Old 01-09-2010, 01:11 PM   #61
busdriver_phil's Avatar
Coachwork: AmTran RE
Re: CHANGED AGAIN! THIS WILL BE IT!!
For the emergency door interlock:
I have a book of wiring diagrams for older Thomas conventional buses (which are wired similar to other Thomas buses). In 1995 they changed a lot of wiring stuff, but the pre-95 circuit diagram gives me an idea of how your switches were set up. My scanner isn't working right now, so I'll try to explain how it's laid out. Wiring colors may be different (your black and white wires should be yellow and dark blue according to my book, so it may vary by different models).
There are 2 switches at each emergency door with a Vandalock. One is just for the buzzer when the door handle is opened, that should have two wires. The other is for the buzzer and starter interlock when the door is locked, which should be the 4 wire one. It's a double-pole single-throw switch. One pole is normally open, the other is normally closed.
In addition, buses with a locking compartment over the driver's window for safety equipment storage may be equipped with an interlock. This will use a 4-terminal DPST switch just like the Vandalocks.
The buzzer circuit uses ground-side switching. There is power to the buzzer whenever the key is on. When any door is either opened or locked, the the respective switch grounds the wire from the buzzer. (The buzzer wire is connected to the normally-open SP door switch and to the normally-open side of the DP lock switch.)
The interlock is also wired with ground-side switching. The interlock uses an extra starter relay, fed by the ignition. The ground wire for this passes through each interlock switch, on the normally-closed pole of the double-pole switch. When each door is unlocked, the relay is grounded. When any door is locked, the ground circuit is broken.
Now that I've explained how it works, there are a few ways to disable it. If you can locate the interlock relay by tracing the starter circuit wires, you can simply connect the two wires (in the diagram they're shown as black wires). If it's easier to do at the side door (or rear door - make sure it's the closest one to the front of the bus), the diagram suggests that the interlock circuit is a yellow wire connected to the furthest terminals from the plunger. (On the overhead locking compartment, it will be connected to the terminals closest to the plunger.) Either connect these two wires, or ground the one coming from the switch cabinet (will be hot when the key is turned to start). I would suggest either bypassing the relay, or tracing the interlock wire and grounding it behind the switch panel, so you won't have a hot wire running the length of the bus.
The buzzer wire is supposedly dark blue, connected to the other terminals. One side will be hot when the key is on or in accessory, and grounding it will sound the buzzer. If you remove the buzzer or its fuse, you'll just have a dead wire running the length of the bus. (If you have the optional emergency door pilot light, it's wired in parallel with the buzzer - either disconnect the light with the buzzer or remove the fuse to kill the circuit). This circuit also runs to other non-locking exits such as pushout windows and roof hatches, which ground it through SP switches in the same way.
On newer buses (95 and newer according to my book), they used a different Vandalock design that would lock the handle by inserting a pin. To line it up, you would have to slightly open the handle, just enough to sound the buzzer but not open the door. These use only one switch, wired the same as the lock switch on older buses - double-pole, with the normally-open side for the buzzer ground and the normally-closed side for the starter relay ground. You should be able to disable it the same way. The diagram suggests newer models use a standard 5-prong relay for the interlock, and if you just connect the wires from the 30 and 87 prongs it should bypass the interlock circuit. Either that, or ground the yellow wire (circuit #32) from terminal 86, or at the door if you prefer.
Sorry for the long post, but hopefully this will help some future Thomas converters.
The conversion of Miss Euphegenia, a 1999 AmTran RE: http://www.skoolie.net/forum/viewtopic.php?f=9&t=5704
Old 01-10-2010, 08:43 AM   #62
Seeria's Avatar
OMG that is great info! WUB YOU Thanks for sharing
Old 01-10-2010, 12:31 PM   #63
Diesel Dan's Avatar
Engine: DT466/AT545
Phil, you are awesome! Thanks!
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 01-20-2010, 08:01 PM   #64
Coachwork: THOMAS
Chassis: SAFE-T-LINER
Engine: CAT 3116
Rated Cap: 83
Not too much accomplished but here is a dinette mock up and some insulation.
I don't have any pics of it. But I picked up 1" raw white sheet insulation thats going to cover some of the windows and the walls in between the wall framing. Its the real cheap white styrofoam stuff. I wanted to get the Owen's Corning pink sheet insulation (the raw stuff. No plastic or foil on each side). But I could only find it in 2x8 tongue and groove sections and they wanted around $8 dollars a sheet.
The white stuff was 4x8 for $11 a sheet but seems a lot more flimsy. I was wondering what you guys recommend. Should I return it and get the pink sheet insulation? Or would the white stuff be ok?
Also, I think I am just about ready to start framing up the wall. Is there anything I should do before that? I plan on running my electrical wire through the wire channel above the windows. I still need to decide exactly where I am going to put outlets and pretty much all my electrical. I don't plan on having any outlets in the bus walls. Probably just on end walls and kitchen counter etc..
BUSBOZO is offline   Reply With Quote
Old 01-21-2010, 07:29 PM   #65
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
I don't even see an R rating for the cheap stuff I got. The Owens Corning pink stuff is an R5. Wow. Thats pretty low. I can't imagine what the R value is on the white styrofoam. I think I'll go exchange it for the pink.
Old 01-21-2010, 08:05 PM   #66
Just remember to get pink stuff that is only thick enough to fill the space without compressing it in. The tighter/more compressed the pink stuff is, the less R-Value it has.
Old 01-22-2010, 10:59 AM   #67
newbusser's Avatar
Year: 90
Coachwork: blue bird
Engine: Navistar Straight 6 Turbo
so... the white polystyrene actually is better to use in the walls?
need more coffee, not processing thoughts well.
“Twenty years from now you will be more disappointed by the
things that you didn't do than by the ones you did do. So throw off
the bowlines. Sail away from the safe harbor. Catch the trade winds
in your sails. Explore. Dream. Discover." Mark Twain
newbusser is offline   Reply With Quote
Old 01-22-2010, 06:12 PM   #68
Fiberglass allows air currents to circulate between the strands of fiber - go to the isocylene (spelling?) foam booths at a Home Show for a demo.
Fiberglass also holds moisture like a sponge. This can freeze into ice, which kills the R value, and promote rust in metal it contacts.
In a home, there is supposed to be a vapor barrier between the living space and the fiberglass to discourage the moisture from entering it. I once bought a home that had an incomplete vapor barrier, and the winter condensation encouraged by the frozen fiberglass dripped onto my nose while I tried to sleep. The outer side of the fiberglass should be able to breathe, to allow what moisture there is to escape. The steel walls of a bus aren't too good for that.
If fiberglass stays dry, it is OK in a bus. But closed-cell foam will not hold water or pass air currents through it at all, so it gives extra protection from heat, cold, and moisture.
Old 02-01-2010, 07:54 PM   #69
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
A little more on the backing sign done.
Old 02-01-2010, 08:11 PM   #70
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Blacked out some windows.
