Old 09-23-2015, 12:27 PM   #161
Year: 1981
Coachwork: GM
Chassis: RTSII-04
Engine: 6V92TA (non-DDEC)
Originally Posted by onenationundergoat View Post
Hi Stoltz! Welcome to the bus life! Looks great! What make/model/year/mileage/fuel?
Thanks!!!
Its a 1981 GMC RTSII-04 it only has 12,790 original miles and the 6V92TA Deisel motor motor was rebuilt less than 500 miles ago. It has an Allison V730. I'm going to have to change the gears or something because I top out around 65-66mph. I would like to be able to cruse at 65-70 and not me screaming down the road.
It was a retired Charlotte CATS bus then a Limo company bought it and partially turned the inside into a party bus, rebuilt the engine and parked it at a storage place. then ran out of money and stopped paying for storage and turned the title over.
so the owner of the storage place just wanted the money he was out so I got the bus for a great price!!!!!
Stoltz is offline   Reply With Quote
Old 09-23-2015, 07:20 PM   #162
onenationundergoat's Avatar
Chassis: Thomas
Engine: International Navistar DT360
Rated Cap: 60
Whoa that sound great! Although I'd be pleased as pie to go that fast! We originally got 47 mph, changed the gears and now to top out at 59! Wooooo!
My build thread:http://www.skoolie.net/forums/f11/build-thread-for-haulin-oats-and-goats-11237.html#post113500
A gal, a guy, three cats, two dogs, one rabbit, and one goat, traveling the country together.
onenationundergoat is offline   Reply With Quote
Old 09-27-2015, 06:22 PM   #163
I appreciate your love of animals bit truth be told that isn't a very good life for a goat. I do love your bus!
jean is offline   Reply With Quote
Old 11-27-2015, 07:15 PM   #164
Chassis: Thomas
Rated Cap: 60
Finally, an update! I might not get to post pictures, because our internet situation is tenuous. We'recamping in a casino parking lot near San Diego, CA, and the wifi just barely reaches all the way up here! This is the first time I've had internet on my laptop since we left NC because I can't use it without connecting it to the TV for a monitor.
Anywho...
At the end of September we drove the bus 1500 miles in 48 hours to Drayton, ND to work the sugar beet harvest. The job was pretty grueling, but the campsite with electric water and sewer was included. We didn't get the bus completely finished and it's still pretty much the way it was when we left NC even today. There are holding tanks for the black and grey water, but no internal plumbing from our water tank. So when we have a hookup we just run a potable water hose in through the kitchen window. Perks of having a skoolie: plenty of windows to choose from! For two weeks of work we each made over $2000. Our general on-the-road expenses are less than $1000 a month, even with our long-ranging fuel consumption, so that should last us a few months before needing a new job.
After Drayton we headed south toward warmer climes. Down through SD, Nebraska, Colorado, and Utah to our first long-ish camp in Moab. Moab is probably my favorite place in the country. After two weeks or so in Moab we visited Canyonlands and hopped over to see Zion. Then we went through Valley of Fire State park in Utah on our way to Lake Mead for free ($10 without a Parks pass) camping beside Vegas. Dan got to meet up with one of his buddies who was in Vegas for vacation. After a couple weeks at Lake Mead we set out for Death Valley, and then headed down through Bakersfield and LA to San Diego, where we are now currently. I'd estimate we've been about 8000 miles since September 25.
The bus performed magnificently over both the Appalachians and the Rockies. Uphill is slow (25-35 mph) but with no overheating. Downhill is hairy sometimes because we have to keep from overusing and overheating the brakes. We had to stop three times on the way out of Death Valley. The elevation changes by about 5000 feet in just a couple miles, causing a 9% grade.
Our in-chassis overhaul is holding up just fine, but it seems that the oil control rings on the pistons didn't seat well so we're burning some oil. We noticed the oil pressure dropping and remaining low, and couldn't get any mechanics to even look at it because it's a bus. Concerned that maybe a bearing was messed up, we cut open an oil filter to check for metal fragments. No metal. Phew. Then we checked the oil again. Dan had been checking it at night and didn't realize he had been checking the transmission oil stick right next to it. There was no oil on the stick! It took three gallons to fill it back up. So now it seems we have self-changing oil and will just need to add a gallon every couple thousand miles.
We also have an air leak around the release valves for the air tanks. It leaks out while we're parked in about twenty minutes, but it builds and hold pressure just fine while the engine is on. As soon as we find a mechanic we're having it checked. There's also a coolant leak in the radiator. It seems to only leak when the engine is running and when the reservoir is full. If we let the reservoir remain low (but can still see coolant in the tank) it doesn't seem to leak. As far as we can see the leak is coming out through the radiator fan shroud, but we'll have to take things apart to find the exact spot on the radiator.
The interior is holding up great! Even the one by twos that we used to construct the walls and for the slats in the beds and couch. We'll need a new toilet soon because the old one we bought is starting to crack. It'll be really nice once we get the washer/dryer and sink water hooked up.
The cats are loving the bus. It's a bit small for the dogs if they have to be cooped up without running around for a few days, but as long as we find out of the way campsites they're usually able to run around. The rabbit is indifferent and doesn't seem to know the difference between being here and at home. Rosie is having a grand time. She loves her pen and being around us. Someone said it's not a good life for a goat, but I have to disagree.
It is true that most goats do not do well by themselves. They are herd animals and get depressed without a herd. But I don't think there's even been another situation like this. Rosie may not graze all day with goat buddies, but she's constantly within feet of the rest of us, and we are her herd. She has free feeding of hay and fresh water, and she goes on hikes with us and hangs out when we're outside. She loves the dogs and likes to play with them. They chase her and she chases them. If you could see her in Moab running around and jumping and then coming beside my chair to lie down for a nap next to the dogs in the sun, you'd agree that she has a good life. I have pictures that I'll post when I get a chance!
Old 11-27-2015, 11:11 PM   #165
What a fun read. I'd like to see a pic of how you situated the freezer/fridge.
Jpslickorocks is offline   Reply With Quote
Old 11-27-2015, 11:14 PM   #166
crazycal's Avatar
Blackstone Labs
I'm hungry!
You Gotta Let Me Fly
Old 11-27-2015, 11:24 PM   #167
Great update guys. Keep those cards & letters coming in...from wherever.
Old 11-28-2015, 11:11 PM   #168
LOL ... I literally set fire to the brakes on my 2004 Winnebago Minnie-Winnie 331 coming down the mountain on the way out of Death Valley. It was a bloody miracle we got that thing stopped before we plowed into a street car in San Francisco (9% is serious in an RV ... especially when you're driving it like a car - oh well, that which doesn't kill you makes you slow your ass down).
Mr_Batman777 is offline   Reply With Quote
Old 01-03-2016, 01:59 PM   #169
Chassis: Thomas
Rated Cap: 60
Hey HolyBus and EastCoastCB! We're currently in Gainesville, FL, for a couple weeks visiting Dan's sister and assisting her with her kids while she has a new baby. I noticed on the skoolie map that you're close by. Would you guys be interested in a meetup? I see on the map that you guys are open to stopovers, or maybe you'd like to go on a camping trip to Ocala NF?
Old 01-03-2016, 04:11 PM   #170
Coachwork: IC
Chassis: CE300
Rated Cap: 32
I'm down for sure!
I'm about ten miles from the ocala natl forest.
We have a cow pasture you could stay in if you'd like to stay somewhere for a week or two or three as well. The cows are gone for a few months at a feed lot. We love to meet new folks, especially with buses.
Your goat enjoying the FL weather?!
