04-29-2010, 02:20 AM
#21
Re: Daddy's Dog House
I am too lazy to backread at the moment... It depends on what items you still need. But I would go with items that will cost you a bit that you would rather just pick up from them instead of dropping a load of cash somewhere. Fridge, Stove/oven, AC, come to mind as being costly.
05-19-2010, 11:03 AM
#22
Coachwork: Ward
Chassis: Ford B600
Engine: 6.6L Turbo Diesel
Rated Cap: 26
Originally Posted by houskou
I think i saw your bus in a lot in Katy while going to t ball today...
Where in Katy? I live there, but my bus is near Sealy. I'd love to see other projects close by.......
05-19-2010, 11:11 AM
#23
Moderator
Engine: DT408, AT545
Rated Cap: 23 500 gvw
How much does that insulation cost per sheet?
05-19-2010, 12:19 PM
#24
Coachwork: Chevy
Chassis: Bluebird
Rated Cap: 16
$12-$15
05-28-2010, 07:02 AM
#25
what was the thickness of the insulation, and the thickness of the plywood that u used on the floor?
tks
05-28-2010, 07:43 PM
#26
Originally Posted by Smitty
tks
Just to see how good of a guesser I am (by the pic)....I say 1/2" & 1/2"
Smitty
im guessing 1 inch for the insulation , 1/2 for plywood
06-06-2010, 08:08 AM
#27
Don't have my skoolie yet but I've done bunks in class A and ugh... For us it was a toss up, easier walk space or more sleeping width. We deciding sleeping comfort was far more important than having to turn side-ways to walk through an ilse. Ours are 33" wide (supports and all) and 7' long. Testing them out in the house for a month (kids love that) shows this is decent and gives enough room for turning during sleeping and plenty of foot room to push covers and sleeping bags to end of bed if things get too warm. We've four beds, two bunks btw.
06-06-2010, 01:36 PM
#28
Coachwork: flatnosed
Chassis: amtran/bluebird/thomas
Engine: diesel
If and when I ever get a bus, I definitely want bunk beds on each side of the aisle for my two boys and a pair of friends. My thought is to built them such that at night they can be pulled out (cantilevered) somewhat like a drawer. Depending on the mattress (I am thinking foam); it could be pushed up the side wall during the day.
I have not put pen to paper, but another derivation might be to put (removable) supports all the way across, and pull out a platform to support a mattress and have a very large sleeping surface, say if other adults were to tag along( I am thinking top bunk for this idea).
The sun is the same, in a relative way, but you're older; shorter of breath, and one day closer to death.
Pink Floyd - Dark Side of the Moon
06-06-2010, 08:40 PM
#29
Chassis: Safe-T-Liner
Engine: CAT 3208 Turbo
Re: measurements
Originally Posted by bcschro
Ordered sheet metal yesterday to cover seven windows on both sides. Should be picking it up Tuesday.
Can anyone who has build out their interior tell me their measurements for bathrooms, and bunk beds. I am taping mine out and they seems too take up a lot of walking space. I have measured my bunks at 7 feet by 3 feet. Is this right or too big?
I will try and get you some measurements of my layout in the next couple of days. I have the exact same bus you have. My bathroom is a split/pass through design. In other words, shower on one side of the bus and sink and toilet on the other.
Left side front to back:
dinette booth
counter space
Refrigerator
Bunk beds
shower
wardrobe
Master bedroom
Right side front to back:
couch
counter/sink/stove top
pantry/furnace
broom closet
wardrobe
toilet/sink
wardrobe/storage
master bedroom
It is all just in tape and subject to change.
06-06-2010, 09:22 PM
#30
Coachwork: THOMAS
Chassis: SAFE-T-LINER
Engine: CAT 3116
Rated Cap: 83
I would do the bunks just a little over 6 feet.
06-06-2010, 09:26 PM
#31
Year: 1981
Chassis: Ford B-600
Engine: Ford 370 Propane
Rated Cap: 48
I thought 6'6" was standard, but I have been wrong before. Really, it has happened!
07-08-2010, 06:42 PM
#32
Coachwork: Bluebird tc2000
Chassis: 3401-3502 ???
Engine: cummins 5.9
that galvanized aluminum paint worked great for about 98% of my use ....in sum spots it didnt stick well and looked like oil and water .... i thought sum contaminant got into the paint or on to my panels... but i just metal primed over those spots and that stuck.... your work looks great
07-09-2010, 12:23 AM
#33
Engine: DT466/AT545
To paint my galvanized steel window skins, I got this paint/primer called "Cold galvanizing compound". I did the vinegar treatment, rinsed it off with water, then sprayed this stuff on. Seems to be sticking.
07-09-2010, 01:31 PM
#34
Coachwork: Ward
Chassis: Ford B600
Rated Cap: 26
Where are you in Katy? I'm just off Mason & I-10! I'd LOVE to stop by and take a peek!
07-15-2010, 11:36 AM
#35
Coachwork: Chevy
Chassis: Bluebird
Rated Cap: 16
I think you need epoxy primer. Galvanized is tough stuff to prime.
07-16-2010, 08:08 PM
#36
Year: 55
Coachwork: Ford
I would wipe it down with some Dupont First Klean and follow up with some Dupont metal conditioner.
You can also get some fisheye eliminator and add it in the paint.
Etching primer works good as do any two-part primer.
07-17-2010, 12:09 PM
#37
Coachwork: Chevy
Chassis: Bluebird
Rated Cap: 16
Ask a truck shop that has a paint booth, because that means they paint big busses like ours. Vinegar is from the 60's and self-etching primer is an old method as well. They'll tell you exactly what you need, but again I believe the guy who painted my bus said he used epoxy primer.
07-18-2010, 07:29 PM
#38
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Self etching primer is usually used on bare metal first. 2 part epoxy primer is GREAT STUFF and is usually used on an already coated surface (color change etc..) or after self etching primer is applied.
The nice thing about the 2 part epoxy primer is.. Its just the primer and catalyst (harder). There is no reducer required. You can reduce it to make it thinner depending on your application. But most of the time The epoxy primer is used for filling in minor imperfections because of its high build properties. It also covers very nicely.
Dan
08-11-2010, 05:38 PM
#39
Engine: cummins 5.9
i weighed about i/4 of the way in im going to reweigh when im close to done also ..
i went to a truck stop outside of town and used the cat scales
my weight was 15456
08-12-2010, 09:43 AM
#40
Engine: DT466/AT545
Oh I forgot to ask. At what point did any of you Texas skoolies weigh you bus for registering it as a RV. Before you build out the interior or after?
I had no requirement to weigh my bus for registering as an RV. I just gave them the GVWR off the title.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
House Batteries
Stuff |
Electrical, Charging and Solar |
12 |
06-06-2012 08:52 AM |
House burned down. :(
ezbme |
Everything Else | General Skoolie Discussions |
1 |
05-16-2009 11:25 AM |
my new house....maybe
lapeer20m |
9 |
01-17-2009 09:55 PM |
Do I need house batts?
the_experience03 |
Conversion General Discussions |
3 |
10-07-2008 08:29 PM |
Bus Boat House
nyrockingchairs |
2 |
07-20-2007 01:35 PM |
