Old 03-23-2013, 04:26 PM   #101
PDBreske's Avatar
Rated Cap: 1
Re: Church Bus
Originally Posted by Part-time
That lock hasp should be hinged to fold flat against the side when not being used.
Yes, I thought the same thing. It might lose a little strength, but for its purpose, I think it would still be strong enough. Just make sure it has enough friction that it stays folded and doesn't accidentally flip out to where it might do damage. Or maybe a little magnet that holds it out of the way?
Read about the "Camel" RV Conversion project!
My first passion is photography. Visit my website to see some of my work.
Old 05-05-2013, 05:19 PM   #102
Re: Church Bus
as long as air can flow thru the unit it will be fine, and most lower units cab be turned 90 degrees...old ones could atleast
Old 05-08-2013, 11:18 AM   #103
Sam
Chassis: Wayne Lifeguard
Engine: GMC 6.2lt
Rated Cap: 40
Re: Church Bus
Originally Posted by thjakits
Hi Sam,
question: Why did you install the AC "sideways" ?
Thanks for the input! yes, the main reason was because it fit so nice between the 4x4 deck frames. i did a bit of looking into it and bansil is correct. as long as air can Circulate in the system it should be fine. The majority are placed facing forward to be more aerodynamic while on the road. I figured since I was going to have a deck on top when complete the unit would be the least of my wind resistance problems Rain could be an issue but after I seal the roof with some Hy-tech and build the deck with rain collectors underneath it Iím crossing my fingers the skoolie gods will smile on the design.
Sam is offline   Reply With Quote
Old 05-17-2013, 08:09 AM   #104
Sam
Engine: GMC 6.2lt
Rated Cap: 40
Re: Church Bus
Time to work on the door!
Old 05-17-2013, 08:10 AM   #105
Sam
Engine: GMC 6.2lt
Rated Cap: 40
Re: Church Bus
Took off the old bus door...
Old 05-17-2013, 08:11 AM   #106
Sam
Engine: GMC 6.2lt
Rated Cap: 40
Re: Church Bus
built up a frame for the new door.
Old 05-17-2013, 08:14 AM   #107
Sam
Engine: GMC 6.2lt
Rated Cap: 40
Re: Church Bus
useing the wire brush and some muscle to get the rust off of some old sheet metal.
Old 05-17-2013, 08:20 AM   #108
Sam
Engine: GMC 6.2lt
Rated Cap: 40
Re: Church Bus
trying out some rope caulk for the door install!
Old 05-17-2013, 08:22 AM   #109
Sam
Engine: GMC 6.2lt
Rated Cap: 40
Re: Church Bus
putting the metal skins on.
Old 05-17-2013, 08:26 AM   #110
Sam
Engine: GMC 6.2lt
Rated Cap: 40
Re: Church Bus
Almost done!
Church Looking To Trade Their Bus For A 15-passenger van.... CHEESE_WAGON Classifieds | Buy, Sell, Swap 0 09-07-2013 06:31 AM
1996 Bluebird school/church bus GBC Classifieds | Buy, Sell, Swap 7 07-27-2011 07:14 PM
Int bus neet paint church bus check listing frank-id Classifieds | Buy, Sell, Swap 0 06-05-2007 08:42 PM
TAILGATERS!!! Church Pews for FREE!!! churchbus Classifieds | Buy, Sell, Swap 0 09-30-2005 09:33 AM
Church buses Firearm Classifieds | Buy, Sell, Swap 0 09-09-2004 12:41 PM
