Old 07-25-2014, 07:26 AM   #1
Buster
Well, we have decided to join the family of Skoolies.
We have the rubber flooring up and are working on scraping off all the gum and dirt on the inside. We just received our "BusKote" paint for the roof.
My question is: how do I prepare the roof for the bus kote? Do I need to sand and prime or just sand?
Any suggestions would be most appreciated.
Laurel is offline   Reply With Quote
Old 07-25-2014, 09:22 AM   #2
Docsgsxr's Avatar
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
Re: Buster
First off, welcome to the gang!
Depending on the condition of the roof I would just give it a good bath with some tsp (trisodium phosphate). You can find it at Lowes or HD. This takes off the oils and grease on the surface. Then rinse it well and let dry. Then roll on the buskote.
Now if you have flakey areas make sure to scrape them off where all the loose areas are removed.
Afterward, your paint job should be good to go!
-Doc
My build thread - viewtopic.php?f=9&t=467197
Old 07-25-2014, 09:37 AM   #3
Re: Buster
Thanks Doc!
We will head over there tonight and start on that.
We were fortunate to get a bus that is structurally sound and mechanically sound with only 76,000 miles on it. It also had all the seats removed already! Yah! So the job of getting the rubber flooring up was not so bad.
Any ideas on how to get all the remaining glue off the metal floor?
We would like to put down some rustolium to protect it. Are there other suggestions?
Old 07-25-2014, 09:45 AM   #4
LandLubber's Avatar
Chassis: All American RE
Re: Buster
Welcome to the site.
We washed the roof with automotive style sponges and soap. We got two palm sanders and paper from Wal Mart for around $50. We sanded the roof, then cleaned it with vinegar. Primed it with self etching primer (from hytech as well) and then applied the bus kote. We are sealing it up next weekend with the clear sealer. good luck with your roof.
Roll Tide
LandLubber is offline   Reply With Quote
Old 07-25-2014, 06:21 PM   #5
browncrown's Avatar
Rated Cap: 79 at Birth
Re: Buster
I have not done the BusKote paint, but Welcome to Skoolie Family and have a great time on your project
BC
Old 07-25-2014, 08:56 PM   #6
gmarvel's Avatar
Engine: DD6-71T
Re: Buster
Welcome to the madness that is Skoolie World!!! You will have great times and frustrating times often all at once. However, you will have memories that last a lifetime and a conversion that will be one of the best recreational vehicles on the road.
______________________
Greg and Donna Marvel
Danville, California
http://www.transtraks.com
gmarvel is offline   Reply With Quote
Old 07-25-2014, 09:16 PM   #7
big_bertha's Avatar
Chassis: TC/2000
Engine: Cummins 6CT8.3
Rated Cap: 76
Re: Buster
Welcome!
It's likely that your floor is galvanized steel. Oil-based paints like Rustoleum react with the zinc coating and have problems adhering. The safe thing to do, after you've done any grinding/sanding/wire-wheeling and washed it with tsp/acetone/soap+water, is use a water-based primer like Kilz 2.
Having said that, I put Rustoleum directly on the galvanized steel after heavy grinding and it seemed to adhere just fine. We haven't seen long-term results, so it may be a problem in the future. Not that we'd ever know.
As for the glue, acetone didn't work for me. I ended up using a wire wheel, which didn't remove the glue, just moved it (violently) to the walls and roof. After seeing those results we decided to wash the glue with soap and water and paint over it. By that point though, there wasn't much glue left. The wheel wells were the big glue areas, and it DID help going over them with the wire wheel.
YouTube | Facebook
big_bertha is offline   Reply With Quote
Old 07-25-2014, 10:20 PM   #8
Chassis: Genesis
Re: Buster
The heavy grinding and rust probably removed bulk of the zinc. The 'proper' way to paint galvanized metal is to etch it first. There are etching primers, or you can just give it a spray down with Ospho.
I washed down the floor, TSP'ed the floor to remove all the goop and grease, gave it another hose out. After it dried, I used a pump sprayer to spray down the entire floor with Ospho. Once that dried, I ended up having to fine-wire-wheel the zinc oxide. Don't breathe that stuff. I then put a coat of Rustoleum Pro primer and matching top coat. Worked very well.
Timelord is offline   Reply With Quote
Old 07-26-2014, 08:53 PM   #9
Re: Buster
Wow! Long day today. I spent most of it on my knees scraping Adhesive off the floor. I am about half way done.
The heatgun idea worked great for the stickers and decals. They came right off and with some goo gone, I was able to get the adhesive gunk off. Thanks for all the great advise on this site. It helps a whole lot. All the boys in the house took a camping trip so I think we will tackle the roof when they get back.
Old 07-27-2014, 10:18 PM   #10
big_bertha's Avatar
Chassis: TC/2000
Rated Cap: 76
Re: Buster
The majority of my decals are reflectors, and they are everywhere. There is a brittle yellow outer layer stuck on a gummy white adhesive layer. Is this what yours were like?
YouTube | Facebook
Buster ezbme Skoolie Conversion Projects 138 12-26-2009 08:44 PM
May I present Buster The skoolie Buster Skoolie Conversion Projects 5 10-16-2007 12:06 PM
