02-02-2017, 02:26 PM
Year: 2005
Boring Gravy
Here it is. First bus. Purchased in Massachusetts Nov '16.
02-02-2017, 02:32 PM
Year: 2005
Seats
I yanked the seats immediately. Couldn't help myself. The grinder did a great job. But to be honest, the cordless Milwaukee reciprocating saw was WAY more convenient. The sides unbolted easily. I had them all pulled in 2 hours. It took far more time to break them down. I traded the metal to a local guy for use of his truck. I knew I would need access to a truck for garbage and materials. It worked out nicely.
02-02-2017, 03:08 PM
Year: 2005
Ceiling
So I didn't want to remove the interior skin of the bus. I know this is a topic of debate in different circles. This skin is structural. I wanted to compromise it as little as possible. I decided to form ribs, made out of layered 1/8" plywood (Liquid Nails between each piece). I attached them with Tek screws as close to the internal frame of the existing ceiling as I could. I did not screw them directly into the framing, just into the skin. After the glue cured, the ribs supported my weight easily, without budging a bit. I was very happy. I think it took about 45 minutes to make the ribs, and a few hours to position them, glue them, and screw them. I will attach tongue and groove pine to these ribs.
02-02-2017, 04:04 PM
Rated Cap: Your mom +1
looks like a good start
02-03-2017, 08:28 AM
Year: 2005
Lighting
I am obviously going with all LED lighting. I picked up a set of 10 low-profile recessed LED's for something like $25. They are dim-able. I went crazy and decided I wanted switches at both ends of the bus... and that I wanted the light grouped into 3 or 4 independent sections. Not only that... I wanted dimmers at both ends. Those of you who know electrical... not a simple straight-job one switch wiring scheme. It isn't particularly difficult, but no cake-walk. I installed conduit and boxes EVERYWHERE. I want the ability to upgrade/add services later. I got lucky and found a 200 foot roll of non-stock conduit at home depot. It was hidden way behind some stuff, covered in dust. They charged me as if it was a 100 ft roll of smaller-diameter conduit. I can't remember what it cost, but it was a solid find. A little planning(photo). Wiring went in. YEHAAW... Time to build a floor!
02-03-2017, 09:24 AM
Year: 2005
Thanks! I look forward to whatever engagement I get here.
02-03-2017, 12:46 PM
Very cool, looks like a fun project. I will follow your lead when i do my ceiling ribs.
02-03-2017, 01:46 PM
Year: 2005
Subfloor
I used furring strips to make floor joists. I, again, used Tek screws and a ton of glue to attach them to the floor. I did not need to grind the seat mounts all the way down. In the beginning, I just used the reciprocating saw to cut them as close as possible. This was nice. Left the screws in... AKA no holes to fill. The plywood is high enough to clear them. So I carefully cut my insulation. You can see in the pic... NO GAPS. I glued that insulation down with some foam-board adhesive (didn't want squeaking in my floor/anywhere). I used some thermal tape and aluminum tape to seal up every edge. My floor and ceiling have a relatively low R-value, so I do not need a draft on top of it. After that I started tossing down and gluing some OSB sheathing. WONDERFUL. Now I have an insulated subfloor!
02-03-2017, 02:01 PM
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Great start !
Conduit is nice if you decide to add speakers or more lights. LED's are amazing and dimmable is essential, in my book. They have cheap wireless dimmers so you won't even have to get out of your Lazy Boy.
Look at this bad boy:
2.4G 4-Zone Mi-light Wireless RF Dimmable LED Strip Controller DC 12V-24V Dimmer
I can't vouch for quality (so cheap, I buy 2x), but loaded for features.
Ok, I have to go back under my bus and finish fuel lines....
02-03-2017, 03:07 PM
Make sure you do not permanently cover up any access panels in the floor.
They are there for a reason.
Some of them are there to give access in the only way possible. Without that access jobs that would be readily and easily done in an hour could become an all week job of work.
02-03-2017, 03:19 PM
Year: 2005
I didn't see any panels on the floor. Just the rubber floor and the metal runners in the middle. That is interesting, though.
02-03-2017, 03:22 PM
There should be at least one access panel above the top of the fuel tank and an access panel in the floor and in the back seat area to access the engine and transmission.
02-05-2017, 01:52 PM
Hey! I just bought a similar bus. Are you from around MA?
02-05-2017, 03:58 PM
Year: 2005
Pa... but I picked it up in Mass.
02-06-2017, 08:53 AM
Year: 2005
Framing the Driver Wall
Now that the floor is down, I am moving forward with framing the first outside wall. I used furring strips... a ton of them. Ya'll know my pain. I started with 2 double-layers, placed horizontally, the entire length of the bus. One just below the window, and another down by the floor. I filled that space with a few layers of the only insulation I could find rated for external use. I wanted something that could handle a potential beating, being up against the exterior wall. The r-value on this stuff was terrible, though it has the aluminum reflective layer. I put a layer or two alum out, a layer or two alum in. I then started adding vertical studs. Three layers, to be exact. I Then added some horizontal layers to bring it all together. I ended up with a fairly straight wall, without using a level once. I threw in the conduit and wiring for outlets. I then filled the voids with a few layers of R-7.5 foam-board. Every layer of insulation received foil tape on the edges. You can see I chose to close off a few windows entirely, and closed the bottom half of all the rest. I sprayed them with regular enamel spray paint (a soft white). From the outside, It looks like shades are drawn. It came out perfect. All in all, I ended up with around r-20 in the walls. More than enough for me! Note: I did not screw the walls to the edge of the ceiling. I purposefully did this to allow the bus to flex. I also lined up every joint, in framing this is a no-no. I wanted to give the wall a clear place to give and take. At the top of each stud, I shoved a bunch of felt in. This way I wont have to deal with the top squeaking/rubbing against anything. I also didn't attach the wall to the floor in any way. No chance of buckling.
02-06-2017, 11:42 AM
Are you the Shippensburg fellow?
02-06-2017, 11:49 AM
Year: 2005
Nope. This is my only online presence for the bus, at the moment.
02-06-2017, 11:52 AM
Where at in PA then. Oh by the way, there's a newbie in Shippensburg.
02-06-2017, 11:56 AM
Year: 2005
Im in the Eastern PA/Southern NY/Northern Jersey area. The Tri-State.
02-06-2017, 11:57 AM
Further east then. The gf lives between Harrisburg and Lancaster. I guess that's still considered central PA.
