Old 08-04-2013, 07:57 AM   #21
Chassis: Saf-t-liner
Engine: Cat 3126 - MD 3060
Re: Credit Score 1000 Bus
ThePimentals is offline   Reply With Quote
Old 08-04-2013, 10:15 AM   #22
opus's Avatar
Chassis: All-American R/E
I never thought of doing that with the bus on its side. Makes it easier on the shoulders I bet. ;)
Old 08-04-2013, 12:22 PM   #23
wmkbailey's Avatar
Engine: 3126
Man, I wish you would have shown me this trick before I removed my ceiling. My shoulders were killing me.
William
https://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 08-04-2013, 07:29 PM   #24
I thought it took a long time to upload the photo. Guess it glitched out
Old 08-08-2013, 05:59 PM   #25
Old 08-08-2013, 06:12 PM   #26
atleast they used wire ties in yours!!
Old 08-08-2013, 07:22 PM   #27
opus's Avatar
Now you're fixing things with it standing on its nose.....
Old 08-08-2013, 08:56 PM   #28
wmkbailey's Avatar
Engine: 3126
That looks like my rats nest.
I'm slowly removing stuff I don't need. I did re route the air for the stop sign and front thingy on the bumper to use for my air horn. Thanks to your photo I can show where they are located.
I disconnected the line from the air switch and re-connected it into the tee. The silver hose is the feed into the switch.
William
Old 08-08-2013, 10:12 PM   #29
I don't know why when I preview the photo is fine. Oh we'll.
Yea I had some extra air elbows from some other project, so when I disconnected the stop sign I could re attach the T with an elbow instead. I haven't done the front swing out mechanism yet, I'm going to try and clean up the wiring mess so I can get to it all better. I figure about half of these wires will stay.
Old 08-10-2013, 09:55 AM   #30
Old 08-10-2013, 04:49 PM   #31
wmkbailey's Avatar
Engine: 3126
I have not looked inside my engine compartment, but it looks like something large is bolted through. These are added supports for it. Just my guess.
William
Old 08-10-2013, 08:02 PM   #32
roach711's Avatar
Rated Cap: 19
It's hard to tell from the picture but I'm guessing they might be seat belt tie-downs. The ones in my bus had keyhole shaped slots for clipping in seat belts.
The Roach Motel
Old 08-11-2013, 10:48 AM   #33
I started to remove flashers and unnecessary electrical today, and within an hour I wanted to light my bus on fire. I'd rather rip the floor out again. What a mess. So many things wired to so many sensors and buzzers. Yuck.
Old 08-11-2013, 05:41 PM   #34
wmkbailey's Avatar
Engine: 3126
Looking at my bus today I think Roach711 is right.
William
Old 08-12-2013, 08:11 AM   #35
wmkbailey's Avatar
Engine: 3126
I sent you a PM on the windows.
William
Old 08-12-2013, 02:13 PM   #36
I didn't get it
Old 08-13-2013, 11:21 AM   #37
Pretty happy. I got all the emergency exits and flasher disconnected and the bus still runs. No buzzers or anything.
Old 08-17-2013, 08:54 AM   #38
Old 08-17-2013, 12:07 PM   #39
lornaschinske's Avatar
Rated Cap: 89
I have a similar one. It's to vent the bus on hot days so the windows don't blow out. Kinda like why I open a window on the Jeep just a crack. Started doing that after I had a window shatter in a very dark green car with black interior. Nights get very cool in the NC mountains but can/warm up nicely on a sunny day. Since then I leave a window open just a tiny crack. Enough to let expanding hot air out yet not let rain in.
I have sealed of our vent on the Blue Bird from the inside with spray foam and a piece of sheet metal. It was sucking our air conditioned air out of the bus since the vent was right at the front of the air conditioner.
Fulltime since 2006
Old 08-17-2013, 03:04 PM   #40
PDBreske's Avatar
Rated Cap: 1
This is how internet rumors get started.
I know that vehicle windows will sometimes shatter on very hot days, but it's NOT due to the interior air pressure "blowing out" the glass. The high temperatures can sometimes cause auto glass to shatter because tempered glass is made with high internal stresses that give it strength, but also ensure that when it does break, it breaks into a million little pieces instead of long, dangerous shards. A single, invisible flaw in the glass can cause it to become very brittle on a very hot day and anything could set off the chain reaction that causes the window to break.
No car is sealed so well that the difference in air pressure could cause the glass to break. Air leaks out through a thousand small cracks around the car, and a bus is no exception.
If a car were sealed well enough to trap the air inside with enough pressure differential to break the glass (have you ever tried to break a car window?), it would follow that using the heater on a cold day to warm the air temp in the car to forty degrees above the outside temperature would cause the windows to suck into the car, or at least create such a pressure differential that you'd never be able to open the door.
Science is your friend.
Great WVO score sdwarf36 Alternative Fuels | Electric, Propane, Wood & Biofuels 4 02-23-2016 11:56 AM
How far will $1000 get you in a conversion? mannypacquimeow Conversion General Discussions 13 08-11-2014 01:58 PM
Another score for Gore Redbear Everything Else | General Skoolie Discussions 0 10-31-2010 07:29 AM
Auction SCORE!! oakspring Conversion General Discussions 0 05-15-2010 10:44 PM
eBay skoolie for $1000. EldoMike Classifieds | Buy, Sell, Swap 9 04-20-2005 05:59 PM
