Old 03-08-2011, 07:33 PM   #241
Coachwork: THOMAS
Chassis: SAFE-T-LINER
Engine: CAT 3116
Rated Cap: 83
Re: CHANGED AGAIN! THIS WILL BE IT!!
Yes, that grab handle is the same on both ends. Chris, thats a good one! Thanks for the compliments!
BUSBOZO is offline   Reply With Quote
Old 03-09-2011, 11:05 AM   #242
Diesel Dan's Avatar
Engine: DT466/AT545
Originally Posted by BUSBOZO
Thanks for the suggestions guys! While I am at it, I'll return the favor with some more progress pics!!
The interior looks great! Very impressed and inspired by your work.
SOOOOOOOOOO.... WHAT DO YOU THINK ABOUT THIS IDEA????
I think you'll look like the skoolie version of Peter Fonda in "Easy Rider" But you'll have to get a baseball cap with an american flag on it, and an american flag jacket to match!
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 03-09-2011, 08:19 PM   #243
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
HA!! HA!! Yeah I know DD.
Old 06-01-2011, 08:41 PM   #244
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Sorry folks for the long delay. Guess I've been kinda lazy keeping the web site updated. Since the last posting I have switched my efforts to the exterior to prep and get ready for paint.
Lots of hours prepping, sanding etc.. etc... Unfortunately, I had to get a new phone and lost a few pictures. Here is a few update pics!
Stripped everything and masked.
So I started with the roof. And I decided I would roll it and brush it. At this point, I was still on the fence about whether or not I was going to roll and brush the entire bus or spray it.
I don't think this small section of white is going to help keep the bus cool. But I didn't want the entire roof white.
Some of came out ok. But after the roof, I decided I was going to just spray the rest of the bus. After rolling the passenger side of the roof, I noticed it came out pretty lousy. So I had to wait for it to dry, sand it, and prep that for another coat. (This time with the spray gun).
Ahhhhhh... MUCH BETTER!!
This area is where the stripes will be. So I didn't need to paint this area blue.
Next update will be the stripes!!
Old 06-01-2011, 08:57 PM   #245
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Forgot to mention what I used for paint.
So automotive paint is around $85 a gallon. I set out to find the colors I needed in either rustoleum or XO rust at $30 a gallon. Lowes or Home Depot didn't have what I needed so I went to a very well known local hardware store that is small BUT CARRIES EVERYTHING. And I found the colors I needed in the XO Rust brand. (red,white, blue).
So now that I have the colors, I wanted to make the finish more durable. So I picked up some enamel hardner and reducer from the local auto body supply. And basically used the mix ratio of the automotive style paint. It ended up working pretty good. I needed a little more reducer with each batch because the XO Rust paint is thicker than auto paint.
Unfortunately the gun would get clogged up and not lay down the paint heavy enough and I ended up with some very cloudy areas. Oh well. Its a bus. Not a show car.
Dr LuLu..
Rope lighting- AC. lights up EVERYTHING in the area. I have more light than I need! DC rope lighting is more expensive.
I left the original speakers in the ceiling and bought 2 sets of 6X9's that are mounted on the front bulkhead and rear walls. MUCH BETTER. The original speakers are wired in series. I decided not to waste my time with that mess.
Hope this helps!
Dan
Old 06-02-2011, 06:21 AM   #246
Seeria's Avatar
Great color. Show us more when complete please
Old 06-02-2011, 08:47 AM   #247
browncrown's Avatar
Rated Cap: 79 at Birth
It's looking great!
BC
Old 06-02-2011, 10:06 AM   #248
GreyEagle's Avatar
Just spent the last 2 hours reading up on your bus build. "WOW" Very impressive work.
Good job......
GreyEagle
Roll - On...
GreyEagle is offline   Reply With Quote
Old 06-05-2011, 08:14 PM   #249
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Thanks guys!
Old 06-22-2011, 08:47 PM   #250
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
MORE PROGRESS ON THE PAINT!
The stripes were somewhat time consuming to lay out and mask. Especially considering there is not much flat area on a school bus.
After the stripes were painted, I started on the stars. These are vinyl stickers I had a local sign shop make up. I decided to go with a few different sizes to give it kind of a 3d look. But that didn't turn out so well.
Not enough coverage in my opinion. So I took off the smaller ones and went with all 6".
I wanted to keep the stop arm. But I wasn't going to leave it the traditional "STOP". So I found this image online and emailed it to my sign guy and he printed it out on reflective vinyl. I sanded the original surface, then painted it white, then applied the sticker.
I then decided it needed an outline. So I taped off the edges and painted it.
Replaced all the clearance lamps.
I also decided to use the dual square optional style mirrors instead of the round convex and square concave mirrors. I got these from a bus in the local junkyard.
Old
New
Oh.. Here is the sign put back together and functioning.
I also scored this THOMAS emblem off the same bus in the junkyard. The red was a bit faded so I decided to freshen it up a bit.
First I taped over all the raised letters. Then I hand cut all around each letter. Then painted.
GETTING CLOSE TO BEING DONE!!
