07-28-2019, 06:06 PM
Blue bus #7
07-28-2019, 07:22 PM
Engine: T444E 7.3L
Keep us posted with the progress!
07-28-2019, 07:41 PM
Chassis: G30~Chevy cutaway
Engine: 5.7/350 Chevy Vortec
Looks like someone got a start on the conversion, a definite bonus!
Also looks like it motor~vates down the road still. Double bonus!!
Good luck on your conversion update...
07-28-2019, 07:47 PM
Engine: 345 international V-8
Hello fellow Loadstar owner. Mine is a 71. I have had other old loadstar trucks too, and built/modified a few Internationals. Have fun ,good luck and ask questions if you have any problems.
07-28-2019, 08:23 PM
It was mostly full of junk but the previous owner did live in it for a little while. It has been gutted back out though. There is still a black water tank, fresh water tank, a couple propane tanks still mounted underneath! I drove it home probably 40 miles. Drives great, but shakes a bit over 50mph. I need to look over the suspension. Tires were new in 2015 but only have 2000 miles on them. Should be a good start.
07-28-2019, 08:24 PM
Will do. Thanks.
07-29-2019, 12:40 AM
She's gonna be a beaut.
07-29-2019, 07:07 PM
07-29-2019, 08:11 PM
Engine: T444E 7.3L
That rust isn't too bad at all!
07-29-2019, 08:14 PM
It looks worse in person. Ive spent my whole life in AZ so ive never really had to deal with rust. Won't be a problem though.
07-30-2019, 06:16 PM
Started out by pressure washing the floor and taking down the walls. I started to take out the lower wall/ seat rail but it's tucked underneath where the floor meets the wall. It seems to add strength anyways so I'll Leave it and probably just cut off the rail portion at some point.
07-30-2019, 06:22 PM
07-30-2019, 06:41 PM
Neat old Wayne Loadstar!! thats a classic!
I have a 1978 Loadstar SV392. with an AT540..
08-07-2019, 06:16 PM
08-07-2019, 06:51 PM
Engine: T444E 7.3L
Glad to see someone putting some love into that classic.
08-07-2019, 07:42 PM
Originally Posted by yjzuk
Started out by pressure washing the floor and taking down the walls. I started to take out the lower wall/ seat rail but it's tucked underneath where the floor meets the wall. It seems to add strength anyways so I'll Leave it and probably just cut off the rail portion at some point. Attachment 36076
The chair rail is structural and should not be removed, especially with that much floor missing.
08-07-2019, 07:55 PM
Looks all too familiar. We are roughly at the same stage. Just finished wire brushing, Ospho-ing, then priming the floor metal. If your floor is like mine, beware the short but sharp remnants of rusty fasteners as you crawl around the floor on hands and knees. Harbor Freight has meaty knee pads for 3.99. And you get two!
Whats your plan for when the floor prep is done? I've gotta patch some holes with pieces of cieling metal and automotive seam sealer. Basically, wjat did you remember that I didn't?
08-07-2019, 09:01 PM
After patching is finished, I'll do another coat of ospho, seal any small screw holes, and seams, and then paint it. Then for now, I'll do foam insulation and plywood floor ing and throw some beds, a wood stove, camp stove, etc. until hunting season is over.
08-08-2019, 12:15 PM
Got the Dayton wheels trued up pretty good. Should take care of the shakes above 50 mph I think.
08-09-2019, 05:22 PM
Got the passenger side patched up. Attachment 36336
