02-24-2014, 04:46 PM
#81
Chassis: Saf-t-liner
Engine: Cat 3126 - MD 3060
Re: Credit Score 1000 Bus
ill post better pictures when its all painted, i dont like rustyness
03-17-2014, 06:10 AM
#82
03-17-2014, 06:09 PM
#83
For your sake, I hope you don't share my mechanical abilities...
Greta at taking things apart. Less than great at getting them back together.
03-18-2014, 10:44 PM
#84
Mostly it had bad connections, but there was some things that needed cleaning inside. And I wanted to check to make sure the vinyl gear was still good. It's running now.
03-19-2014, 04:31 PM
#85
Finally got the webasto heater working and now my bus won't start. It cranks over 2 times and then the power dies. All the lights go out and my clock resets. And it will slowly keep cranking and kill the battery after every crank.
03-19-2014, 05:01 PM
#86
Chassis: Saf-T-Liner MVP ER
Engine: CAT 3126b Rotella-Chugger
Throw a trickle charger on it and check the oil. These motors won't start if they're low on oil.
03-24-2014, 06:01 AM
#87
03-27-2014, 10:06 AM
#88
Engine: 3126
Good to know I now have a goto person when my Webasto breaks down. What is your hourly rate?
03-28-2014, 10:36 PM
#89
I can see why that guy only charges 300 per unit. It really doesn't take much to pull these apart. It was scary but simple. Very simple system.
05-11-2014, 11:02 PM
#90
Psyched to say construction officially started today.
05-12-2014, 11:12 AM
#91
Enjoying the 80 degree weather? First time in 224 days here in Worcester
05-12-2014, 08:13 PM
#92
Tell me about it. We go from 55 for a month straight to 81.
05-15-2014, 10:09 PM
#93
Floor is done. Next is walls and stuff. Typical.
05-15-2014, 10:11 PM
#94
05-15-2014, 10:52 PM
#95
How thick is your plywood? and your foam?
Not all those who wander are lost.
05-16-2014, 10:33 AM
#96
Chassis: All-American R/E
They are very simple....until one burns up on you and you begin to question whether you want to fiddle with it or not.
05-20-2014, 08:15 AM
#97
Engine: 3126
It feels good to get back to working on the bus again. I'm almost done with my insulation. I ordered spray foam to finish up this weekend. I put 2" of foam board in between the supports and will cover all of it with 1" spray foam. It may be over kill, but I will be living in it full time come November. I hope . It takes me a while because I'm one person.
05-20-2014, 01:55 PM
#98
Coachwork: Crown / Pusher
does doing it this way insulate better than doing straight spray foam?
05-20-2014, 01:59 PM
#99
Engine: 3126
No, I had to get 2" in before my trip to Indidan in December. You can't spray foam unless the temp is above 60. I decided to glue in foam board. The RMAX I used is R-6 per inch, spray foam is R-7 per inch.
05-23-2014, 10:25 PM
#100
Well I suck at posting photos. But my floor is done. And I gutted a whole pop up camper for parts too. Lots of progress happening.
