Old 10-30-2016, 08:23 PM   #121
lookimn good!!! the fire appeasrs to be back! how are you going to keep the coils cool on your A/C unit ? its venting into your garage.. or is the garage always going to be vented enough to not become an issue?
-Christopjer
Old 10-30-2016, 10:23 PM   #122
Coachwork: Corbeil - RAMROD
Chassis: IH 3800 66 Pass
Engine: 7.3 IH IDI NA w AT545 hyd
You're my BOY Blue!!! haha.. Great work dude - love the use of the engine crane. I used one to help lift the back section of my toy hauler off of the deck.
slidewayzm5 is offline   Reply With Quote
Old 01-18-2017, 03:31 PM   #123
ANXIOUSLY AWAITING AN UPDATE!
J33pGirl is offline   Reply With Quote
Old 09-26-2017, 10:16 AM   #124
Just read this whole thread as I am gonna do this (one day) as well and looking for ideas and inspiration. Great build n looks great. Any updates?
2002 E450 Thomas/ U-JOINT 4X4, family hauler
1954 Crown 35 foot RV conversion, guest house
1945? City Bus (unknown manufacture), yard art
1940s 'Binder 7 window, man cave
Oldcarnut is offline   Reply With Quote
Old 04-08-2018, 07:44 PM   #125
Not an update update!
I tried to move the bus backwards to do some work to her, but can't. She hasn't moved in about 5 months, and started up great, but won't build air pressure and the brakes are acting weird. The constant beep that used to go on until the pressure was high enough to be safe is very sporadic and sounds like it wants to beep but has a bad wire or something. Any idea why the pressure won't build AND the brake warning system seems to be on the fritz? I assume it's related.
Tippyman is offline   Reply With Quote
Old 04-12-2018, 01:15 PM   #126
Chassis: 3000RE
Engine: T444E w/ MT643
Rated Cap: 84 pass, 40'
How do you know if the steel was heat treated? Is galvanized steel heat treated? My son wants to learn how to weld and practice on the bus and at first I thought it was a great idea but the more I read about it the less enthused about the idea I become. Looking at my bus- just as some welders themselves point out- the welds are where the rust is!!! The area by my stairs and my stairs are horrible where they were welded.
2martins is offline   Reply With Quote
Old 04-12-2018, 10:09 PM   #127
Year: 1980
Chassis: Chevrolet
Engine: Small Block Chevrolet. May swap out for ?
Sounds like the governor for the air compressor. They are generally mounted on the air compressor and when they fail you may only build minimal air pressure. D2 is a common part number and is easily replaced. Also when welding on an electronic controlled bus be sure to disconnect the batteries as the current through the frame may cause havoc with the Ecu. Awesome build, I have enjoyed seeing what you have accomplished thus far.
Mack
Coamack1 is offline   Reply With Quote
Old 11-16-2018, 05:39 PM   #128
Update sir?
IdahoJOAT is offline   Reply With Quote
Old 12-10-2018, 03:48 PM   #129
Coachwork: Thomas Freightliner
Engine: 5.9 Cummings
Heat treated is hard to cut with a file. Very nice thread can you take a few more pics on
how the ramp/ tailgate lift works. I'm trying to do something similar for my Rock Crawler.
Thanks Robin
COONDOG96 is offline   Reply With Quote
