Old 08-26-2015, 03:01 PM   #1
Coachwork: International 3800
Bus-ta Rhymes
Just picked up our our bus on Monday made the drive from Denver to Albuquerque doing 65mph the whole way.
The bus is 1995 international 3800, with a dt466 and a Alison 643. it has 181,XXX miles and runs like a champ. My wife and I are excited to convert it for vacationing with our 3 boys.
I'm trying to upload pics so here goes.
http://s1353.photobucket.com/user/De...er/library/Bus
Vanenver is offline   Reply With Quote
Old 08-26-2015, 03:03 PM   #2
Old 08-26-2015, 03:11 PM   #3
sounds like fun, I helped you on the pictures, your link didn't have the picture extension (name)
Old 08-26-2015, 03:19 PM   #4
VERY sweet bus. An excellent choice for sure! Enjoy and feel free to post LOTS of pics!
Old 09-05-2015, 07:46 AM   #5
Got the seats out with angle grinder and impact driver. Managed to sell a few seats on Craigslist the remains seats will probably be sold as scrap.
Flooring out (rubber on plywood). Found a some bad rust by the wheel wells. I plan to cut out the rust and rivet new sheat metal in. Any other ideas?
I hate removing rivets. I've tried grinding and chiseling with a cold chisel and hammer, both seem to take the same amount of time. Making slow progress on interior panel removal.
We are planning on doing a 20" roof raise so I cut out a section of the hat channel to have it replicated in 36" pieces. I haven't seen any other threads with factory metal supports in the channels. Any suggestions on what to do about inside the hat channel I am having made?
Old 09-05-2015, 08:30 AM   #6
Square tubing or some custom U channel, maybe?
Old 09-06-2015, 12:05 AM   #7
Engine: 190hp 5.9 Cummins
I lapped my new pieces of hat channel on the outside of the original channels, not the inside.
That will cure your issue.
The layers all work out in the end. I overlapped my new skin metal over the rub rail at the bottom of the old windows to force the water to drain over, not under.
Now that I'm done that stage, you can't even tell.
Pics can be found here.
http://www.skoolie.net/forums/f11/th...ime-10138.html
Did all your original hat channels have the U shaped metal inside?
Old 09-14-2015, 09:01 PM   #8
Yes all of the hat channel has the u shaped pieces inside.
Old 09-14-2015, 09:28 PM   #9
So after researching roof raises and see how simple it looks I contacted my father in law who had been welding for the past forty years and works in commercial construction. He was up for he task and we began working on he roof raise this past weekend.
I had the hat channel and and made for a 20" raise.
We used half inch all thread in 6 spots( front, middle, back) to do the raise. Turns out we really only needed it in the front and back. We used jacks to assist with lifting rather than just adjusting the nuts up the all thread.
Old 09-14-2015, 09:34 PM   #10
More work and pictures tomorrow.
Old 09-14-2015, 09:38 PM   #11
Very cool, what welder are yall using?
Old 09-14-2015, 10:08 PM   #12
Chassis: Blue Bird
Engine: ISC 8.3
Mine has a U channel inside the hat channel as well. I was glad I'd had hat channel made to go over the top of the factory stuff when I made this discovery!
I haven't done anything to extend the U channel. My raise is done at the bottom of the wall, rather than in the middle as you have done (and as most do). Hopefully I won't come to regret ignoring the U channel..
Old 09-15-2015, 01:16 AM   #13
I cheer every time I see a roof raise.
Don't just weld the outer seams. Add a few plug welds in the center of the ribs. Plug welds are great on thin metal.
Good job.
