Old 04-20-2010, 07:05 PM   #111
Coachwork: THOMAS
Chassis: SAFE-T-LINER
Engine: CAT 3116
Rated Cap: 83
Re: CHANGED AGAIN! THIS WILL BE IT!!
Monday I got the hot water heater install finished.
BUSBOZO is offline   Reply With Quote
Old 04-20-2010, 07:10 PM   #112
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Started the cutout for the exterior furnace door. I ran into a bit of a problem with the ribbed exterior skin. So I am going to have to straighten the raised areas so the door will sit flush (hopefully) to the exterior skin.
Old 04-25-2010, 06:49 PM   #113
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Thanks Smitty. I'll keep that in mind!
Old 04-30-2010, 07:29 PM   #114
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Kitchen counter framed up!! (makes a good workbench)
Also recieved the transfer switch, inverter remote, stove distribution box and furnace access door this week!
Old 04-30-2010, 07:35 PM   #115
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
The distribution panel is not a surface mount, so I had to build a frame for it so it sits flush in the frame. The 2x4's worked great! I still need to mount it to the wall.
Old 05-03-2010, 03:15 PM   #116
Coachwork: Ward Genesis
Engine: DT466/MT643
Is that some sort of funky mini-oven cooktop or just a weird angle on the photo?
Jarlaxle
Old 05-03-2010, 08:36 PM   #117
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Thats a SMEV Italian oven/cooktop from Aery corp on ebay. It has a smooth glass top that opens to expose the burners underneath.
Old 05-03-2010, 08:46 PM   #118
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Well, its time to start thinking about mounting the LP tanks and get some lines run. This is a picture of the LP setup I am going to use.
These came off my concession trailer. I don't need them because I run all electric. So I think they should be perfect for the SKOOLIE!
I believe it is a typical RV type setup. It has the valve, and complete assembly. I think all I need to do is make a frame, platform and hang them under the bus.
What do you think?
Old 05-03-2010, 08:58 PM   #119
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Engine: Ford 370 Propane
Rated Cap: 48
I have been thinking about this stage of the conversion as well. I need to be able to mount a couple 20lb tanks under my bus as backups and also so I can pull one out and run my generator further away from the bus. I have found that a 20lb tank is taller than the space I have under my bus. I see you have 30lb tanks which may make the issue even harder. Does anyone with propane experience know if you can store a tank on its side? I seem to think you shouldn't due to the way the pressure relief valve is set up, but I am not a 'Hank Hill' so I am not an expert on propane and propane accessories.
Old 05-03-2010, 09:02 PM   #120
bunedoggle's Avatar
Chassis: Safe-T-Liner MVP
Engine: CAT3116
Hey man,
What are the details on that stove? Looks sweet. It's glass top propane?
Source, price, model?
1. Always use the right tool for the job.
2. A hammer is the right tool for any job.
3. Anything can be used as a hammer.
bunedoggle is offline   Reply With Quote
