Old 04-20-2008, 10:07 PM   #41
phillbus914's Avatar
Re: BigBallsBus documented with pictures
oh man that's a bummer. Hopefully it's an easy fix.
I do a lot of bachelor party's with my bus too... Usually I get just enough to cover my fuel, which kinda makes it not worth it.
My Old Bus :(
Old 04-20-2008, 11:28 PM   #42
Year: 1987
Coachwork: blue bird
Chassis: Conventional
Engine: Gas
yea, ours was only going to be MAYBE 30 miles round trip... so that wouldn't have been too bad on gas... but i can't really take them and have the wheel catch on fire... that wouldn't be a very good bachelor party
-Scott
"Sotally Tober"
http://i246.photobucket.com/albums/g...98502_5384.jpg
bigballsbus is offline   Reply With Quote
Old 04-21-2008, 10:39 AM   #43
how bad is it? you sure you guys cant have it fixed by the weekend?
My Old Bus :(
Old 04-21-2008, 11:04 AM   #44
Year: 1987
Engine: Gas
maybe it depends on how soon we can get someone to look at it. we don't know the extent of the problem and we are at the point where we don't wnat to put any more money into the interior of the bus until we know how expensive this is going to be. i mean if its going to be a lot... we would be better off scraping the bus considering we only paid 1100 for it
-Scott
"Sotally Tober"
Old 04-22-2008, 10:22 PM   #45
Year: 1987
Engine: Gas
well we had one of the local schol bus mechanics come out and take a look at the ole bus. he didn't really have any good news. aside from what we already knew, there are plenty of other parts getting ready to bite the dust. we told him we would give him $1000 to make this a reliable bus for tailgating and concerts. (we aren't looking at going on any long hauls) and he said he could probably do that but if we wanted a solid bus it would take more than that. on top of that he is about 2 weeks out...he suggested that we dont drive it past the end of the driveway with the condition of the brakes. so we will hault all expenses until we know the true extent of the problem, but we will continue to finish the flooring and prep for paint on the outside in the meantime. wish us luck
-Scott
"Sotally Tober"
Old 04-23-2008, 11:31 PM   #46
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
big balls i have to do it too take off the wheels and do the wheel cylinders and at the same time i will repack all the bearings and inspect and replace your bus weighs as much as 4 chevy pickups so ya need too stop nicely with piece of mind its the best place to spend the bucks brakes and tires do work good luck timbuk
Old 07-08-2008, 12:51 AM   #47
Year: 1987
Engine: Gas
well 2 months later the bus mechanic shows up to do some work... he got the pads and calipers replaced but they gave him the wrong brake lines... so hopefully they will have them in stock tomorrow if not then we will have to wait... regardless the bus has to be moved tomorrow the place where we left it at when we had the fire was a friends house that happened to be close... he is starting to get mad so it needs to be moved ... its only going to be moved 3 or 4 miles but it is still a risky drive. after this mechanic fixes the brake line he will be fired ... we will be taking it to someone who does mechanical work out of his home and can get it done in a timely manor... so wish us luck!
-Scott
"Sotally Tober"
Old 07-08-2008, 11:16 AM   #48
Year: 1987
Engine: Gas
i don't know what is with brakes... but im glad that soon i will have the piece of mind that it will stop.... i just got a call from the mechanic and he wont have the lines until tomorrow so that means that we are going to have to move it tonight... he said that he is going to bring over a fitting to block that one line and i'll be stopping on three brakes insted of four... this should be fun...
-Scott
"Sotally Tober"
Old 07-08-2008, 11:48 AM   #49
just go easy, 3 wheel brakes should stop as good as 4 wheel brakes on a loaded bus, the steering will probably pull to the side with working brakes.
The only safe and cheap way to do the brakes on a 20 year old hydraulic brake system is to bite the bullit and replace every brakeline both steel and flexable, right from the start. the other option is to replace the leaaking line and bleed the system, then replace the next leaking line and bleed the system, and then..., by the time you are done you have replaced all the lines and wasted 2 gal of brake fluid countless hours of time chasing after parts and learnin to cuss like a sailor.
just some friendly advice from someone who has the t shirt
good luck
Old 07-09-2008, 10:55 PM   #50
Year: 1987
Engine: Gas
got the bus there safely and the new brake line has been replaced. today was a very progressive day... it was hot as hell so we decided on putting the window ac in today we cut a hole just below the window right in the middle of the bus with in an hour it was down to 65 and getting a little chilly we got the flooring laid the the back w/ black and white checkered self-adhesive vinyl tiles and we painted to bus seats red and faced them together we also made a little bench seat/ table tomorrow we are going to work on getting the booth table put up and maybe some speakers!
-Scott
"Sotally Tober"
A few pictures of my Nascar Bus moerules Skoolie Conversion Projects 4 05-03-2010 06:19 PM
my bus pictures? dragonfly112 Conversion General Discussions 0 03-30-2010 01:18 PM
Some pictures to look at. crazycal Everything Else | General Skoolie Discussions 1 03-23-2009 12:49 AM
First pictures on the web staggerlee917 Everything Else | General Skoolie Discussions 3 05-12-2004 10:16 PM
School Bus Pictures Steve Conversion General Discussions 0 01-08-2004 09:09 AM
