Old 05-05-2014, 12:34 PM   #31
Re: Betsy
I prefer Flickr myself but hate the BS little icons the geeks come up with. They have twice shuffled them around over the past two months because so many people complained. There were even a number of Blogs that sprang up dedicated to trying to sort out the WTF aspect of the changes. OK once you get the gag but a really stupid and unnecessary move on Flickrs' part. The old system was one anyone could understand.
Old 05-05-2014, 06:19 PM   #32
Chassis: bluebird
Rated Cap: 16
Re: Betsy
Tango, thanks much for the flckr version of the photo sharing directions. I will be using this when there's something worth taking a picture of. I can't imagine anyone is interested in the inside of a bus where the seats have been removed from their factory location but are still piled inside.
Still have to get my buddy over again so we can get the wheelchair tiedown tracks out. Since the bus had 7 wheelchair spaces and tiedowns for an 8th under one of the seats there are a crapload of those things. I haven't counted but there are definitely at least two for each space, just on the floor. At least the track on the walls didn't rust. Ok so nobody mops the walls unless some kid pukes on it and that almost never happens ABOVE the windows.
On a separate note I'm right with you on the changes flickr has made. Downloading others pics is a lot more difficult than it used to be. Especially if you need to rename the file. I download a lot of truck pics and I prefer to store them by owner and fleet number. I have to rename almost all of them. It was easier when you could see the original version on the screen while doing it and not just the large version while still downloading the big one. It was easier to read the info on the door.
orangepeel91 is offline   Reply With Quote
Old 05-05-2014, 07:46 PM   #33
Re: Betsy
Are you kiddin'! That's just the kind of image that gets this crowd all wet & giggly!
Old 05-09-2014, 10:49 AM   #34
Chassis: bluebird
Rated Cap: 16
Re: Betsy
To quote the not so great Homer Simpson Doh!
Thank you Jatsy for posting the flickr version of the directions and to Nat for pointing out my error.
Old 05-12-2014, 11:19 PM   #35
Chassis: bluebird
Rated Cap: 16
Re: Betsy
Did a little work on the bus today. Very little actually accomplished. Discovered the bane of my buses existence is not the seats or even the wheelchair lift, which still isn't out. No the troublemakers are the wheel chair tiedown points. There are four of them for each wheelchair position. My bus was setup to carry 7 wheelchairs and had tiedown points for an eighth under one of the seats. With four tracks per wheelchair that means there are 32 of these little bas$&*%s in here. The fasteners on top are allen bolts, flush mounted. They are not moving. Snapped 2 allen bits and an allen key. At least the ones that didn't round off anyway.
So I present here in all her glory pulled forward so we could use the wheelchair lift Betsy the bus I couldn't think of a better name for.
IMG_20140512_144226 by orangepeel91us, on Flickr
Turns out the wheelchair lift does in fact work.
IMG_20140512_143537 by orangepeel91us, on Flickr
Now who mentioned pics of buses with seats no longer attached but still in the bus making people feel all squishy inside I have this.
IMG_20140512_133833 by orangepeel91us, on Flickr
And this, let the squishiness begin!!
IMG_20140512_133852 by orangepeel91us, on Flickr
Notice there are NO wheel wells in this bus. A nice little feature if you ask me. I can hang 20" side boxes under the floor and not change the current ground clearance a bit. That said I do intend to go a bit lower between the axles.
The trade off for not having wheel wells is having a crapload of these little sh&$s.
IMG_20140512_163725 by orangepeel91us, on Flickr
Notice that there are 3 bolts in one and 5 bolts in another of these brackets. It alternates like that with all of them. So half have 3 and the other half have 5.
We managed to cut one.
ONE.
So at least when I call the local Snap On guy for super hard drill bits I have something to show him.
The bottom side of these suckers is a nightmare of another type. Not just bolts and nuts like the seats. There are plates to go with them to keep them from pulling through the floor.
The problem with this concept is where half of them are located. To start with there is an emergency wheelchair escape ramp-like the kind on a moving van mounted in back. Behind a panel with 7 rivets holding it on so it could not be pulled out. Once that was removed we discovered the release handle is so rusty it wouldn't move with a sledge, prybar and penetrating oil. We soaked the crap out of it with the oil. Will see what happens in a couple of days. No pics of this.
Now then ofr those of you who figure they don't need to pull up their plywood because the bus is from a rust free state like Texas, you are probably wrong.
