Old 03-22-2012, 06:13 PM   #21
Re: Brian's 1991 International Thomas In Progress...
looking good, have bolted down the furnature ? our are you going to leave them lose?
keep up the good work
Old 03-22-2012, 06:31 PM   #22
browncrown's Avatar
Rated Cap: 79 at Birth
Furniture pics look nice...looks like a comfortable home!
BC
Old 03-22-2012, 09:18 PM   #23
Good job Brian... looks great. Bring that rig on down to the sunny southeast.
Gulfcoast is offline   Reply With Quote
Old 03-23-2012, 11:57 PM   #24
MountainPreacher's Avatar
Chassis: international
Engine: international trbo diesl
Rated Cap: 71
I actually pastored a church in the Baton Rouge area just after Katrina and Rita went through for several years. Miss that warm weather!!
MountainPreacher is offline   Reply With Quote
Old 03-24-2012, 07:48 PM   #25
Rated Cap: 71
Got Bunk beds built and electrical wiring finished up... Stopped at our first RV park to plug in the 50 amp service cord for the first time. All the outlets check out fine. Measured 120 at each outlet and 240 at the panel. That settles it, I'm going to put in an on demand water heater when the time comes.
Here's a few phots of how things are looking on this early voyage.
not much room on the top bunk but the kids love it! In a few years, they will graduate high school and move out... Yay! Then we'll modify!
Old 03-25-2012, 01:53 PM   #26
pipopak's Avatar
Maybe you can glue a pillow on the ceiling above the top bunkers........ or issue sleeping helmets!.
pipopak is offline   Reply With Quote
Old 03-25-2012, 03:31 PM   #27
Accordion's Avatar
Year: 1973
Engine: CAT 1160 V-8 Diesel
Sleeping helmets!!! That is funny.
Old 03-25-2012, 06:53 PM   #28
lornaschinske's Avatar
Rated Cap: 89
You should not have had 240 when plugged into a 50 amp outlet! You hit a power pole that was wired wrong your first time out. No matter what the amperage of the campground power pole, you should only have 120vAC from the post. No matter if you are using a 15 amp, 20 amp, 30 amp or 50 amp receptacle, you will have 120vAC from all of them. I would say a "weekend electrician" rewired your pole. They are lucky someone didn't get their RV burned down. Please call the campground you stayed at and tell them about it. This is a very dangerous situation that needs to be remedied quickly. Now SOME parks have an extra 220 plug (separate box from the normal outlets mentioned above) but you should not have been able to plug into it with a normal 50amp plug.
Fulltime since 2006
Old 03-25-2012, 07:03 PM   #29
Rated Cap: 71
Sorry friend, but I believe that you are mistaken.... I've got the standard 50 amp 4 prong plug. (Looks just like a 4 wire range cord for your oven) I guess I should clarify... when I said "Panel" I do mean at my breaker panel, although I'm sure the right combination of holes on the pole will also give the same reading. Please do click this link... I think this article should clear up the confusion. Have a look! http://www.rv-motorhome-answers.com/AC-Electricity.html
Old 03-25-2012, 07:54 PM   #30
Rated Cap: 89
Sorry, but I have listened to enough campgrounds & electrician bitch because someone had required the panel (made the 50 amp 240 by rewiring or removing the ground) and fired up the next RV (or their own), I still say you should be getting 120vAC period. 240 would have trashed our Class C's 30 amp electric panel. We plugged it into 50 amp more than once.... long term. but you are right and I am wrong. I won't argue with you.
Fulltime since 2006
Just Right Bus: 1991 Ford Thomas School Bus Conversion kellyetross Skoolie Conversion Projects 12 02-15-2017 10:51 AM
The Lunker (or LunkBus) : a 1991 Thomas Conversion lunkbus Skoolie Conversion Projects 2 03-28-2014 07:34 AM
1991 Thomas conversion Will Skoolie Conversion Projects 16 06-24-2013 03:03 PM
1991 Thomas RE Conversion project tfdfyrman Classifieds | Buy, Sell, Swap 3 10-03-2010 07:04 PM
1991 Thomas Built 59 passenger adamb Skoolie Conversion Projects 4 07-08-2004 10:57 PM
