04-28-2018, 12:34 PM
Chance the bus
04-28-2018, 03:03 PM
The scraper blade in the Sawzall works great to pull up the rubber floor. But broke with 6ft left. Used a pick to clean out the screw heads before using the rechargable drill. So only had to cut a half dozen screws
04-28-2018, 09:31 PM
Year: 98
Congrats on chance. The rest is all details. Are you going to do a similar road trip with this one?
Later j
05-01-2018, 09:04 AM
Planning on Fla to Canada road trip in 2 years.
Got more taken apart Sunday.
Checking out the uchannel in the roof raise area. Planning on raising the 7 back rows of windows 18"-20" but leaving the first 3 windows low.
Is the white material insulation or just sound deadening?
05-01-2018, 09:07 AM
I'd love to lend a hand if you want any free help. Just hit me up.
raising a Thomas is tricky for sure. That bend at the beltline sure complicates things!
05-01-2018, 09:48 AM
It'd be awesome to see you again!
We plan to mimic this roof raise. In some resects I think mine will be easier.
05-01-2018, 03:07 PM
Originally Posted by yellowxj
It'd be awesome to see you again!We plan to mimic this roof raise. In some resects I think mine will be easier. Attachment 21454
That's not a Thomas. Isn't yours a Thomas? If so you'll have to get creative due to the 6 degree slant.
When yall gonna start cutting? Can I watch?
05-01-2018, 03:32 PM
Coachwork: Corbeil
Engine: Ford PowerStroke Diesel 6.0
Rated Cap: GVWR 11,500
It looks like they're planning to bypass that by raising after the first few rows of windows, unless I misunderstood.
05-01-2018, 04:01 PM
Uh oh. Weres the slant? Whats a belt line? I'm getting my angle finder out when i get home. I'll mark off the cut lines i'm thinking about for some feedback. Yes ours is a thomas. Once i get the title i'll be spending more time on it.
05-01-2018, 04:02 PM
Right.
But if you raise one part on a Thomas you'd need to account for the 6 degree bend at the window line.
I'm not nay-saying. if anyone can do it Travis can.
See the bend inward ^? if you raise you have to do it below the bend, but a partial raise will make for lots of finesse to make it look right or work at all.
I'm REALLY interested to see this!!!!
GO TRAV AND MICHELLE!!!!
So- Can I watch? I'll even help if you like...
05-01-2018, 04:06 PM
Absolutely welcome to help. We'll figure it out. And got the pool 20' away. I plan on working and swimming a lot this summer.
05-01-2018, 04:09 PM
Are you gonna use fiberglass or steel to fill the gaps in the transition?
And cool, just let me know when!!! If you need any tools or supplies let me know, too.
I can get 18ga (or any other) steel for wholesale cost.
05-01-2018, 04:49 PM
Coachwork: Corbeil
Right.
I understand now. I was thinking of the bump raise that some of the buses have right after the driver and assumed he was going to raise even higher after that point.
05-01-2018, 06:22 PM
My current fantasy cut line. The transition would be between the front verticle lines.
05-01-2018, 07:42 PM
Seems like it would be easier to raise ALL of it. What's the plan for the angle difference in that vertical cut line?
05-01-2018, 07:57 PM
Engine: Dt466e
Rated Cap: 71
It would probably be easier to just lift the entire thing below the windows, and then skin it and put the windows where you want. I'm assuming that's why you want to cut it like this, to keep the windows lower up front? Can't think of any other reason
Maybe your just doing something crazy with the front roof area I can't think of
05-01-2018, 08:02 PM
I just wanted to keep the front windows low for when we're cruising so everyone can see. I haven't thought about lowering the windows. Now I've got some thinking to do.
05-01-2018, 08:28 PM
Engine: Dt466e
Rated Cap: 71
I've only read some posts, ECCB is the man to talk to about roof raises. I've just recently noticed the effects of the Thomas window angle while working on framing my interior, and I could imagine it's a bit more difficult to deal with that angle when it's the bus body, and you'd be mating that angled front to a squared back, and higher angle up top
05-01-2018, 08:29 PM
Chassis: Saf-T-Liner MVP ER
If you lift the windows 6 to 9" it makes it easier to install standard height cabinetry and still have the full window to look through.
05-02-2018, 06:50 AM
We would like our counter tops high. I'm a little over 6' and the wife is close. I think our favorite work space in the house is 39". Was planning on 18"-24" lift.
