Old 08-25-2014, 10:56 AM   #21
Re: College student taking on 2000 Thomas Saf-t Liner
Originally Posted by nachosforjoe
What kind of bus do you have?
HERE I present La Tortuga http://www.skoolie.net/forum/viewtopic.php?f=9&t=12570
Old 09-09-2014, 09:01 AM   #22
Chassis: Saf-t Liner
And the wall frames are going up! Used self tapping screws to put them up. Drilled right into the bus walls. Was absolutely fantastic.
nachosforjoe is offline   Reply With Quote
Old 09-09-2014, 09:32 AM   #23
is it the huge picture...or are your walls not 90* to the floor
Old 09-09-2014, 09:48 AM   #24
are my walls not 90* to the floor? I did take a level to the walls and they aren't 100% level, not really sure why though. But the picture makes it look worse than it really is
Old 09-09-2014, 10:47 AM   #25
I looked at those walls and decided I'd better put the screw cap back on my wine bottle. After reading the last post I guess I was overly anxious
Old 09-09-2014, 11:17 AM   #26
Old 09-09-2014, 11:52 AM   #27
Next time I go work on it I will get a better picture of it. Even looking at the picture on my computer it doesn't look as bad as the image online. I do know they aren't completely straight at points. I took a level to the wall and the windows and frame below were not at the same level. Couldn't think of anyway to correct this
Old 09-09-2014, 11:57 AM   #28
your fine, we were just "rubbing you" in a PC kind of way
best way to secure studs to side walls I think
Old 09-09-2014, 12:04 PM   #29
Wanted to make sure that anything I secure later on to the studs doesnt get pulled off so I used 2 3/4" self tapping metal screws. One on the bottom, one in the middle, and one on the top. Going to eventually place plywood on top of the 2x4's running all the way up the wall. Not covering the windows, but covering the 2x4s. Then have plywood above the windows to hide the wires/lighting i plan to run
Old 09-16-2014, 08:57 AM   #30
Started doing floors but ran out of screws unfortunately. Also I think I need a larger vehicle. 8 foot plywood doesnt fit in my SUV with 6 feet of cargo space. Yes I know they are not straight, but it wont matter as that is getting covered over. Also intend to fill the gaps on the sides.
2000 Thomas Saf-t Liner steve.c Skoolie Conversion Projects 52 10-29-2014 04:26 PM
2000 Thomas School Bus Saf-T-Liner FE GreyEagle Classifieds | Buy, Sell, Swap 0 07-30-2011 11:27 AM
1989 Thomas Saf-T-Liner GoneCamping Classifieds | Buy, Sell, Swap 0 01-09-2009 09:05 PM
89 Thomas Saf-T-liner Skoolie.... GoneCamping Skoolie Conversion Projects 2 09-08-2006 09:28 PM
1989 Thomas Saf-T-Liner vonslatt Skoolie Conversion Projects 49 10-25-2005 09:02 PM
