05-23-2010, 05:47 AM
#141
Coachwork: AmTran RE
Re: CHANGED AGAIN! THIS WILL BE IT!!
I have a nice big skirt dent like that I need to straighten. Fortunately (for me anyway) AmTran's roof bows don't go below the floor, the braces for the skirt are separate. It looks like I can just bend the braces back. I also see I'm not the only one who thought to use a pad from the rear seat as a creeper.
05-23-2010, 02:47 PM
#142
Coachwork: THOMAS
Chassis: SAFE-T-LINER
Engine: CAT 3116
Rated Cap: 83
Ha. Ha. Yeah that long cushion comes in handy.
07-03-2010, 09:43 PM
#143
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Ok, so I haven't posted here for over a month. I've been working on a few things. Mostly the time consuming process of designing, planning and building the holding tanks.
I also figured out how and where to reuse the OEM heaters. The fans pull the air from the top down through the heater core and out of the bottom. I ordered fan blades for a counterclockwise fan motor ( mine is clockwise or vise versa can't remember) because I plan on putting the heater unit on its side, cutting off the legs for more room and when I'm done the air will be pulled the opposite way and pushed through the heater core.
Also ran the vent pipe through the roof.
07-03-2010, 09:48 PM
#144
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Grey tank frame assembly
07-03-2010, 09:54 PM
#145
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
I decided to weld vertical square 1" stock to the side of the frame so I can bolt it to the bus frame. The other side of the frame will be suspended with threaded rod.
07-03-2010, 10:04 PM
#146
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
The black tank frame from Rv surplus was a real odd shaped tank and a real challenge. I had to custom bend my frame to the contour of the tank. (courtesy of BUNEDOGGLE'S idea).
I used the same frame method for the black tank as I did with the grey tank.
07-03-2010, 10:09 PM
#147
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Got the vent pipe installed.
07-03-2010, 10:10 PM
#148
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Cable hatch installed for 50 amp cable.
07-05-2010, 08:51 PM
#149
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Thanks. I used 1" angle iron and also 1" steel tubing.
07-07-2010, 09:39 AM
#150
Chassis: Safe-T-Liner MVP
Engine: CAT3116
Really great progress! Nice job on the tank frames.
1. Always use the right tool for the job.
2. A hammer is the right tool for any job.
3. Anything can be used as a hammer.
07-07-2010, 09:11 PM
#151
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Thanks Brian. Finished getting everything plumbed.
07-09-2010, 03:07 PM
#152
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Yes, I tried reversing the wires, but for some reason it did not work. Motor spun the same way.
If your fan blades are not too brittle you can bend them the opposite way. Some of mine were very brittle and cracked. I ended up ordering a couple new blades from the local Thomas dealer. $13 bucks a piece and they are the counterclockwise blades. I guess these heaters had either clockwise rotation or counterclockwise rotation.
Mine was clockwise rotation and I wanted to reverse them so I got counterclockwise blades.
07-18-2010, 07:12 PM
#153
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
This weekend consisted of finishing the shower, and focusing in the bedroom area.
I spent a considerable amount of time prepping the bus heater and figuring out how I want to build a frame around it. I was hoping the edge of the heater lined up with the edge of the bedframe. But that didn't happen.
07-18-2010, 07:14 PM
#154
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
More of the heater install.
07-18-2010, 07:15 PM
#155
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Shower completed.
07-20-2010, 11:38 AM
#156
Rated Cap: 79 at Birth
Coming right along, the pics look good and it looks like your shower turned out really well
07-20-2010, 08:35 PM
#157
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Thanks guys! Working on the bedroom area right now. Running some cable wrapping a few things up under the bed. Cleaning up loose wires. All that fun stuff.
More pics soon!
Dan
08-08-2010, 07:33 PM
#158
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Some more work on the bathroom. Walls are painted, toilet mounted, flooring put down. (adhesive tiles). Shower light and curtain installed.
08-08-2010, 07:38 PM
#159
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Also, got the kitchen counter, sink and stove installed this weekend!! Quite productive!
Now the fun part of trying to figure out how I want to go about making the cabinet face.
08-09-2010, 09:42 PM
#160
wow looking good!!
can I ask you what the height of your kitchen counter is?
also, what did you use for the shower stall? Im haveing a hard time trying to find something for mine, and still have the kitchen to build in mine
tks