See here is the problem, my rubber cracked in several locations. Besides this everywhere there is a hole, like where a bolt holds a seat for example, water will travel down the bolt from inside. Yes I said INSIDE.
I don't know about where you're from, but schools and private bus operators in my area mop the bus floors on a regular basis.
This is what my plywood looks like. Every sheet visible so far has areas that are fine and fit for use and other areas that are absolutely rotten. Just in case you needed more fun, the rotten parts are also soaking wet.
I made this ppic bigger so you can see just how black and disgusting some of that wood has gotten.
IMG_20140512_163645 by orangepeel91us, on Flickr
Old 05-12-2014, 11:59 PM   #36
wash with gasoline's Avatar
Re: Betsy
4in angle grinder with a cutting wheel works the best that i have found.
cut straight down on the allen heads, like you are trying to put a slot in them for a flat blade screwdriver.
cut down deep and angle the grinder side to side to get threw the whole bolt shaft.
it will mix the aluminum and steel a little when you grind, use a big prybar and pop them up
went threw 3 cutting wheels on mine
Had a 8 foot section with 4 of those tie down things running threw it. ...i feel your pain
dont forget a face shield and ear plugs...
Dry with match
wash with gasoline is offline   Reply With Quote
Old 05-13-2014, 07:49 PM   #37
Chassis: bluebird
Rated Cap: 16
Re: Betsy
Only 4 tiedowns? Puhleasee. I've got 32 of them!
Nat thought about your suggestion using the circular saw to cut the ply into sections around the brackets. What took the longest yesterday was digging the ply out from under the bracket. To dig out the area around it basically we just hacked at it with chisels pry bar and very large screw driver. The reason we did it primarily was to confirm the thickness of the ply. Then since we had it dug out anyway it became a debate on how to get rid of the brackets. One of the ideas we tossed around was using the skill saw idea too.
Was also considering the recip saw I think buying a bunch of metal blades for it would be worth trying after the ply is sectioned out. Without trying to chip out the ply under the bracket first. I figure a bunch of blades would be needed just because when I've had to bend one for any length of time they break.
your idea about breaking the ply out from under those @#%^%%%@@ things, that was for dry not rotten plywood wasn't it?
I'm sure some of it is fine somewhere. The one we dug into was rotten as all heck. You can see how black it is in the pic. That ply, using chisels was very difficult to get out from under the bracket. Those bad boys were definitely cinched down tight!
I'll give Bluebird for making the seatbelt mounts for wheelchair passengers secure. I certainly can't fault what they did.
But the school district that owned the bus blocking off the escape ramp is reprehensible on a scale that infuriates me.
Google 7 angels crossing.
It wouldn't have helped in that crash, but ever since I have been more than a little touchy about school bus safety and it really chaps my ass to see an important safety device intentionally disabled.
Old 05-13-2014, 11:30 PM   #38
Re: Betsy
just to clarify...
it was 4x 8ft long strips of those brackets. so 32 feet of that aluminum rail with a ton of those allen heads to kill
I do feel your pain
many ways to skin a cat
Interested to see what works for you, I had the grinder handy and went with it.
At nat, I will have to check out the milwaukee blades. They really have there A game out across there product lines rite now!
Dry with match
Old 05-14-2014, 10:13 AM   #39
Chassis: bluebird
Rated Cap: 16
Re: Betsy
Your tie downs were 8' long! Wow! That must have been a real joy.
Milwaukee blades should work, it's a Milwaukee saw!
But I wasn't going to cut into the aluminum tie downs. My idea was to use the skill saw to cut the plywood around them then remove plywood from floor. This would leave plywood directly under the tie downs but no where else. Then bring in the Milwaukee to cut the remaining plywood and bolts at the same time.
Thoughts?
Have an angle grinder and cut off discs too. My buddy has the Milwaukee recip saw. We used it to cut up a junk suburban once just to see what it could do. I'm sure he'd be okay with me borrowing it-especially if I'm buying blades, it's his angle grinder that's in the bus now.
Will let you know how it worked out. Next bus work day is probably going to be Saturday.
Old 05-14-2014, 09:23 PM   #40
Re: Betsy
I was a die-hard Milwaukee fan & supporter for several decades. But now...every one of their tools are made in China. Screw'em. I'll never buy another of their products again whether they work or not. Just another corporate sell out.
