Old 05-26-2018, 11:29 AM   #41
yellowxj's Avatar
All cleaned out and ready to start the marking and cutting for the raise. Looking for the right material for the hat channels. Looks like 1 3/16" is what I'm looking for. I might use some 1" x 1" square and some 3/16" angle?Click image for larger version
yellowxj is offline   Reply With Quote
Old 05-26-2018, 11:41 AM   #42
jjhwick119's Avatar
Engine: Dt466e
Rated Cap: 71
Looking good man! That's exactly how I did my side walls too soo you won't have any problems. I copied many others. Looking forward to watching your progress
https://www.skoolie.net/forums/f11/n...tml#post256987
My build thread - Started 3.2.18
jjhwick119 is offline   Reply With Quote
Old 05-26-2018, 11:47 AM   #43
Originally Posted by yellowxj View Post
All cleaned out and ready to start the marking and cutting for the raise. Looking for the right material for the hat channels. Looks like 1 3/16" is what I'm looking for. I might use some 1" x 1" square and some 3/16" angle?Attachment 22582
Asetechrail and I tried something similar. We tried welding ("we" means Kent did the work while I watched) 3/16" flat onto 1" square tube to achieve 1-3/16" to fit the hat channel.
Welding and grinding turned out to be very time consuming. We needed 26 pieces. They were taking about 40 minutes each.
We decided to go a different route and had a local shop bend up U channels from 1/8" material. That worked out much better for us.
Pictures: http://www.skoolie.net/forums/f11/pnw_steves-2002-bluebird-a3re-21182-13.html
Old 05-26-2018, 11:48 AM   #44
You gonna proceed this weekend or wait for the tropical depression to pass?
Supposed to be POURING rain tomorrow.
I could see about getting you some channel if you want. But it may take a while.
Old 05-26-2018, 11:55 AM   #45
Yukon Cornelius's Avatar
Moving right along. Today I'll tackle the back wall. Then I will start figuring out my final cut lines. The way I'm cutting the bus I do not have to take all the windows out. But should I take them all out?
If it were me I would, the windows aren't very time consuming to remove, on re-install I would have piece of mind that fresh sealant has been used, would hate to pop a window or twist a frame and need to track down a new window (not likely a big problem in civilization) but a cost I wouldn't be happy about if I could have avoided it.
That's my view anyways
Yukon
Handyman and Shenaniganizer
https://www.skoolie.net/forums/f11/97...ion-22324.html
Yukon Cornelius is offline   Reply With Quote
Old 05-26-2018, 12:33 PM   #46
Engine: dt466e
Originally Posted by Thomas1985 View Post
I would still take the window out and look at it. I bet you find a couple screws. You don't have to pry those pieces apart.
Forgot to mention that I had to take the windows out, the flaps were a part of them. I was advised to use a spot weld cutter but decided to use a drill bit the diameter of the welds to get the panels loose. Did one side like that and broke a few bits. Might cop a few spot weld cutters for the other side to see how it goes
adic27 is offline   Reply With Quote
Old 05-27-2018, 01:21 PM   #47
yellowxj's Avatar
I guess if you could casually ask how long channel would take that would be pretty cool. And the cost of course.
Old 05-27-2018, 01:21 PM   #48
yellowxj's Avatar
Thanks. I probably will.
Old 05-27-2018, 01:22 PM   #49
yellowxj's Avatar
I got a fancy blanket from Harbor Freight to keep Sparks from hitting my windshield or Dash. Going to cut some of the supporting metal out of the roof on this rainy day.Click image for larger version
Old 05-27-2018, 01:29 PM   #50
Cost is free or cheap, if my stepdad can find the time to get em made.
Its worth a shot, I'll ask him.
How wide are the ribs on the ID? 1 3/16" ?
I think I had my Amtran rib extensions made in 1 1/8".
I'll check the size of the ones I've already got. May get lucky!
Old 05-27-2018, 04:12 PM   #51
yellowxj's Avatar
Looks like 1 1/8th? IDClick image for larger version
ID:	22621Click image for larger version
Old 05-27-2018, 11:04 PM   #52
Looks like 1 1/8th? IDAttachment 22621Attachment 22622
I think you may be in luck.
I grabbed a rib extension and put it in my van. I just gotta find a way to get it over to yall!
Old 05-29-2018, 08:06 PM   #53
yellowxj's Avatar
Trying to see if my interior roof sheet metal is sufficient thickness for skinning the sides after the roof raise. Seems Google can't find it for me. They would be ideal because they're the right height already and the holes are already drilled along the edges. I suppose if all else fails I can get the micrometer out and measure.
Old 05-29-2018, 08:49 PM   #54
It's basically just skin, some have used it. As long as you don't run into stuff you won't puncture it.
Old 05-29-2018, 08:50 PM   #55
Speaking of rib extensions it reminded me of the search I just did for rub rail end caps. I'll need some for my double door mod. The caps for a Genesis Amtran new are $88ea. I'll have to find me some used ones.
Old 05-29-2018, 11:25 PM   #56
plfking's Avatar
Rated Cap: 34
I think they'd be fine.....mine are the same thickness as my skirts. I used some of mine to skin over my old doorway, and will use more to make storage compartment doors.
And all the pre-drilled holes are awesome.
Don
The Busted Flush
Old 06-13-2018, 08:23 PM   #57
yellowxj's Avatar
Cant believe the difference in planning a bus 2.5 times bigger than my short bus. Just agony. I really want to just lift it so I can visualize the space better but I might be moving the rear door. What a pain. Night after night I've searching internet and watching YouTube videos for inspiration. I should be able to order my rib extensions from Colorado with my next paycheck.
Old 06-13-2018, 08:26 PM   #58
Why order them from so far away?
I've got a sample for you to try.
Old 06-14-2018, 06:38 AM   #59
yellowxj's Avatar
This company Fab Lab Customs was recommended. They've been doing parts for bus lifts. Sure seems like an easy way to go for u channel with the flares. Less fab work for me.Click image for larger version
ID:	23254Click image for larger version
Old 06-14-2018, 02:17 PM   #60
This company Fab Lab Customs was recommended. They've been doing parts for bus lifts. Sure seems like an easy way to go for u channel with the flares. Less fab work for me.Attachment 23254Attachment 23255
LOL
well if you'd rather pay a stranger, be my guest. I was trying to hook you up for free with something that fits perfectly.
Why do you need the flares? How long are the extensions he's selling?
Are you gonna forget the 6 degree slant and just see what happens?
I've also got 4x10's of cold rolled 18ga for $65 each if you want any.
JUST TRYING TO HELP!
