04-11-2010, 08:07 PM
#101
Coachwork: THOMAS
Chassis: SAFE-T-LINER
Engine: CAT 3116
Rated Cap: 83
Re: CHANGED AGAIN! THIS WILL BE IT!!
This is the falls near my house after the crazy rainfall in March. Crazy huh?!!
04-11-2010, 09:11 PM
#102
I've seen much worse. Water up to the bottom of the second story of a canal lock house, dropping into the lock from over the top bar of the railing by the sidewalk. Any way you look at it, Mother Nature is impressive.
BTW, it took me about 5 minutes to spot the mill on Google Earth, working outward from the home of the Spinners. The photo must have been taken in or by the gazebo. Ain't technology wunnerful?
04-11-2010, 09:39 PM
#103
Year: 1974
Coachwork: CARPENTER
Chassis: GMC-6000
Engine: 454 CHEVY
yep the flood of 96 here in walla walla wa. it was the 30 year flood.
hd d44 4.56, eaton ff 4.56
04-12-2010, 08:55 PM
#104
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
WOW REDBEAR, YOU ARE GOOD!! YUP, right near the gazebo. I was standing at the railing. Damn, one would have thought you lived around here
Yeah, I really enjoy rivers and streams when they are flowing high.
04-12-2010, 11:00 PM
#105
I grew up less than 45 miles away as the crow flies. Your area wasn't my stomping grounds, but we did cross mill country in northeast Mass on Route 110 headed for vacations up until I-495 was completed. I moved west, but my sister moved Down East, so I sail through on one interstate or another every couple of years.
04-13-2010, 08:18 PM
#106
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
GOOD ONE SMITTY!!
Redbear, if you are ever in the Lowell Mass area. Let me know!!
04-16-2010, 07:15 AM
#107
Year: 1974
Chassis: GMC-6000
Engine: 454 CHEVY
so the point of these are?
04-16-2010, 07:16 AM
#108
Thanks. I'm usually blowing through on a schedule, but will keep it in mind.
04-18-2010, 09:22 PM
#109
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
CAMO, those are one way valves. One valve is on the city water line and the other is on the tank water. So when hooked up to city water, the water won't back up into the tank.
If I am using water from the tank, it won't back up into the city water inlet.
04-19-2010, 09:30 AM
#110
Year: 1974
Chassis: GMC-6000
Engine: 454 CHEVY
oh ok. i see, well i have ball valves in my system to do that.
but thanks.
04-20-2010, 07:05 PM
#111
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Monday I got the hot water heater install finished.
04-20-2010, 07:10 PM
#112
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Started the cutout for the exterior furnace door. I ran into a bit of a problem with the ribbed exterior skin. So I am going to have to straighten the raised areas so the door will sit flush (hopefully) to the exterior skin.
04-25-2010, 06:49 PM
#113
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Thanks Smitty. I'll keep that in mind!
04-30-2010, 07:29 PM
#114
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Kitchen counter framed up!! (makes a good workbench)
Also recieved the transfer switch, inverter remote, stove distribution box and furnace access door this week!
04-30-2010, 07:35 PM
#115
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
The distribution panel is not a surface mount, so I had to build a frame for it so it sits flush in the frame. The 2x4's worked great! I still need to mount it to the wall.
05-03-2010, 03:15 PM
#116
Coachwork: Ward Genesis
Engine: DT466/MT643
Is that some sort of funky mini-oven cooktop or just a weird angle on the photo?
Jarlaxle
05-03-2010, 08:36 PM
#117
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Thats a SMEV Italian oven/cooktop from Aery corp on ebay. It has a smooth glass top that opens to expose the burners underneath.
05-03-2010, 08:46 PM
#118
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Well, its time to start thinking about mounting the LP tanks and get some lines run. This is a picture of the LP setup I am going to use.
These came off my concession trailer. I don't need them because I run all electric. So I think they should be perfect for the SKOOLIE!
I believe it is a typical RV type setup. It has the valve, and complete assembly. I think all I need to do is make a frame, platform and hang them under the bus.
What do you think?
05-03-2010, 08:58 PM
#119
Year: 1981
Chassis: Ford B-600
Engine: Ford 370 Propane
Rated Cap: 48
I have been thinking about this stage of the conversion as well. I need to be able to mount a couple 20lb tanks under my bus as backups and also so I can pull one out and run my generator further away from the bus. I have found that a 20lb tank is taller than the space I have under my bus. I see you have 30lb tanks which may make the issue even harder. Does anyone with propane experience know if you can store a tank on its side? I seem to think you shouldn't due to the way the pressure relief valve is set up, but I am not a 'Hank Hill' so I am not an expert on propane and propane accessories.
05-03-2010, 09:02 PM
#120
Chassis: Safe-T-Liner MVP
Engine: CAT3116
Hey man,
What are the details on that stove? Looks sweet. It's glass top propane?
Source, price, model?
1. Always use the right tool for the job.
2. A hammer is the right tool for any job.
3. Anything can be used as a hammer.
