Old 03-09-2012, 07:40 PM   #11
MountainPreacher's Avatar
Chassis: international
Engine: international trbo diesl
Rated Cap: 71
Re: Brian's 1991 International Thomas In Progress...
Originally Posted by chev49
If i didnt have some small dogs, i wouldn't use curtains in my bus. I would put in those window shades from wal mart that are the blinds, and can be pulled up out of the way and the cord tied. I did all my windows in my last bus that way. Even put them behind the windshields, and they worked really great. In my house, the dogs get up on a chair, and stick their heads between the blinds to look out......
As far as curtain rods, i use round rods. I have also used the long spring coiled wire in places in some of my older busses.
You might be able to get some of the stick together velcro rolls either at wal mart or the fabric shop.
As far as sewing... i went and bought a used machine at good will and learned how to sew (which doesnt take much time at all) If you do something like that, buy an really old singer machine that sews good as they have metal gears, and all they can sew is forward and back.. (I now have 5 of those gear drive machines) Sewing is way easier than all the heavy work one has to do..
hope that helps
y.
Yep, I think that's right... Blinds are definately cool. Only one problem... You've got small dogs, I've got small kids. They have ruined the blinds in every place that we've lived that has had blinds. Soooooo for the time being, we'll be much better off with curtains. I really need to learn how to run a sewing machine for sure. That's one of those skills that keep popping up now and then with a need. and I definately like the part about sewing being easier... I spent a bunch of time under the bus (no pun intended) drilling holes up through the frame mounting a home made plywood box to contain the power RV cord today. No thanks to all the metal shavings and dirt that fell on my face and tried to get to my eyes, I now have 1 box mostly built with the opening in the end rather than the outside. Later when I get a great idea for the doors on the exterior I'll add them and box in the opening I have on one end.
MountainPreacher is offline   Reply With Quote
Old 03-10-2012, 09:04 AM   #12
doors... yeah... i must have 20 outside small doors, windows, couple of frig's, furnaces, water heaters, cabinet doors, on and on.. that will probably get scrapped instead of sold. I have scrapped 5 RV's in the last year. Maybe i should run an ad on CL.. maybe not, being the lazy guy that i am...
Old 03-10-2012, 09:27 PM   #13
thommassey's Avatar
Chassis: All American RE
Engine: 3208TA Cat 250HP
Originally Posted by MountainPreacher
any electricians in the group? Does this look ok so far?
Be sure and bring that 12/2 romex you have coming up (bottom of panel) in the K.O. thru some type of romex connector. Also, the more insulation (outside jacket) you peel back off the cable inside your panel, the easier to work with it when it gets crowded in there. Good to see you using 12/2.
Don't forget to double ck all your grounding... Safety first!
TUMBLEWEED (AKA Rufus) build:
viewtopic.php?f=9&t=11121
PICTURES : http://s1338.beta.photobucket.com/user/ ... M-HP/Rufus
thommassey is offline   Reply With Quote
Old 03-10-2012, 09:29 PM   #14
thommassey's Avatar
If you are in OR, I would like to help you get rid of some of that...
Old 03-13-2012, 09:10 PM   #15
Rated Cap: 71
Thank you! I definately went for some of the bigger wire on everything. What a pain that stuff is to work with thought. Very tought trying to get each wire to wrap around the screws on the receptical outlets. Of course the shallow boxes that I'm using didn't help matters any. Note to self, if I ever do this again, buy larger outlet boxes and wire a pigtale to the outlet instead of trying to hook up all 5 wires on a tiny box with that super stiff stufff.
Old 03-19-2012, 01:52 PM   #16
Klein has some great special tools like that.. they are a bit spendy, but are great qualtiy. I have used specialty tools from them since about 1982, when i did hvac work.
Old 03-19-2012, 07:42 PM   #17
pipopak's Avatar
Originally Posted by Pied Typer
Get yourself one of these for bending those ends on the 12-2:
They're made by Klein Tools, the little wire nibbon that comes out of the handle near the shank is for bending the ends of wires into that perfect screw shaped hook... It may be an expensive screwdriver ($6-$9) but once you use one you'll think it was worth every penny!
Looks to me like the wire loop is not properly formed. Has a piece of insulation that will be caught under the screw head. If that is the case you will have a terminal with a possible intermittent contact, and this could be a real P.I.T.A. Don't ask.... IMHO is better to strip a longer piece and then cut off the excess from the "exit" side until you learn to eyeball them.
pipopak is offline   Reply With Quote
Old 03-19-2012, 08:51 PM   #18
Rated Cap: 71
Genius Idea!
Old 03-19-2012, 09:50 PM   #19
usmcbay's Avatar
Coachwork: Thomas MVP
Chassis: Saf-T-Liner ER
Great Thread... keep up the Photos.
Here's my Bus Conversion...
viewtopic.php?f=11&t=12202
usmcbay is offline   Reply With Quote
Old 03-22-2012, 02:25 PM   #20
Rated Cap: 71
Hi folks..... Got a few pieces of furnature put in today...
Just Right Bus: 1991 Ford Thomas School Bus Conversion kellyetross Skoolie Conversion Projects 12 02-15-2017 10:51 AM
The Lunker (or LunkBus) : a 1991 Thomas Conversion lunkbus Skoolie Conversion Projects 2 03-28-2014 07:34 AM
1991 Thomas conversion Will Skoolie Conversion Projects 16 06-24-2013 03:03 PM
1991 Thomas RE Conversion project tfdfyrman Classifieds | Buy, Sell, Swap 3 10-03-2010 07:04 PM
1991 Thomas Built 59 passenger adamb Skoolie Conversion Projects 4 07-08-2004 10:57 PM
