01-15-2017, 11:59 PM
Building a wheelchair accessible skoolie
The bus I bought has a wheelchair lift so I can get in and out. I will lay out the interior so it is accessible and easy to use. Stay tuned.
01-19-2017, 08:12 PM
01-19-2017, 08:35 PM
Cool!
Can't wait to see it built. I almost bought a converted 70's greyhound that had been owned by a paraplegic. He had joystick controls custom built and everything, it was really cool.
01-19-2017, 08:57 PM
Outstanding Disbus! And Welcome! --- Ya...this will be a blast to follow. Looks like a pretty sweet platform to build on. Keep the pix coming.
01-19-2017, 10:20 PM
Cool!
Obviously the wheelchair lift is part of the bus by design. Much better than modifying a flimsy RV. I have a set of hand controls for it and I plan to install a transfer seat in the driver's position to make getting in and out of the seat easier. Anyone who uses hand controls should be able to drive the bus.
01-19-2017, 10:28 PM
We all see interiors designed with things along the sides. I am considering building a the kitchen in the middle from floor to roof. Make it 18-24 inches wide so I can get up and down both sides of the bus. At the wheel wells i will build floor to ceiling storage. Bed in the back.
So from back to front will be a bed, bathroom, now we are to the front of the rear wheel well. It is a center isle that is accessible from either side. A sink with the faucet on one side or the other. still developing the idea.
01-19-2017, 10:31 PM
A center island...this will likely be a first...and interesting to follow. Just take & post lots of pix!
01-20-2017, 07:14 AM
great lookin bus!!! nice to have the lift in the front of the bus so it doesnt disrupt your plans for the rear!!
01-21-2017, 02:18 PM
There are a lot of buses out there with the lift in the back side. Not only does it limit design but it is a safely factor getting out of the bus in a hurry for whatever reason.
01-21-2017, 02:28 PM
Looks like I need a new turbo on the motor. I may upgrade to something better. 2003 5.9 Cummins.
01-21-2017, 02:54 PM
I will remove the seat, the frame work behind the seat and the seat mounted to the wheel well and install a transfer seat.
Like this one.
01-21-2017, 05:03 PM
One of those transfer seats would be nice for ANYONE with a FE bus!
01-22-2017, 07:57 PM
I would like some Alcoa wheels if anyone knows where I can get a good price.
01-22-2017, 08:25 PM
Yes, so would I!
01-22-2017, 08:31 PM
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Nice Bus ! I just bought same make, model, year and motor bus !
I'll be following your build.
01-22-2017, 09:18 PM
Year: 1994
If some one needs o get out of the bus quickly and there using a wheel chair ramp. I think its fair to say your not in a hurry or your not going to do it very fast. I wouldn't let this be a build issue for design.
A wheel chair sure adds to the limit space issue. How does it effect your bathroom design? I can see 30 or 36 inch isle to roll down. My grand father was in a chair and he had his bathroom remodeled and it was quite a bit bigger when they were done for him.
01-22-2017, 10:17 PM
I want the bathroom to be big enough that I am not banging into crap all the time. I want to do a center isle to maximize floor space. Knee space is important too. if i can fit my knees under then I can turn around in a 36 inch isle. I will try to draw an example soon. and post it.
02-12-2017, 06:11 PM
I will remove the old suspension seat, and the partition behind the driver's seat, and remove the seat mounted to the wheel well.
Install the transfer seat base i found. The seat base rotates 180 degrees. It can point straight forward for driving, rotate to the right and face straight back. I hope to use the old seat for now. Should bolt right up.
02-12-2017, 06:39 PM
thats a neat idea.. i didnt know they made transfer seats.. i was thinking you had to strap your chair in and drive from that...
02-13-2017, 12:17 AM
I considered driving from my chair but long distance it's just not that comfortable. And a nice captains chair will be a lot better.
