Old 08-28-2016, 08:37 AM   #1
Chassis: Mid size
Engine: International DT466e
Rated Cap: 15+5 handicap
Cool Bus Build
Hello so this is the beginning of my 2001 International Genesis RE build with a DT466e.
When I brought the bus from NJ it was had no power and was over heating. I found the turbo line going into intercooler had a large gouge in it and two bolts missing from the front engine cover causing oil and grime to be all over the radiator, intercooler and engine. I pressure washed and cleaned all of the above and repainted same. I am also replacing the radiator lines, water pump, cam position sensor and oil pan gasket (its weeping). I am also replacing all fluids and filters Parts are on order waiting for them to come in. I also obtained a second intercooler and will be fabricating some mounts so I can run both.
pts.of.authty is offline   Reply With Quote
Old 08-28-2016, 09:53 AM   #2
BuSmith's Avatar
Wooo! I dunno how far you drove it like that but it sounds fun. Can't wait to see pics.
Sent from my XT1575 using Tapatalk
BuSmith is offline   Reply With Quote
Old 08-28-2016, 09:32 PM   #3
Chassis: Mid size
The pics are under cool bus under photos. Can't get them to upload to this post for some reason...
