM   #192
Accordion's Avatar
Year: 1973
Re: Best Home Yet
Originally Posted by Stuff
thats's some exploring!
Stuff, I have detailed photos of my replacing, what I learned was, the lifter pump. It was a success.
Old 08-11-2011, 01:27 PM   #193
Re: Best Home Yet
Salut Accordéon!
Tu as fait du vrai beau travail sur ta conversion! Félicitations!
By french-canadian and cajun, I guess that you're originating from New-Brunswick or Nova-Scottia? I'm a frenchie too but not cajun, I'm a Quebec-er
Andreb is offline   Reply With Quote
Old 08-11-2011, 03:19 PM   #194
Accordion's Avatar
Year: 1973
Re: Best Home Yet
Originally Posted by Andreb
Salut Accordéon!
Andreb, Merci. Bien oui, je suis Canadienne. Edmunston, New Brunswick.
Oh, for those who don't read French, Andreb's compliment translates to " You have done very beautiful work on your conversion! Congratulations!"
Old 08-11-2011, 03:36 PM   #195
Accordion's Avatar
Year: 1973
Re: Best Home Yet
Here are some various items, one of which I am going to guess is the governor. Here are some pictures of that. Am I correct in my guess?
As you can see, I have an oil leak on the passenger side valve cover. I don't know where it is coming from.
Old 08-11-2011, 03:44 PM   #196
Accordion's Avatar
Year: 1973
Re: Best Home Yet
What is this thing? It has a screw-on pipe fitting. It is in the middle of the engine, situated on what would be considered the intake manifold on a gasoline engine.
(Edit) I later learned that this is the lifter pump which supplies fuel from the fuel tank, through the fuel filter, to the injector pump. I became very intimate with this pump because I had to replace it. Pics of that job coming soon.
Old 08-11-2011, 03:46 PM   #197
Accordion's Avatar
Year: 1973
Re: Best Home Yet
One last thing? What are these things on the side of the compressor? One looks like it has a screw cap on top of it, and the other thing looks like a breather of some sort. Thanks for your time to answer questions. I am impressed with the knowledge of buses and bus engines on this forum.
Old 08-11-2011, 03:49 PM   #198
Accordion's Avatar
Year: 1973
Re: Best Home Yet
Here's a report on the heating of the bus. It is now the end of December. The average temperature at night is mid twenties. It has gotten down to 17 degrees. I thought that with as much insulation that I put in to the bus, it would be warmer inside. I am using two oil filled electric heaters. I use the middle setting (900 watts). I also have three propane catalytic heaters.
If it gets down to the teens at night, I will use all three propane heaters. The electric ones are always on. It is expensive to heat this thing. I think that I am losing a lot of heat through the many windows that are in the bus.
I can see now, the importance of having a wood stove. I almost wish that I had kept mine. But, as I had mentioned, there was no room for it.
I think that if I am still here next winter, I will make an effort to seal the windows. Perhaps I will make a removable system of "storm windows" for the outside.
It's not as if I am freezing inside the bus. I can usually get the temperature to be 50 degrees higher that what it is outside if I use all my heaters. It is, however, costing me a bunch for electricity and propane.
Perhaps, I will have to do what my friend Bob does, and go to Arizona for the winter. If I didn't have my recording studio in here, I definitely would have kept my wood stove.
A report on the waste tank. It is under the bus. It got frozen this winter, making it impossible to dump. I, then, became a bear in the woods!!!
Lesson learned: mount your tanks (all of them) inside the bus.
Old 08-11-2011, 03:50 PM   #199
Accordion's Avatar
Year: 1973
Re: Best Home Yet
Doggies taking a nap.
Old 08-11-2011, 03:53 PM   #200
Accordion's Avatar
Year: 1973
Re: Best Home Yet
Night time.
Got it home, time to make it home. ThePimentals Skoolie Conversion Projects 11 07-29-2013 08:17 PM
HOME bansil Skoolie Conversion Projects 2 05-29-2013 10:53 PM
Just for fun... do this at home frank-id Conversion General Discussions 0 07-26-2009 10:14 PM
new bus home westport_wayne Everything Else | General Skoolie Discussions 7 09-14-2006 06:50 AM
Well, I'm home with my new bus! Griff Coach Conversion Projects 11 07-07-2006 11:00 AM
