Old 05-15-2008, 12:49 AM   #1
odyssess's Avatar
Engine: T444E 3800
Re: bus on bus ideas
I was wondering that myself!! What have you learned already? I have a guy willing to trade me a vw shell, and I've been seriously considering it, but I have no idea how I would attach it.
http://www.skoolie.net/gallery/v/Skooli ... Green+Bus/
Keep on Keeping on.
odyssess is offline   Reply With Quote
Old 08-07-2008, 11:28 PM   #2
Year: 1979
Engine: International 466
Rated Cap: 42
Any ideas on the best way to raise the VW to the top of the bus?
eatheat is offline   Reply With Quote
Old 08-08-2008, 08:07 AM   #3
skyhook , what options do you have, an overhead crane would be ideal, next would be a forklift, prep the bus, cut the hole in the nroof and brace it for the construction process, gut the vw including all windows and rough trim to fit the bus roof (make cardboard templates of the roof) install some liteweight cross bracing in the vw body to prevent distortion, hopefully you have access to a pieceof equipment that can lift the vw from overhead with straps thru the windows, another option would be to roundup your buddies and muscle the body up, first onto some staging and then onto the bus, make a plan where safety first is the primary goal and then follow it.
Old 08-09-2008, 06:59 PM   #4
Year: 1966
Coachwork: supierior
Chassis: Chevy C60
Engine: Chevy 454
Rated Cap: 10
well a roof off a VW bus without the glass in it should be prety light you could build a big wedge or ramp like 2x6s and greese em up then pull it up with rope ill bet you could do it three guys two to pull one to steer, or all three to pull if steep ramp. We sell car bodys and once there striped and you cut It in half its faily light and can be loaded with two guys. Make sure before you cut the body that weld in bracing do an x and some going across to hold the width, (look at how they chop a top on a hot rod) you could weld it in but do stitch welds to keep warpage and heat down. I thought why not cut the bus with tabs that i could fold out (like little paper boxes in school with glue tabs) that could then be screwed down to the roof or wood frame.
junkyardkid is offline   Reply With Quote
Old 08-10-2008, 12:04 AM   #5
Rent a skip loader or forklift.
Abbott is offline   Reply With Quote
Electrical Ideas Texan Everything Else | General Skoolie Discussions 1 11-21-2014 08:44 AM
Ideas? lornaschinske Everything Else | General Skoolie Discussions 1 10-30-2012 03:47 PM
Many great RV ideas frank-id Everything Else | General Skoolie Discussions 0 12-21-2010 11:32 PM
Some bus paint ideas :) swinada Everything Else | General Skoolie Discussions 1 10-31-2007 10:10 PM
Looking for ideas and plans ???? frank-id Everything Else | General Skoolie Discussions 0 09-11-2006 11:09 PM
