Old 06-06-2010, 09:26 PM   #31
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Engine: Ford 370 Propane
Rated Cap: 48
Re: Daddy's Dog House
I thought 6'6" was standard, but I have been wrong before. Really, it has happened!
Old 07-08-2010, 06:42 PM   #32
cheezypsnookle's Avatar
Coachwork: Bluebird tc2000
Chassis: 3401-3502 ???
Engine: cummins 5.9
that galvanized aluminum paint worked great for about 98% of my use ....in sum spots it didnt stick well and looked like oil and water .... i thought sum contaminant got into the paint or on to my panels... but i just metal primed over those spots and that stuck.... your work looks great
cheezypsnookle is offline   Reply With Quote
Old 07-09-2010, 12:23 AM   #33
Diesel Dan's Avatar
Engine: DT466/AT545
To paint my galvanized steel window skins, I got this paint/primer called "Cold galvanizing compound". I did the vinegar treatment, rinsed it off with water, then sprayed this stuff on. Seems to be sticking.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 07-09-2010, 01:31 PM   #34
M1031's Avatar
Coachwork: Ward
Chassis: Ford B600
Engine: 6.6L Turbo Diesel
Rated Cap: 26
Where are you in Katy? I'm just off Mason & I-10! I'd LOVE to stop by and take a peek!
M1031 is offline   Reply With Quote
Old 07-15-2010, 11:36 AM   #35
Coachwork: Chevy
Chassis: Bluebird
Rated Cap: 16
I think you need epoxy primer. Galvanized is tough stuff to prime.
Rutgers tailgating bus http://www.skoolie.net/forum/viewtopic.php?f=36&t=5545
RUskoolietailgater is offline   Reply With Quote
Old 07-16-2010, 08:08 PM   #36
Year: 55
Coachwork: Ford
I would wipe it down with some Dupont First Klean and follow up with some Dupont metal conditioner.
You can also get some fisheye eliminator and add it in the paint.
Etching primer works good as do any two-part primer.
bodaver32 is offline   Reply With Quote
Old 07-17-2010, 12:09 PM   #37
Coachwork: Chevy
Chassis: Bluebird
Rated Cap: 16
Ask a truck shop that has a paint booth, because that means they paint big busses like ours. Vinegar is from the 60's and self-etching primer is an old method as well. They'll tell you exactly what you need, but again I believe the guy who painted my bus said he used epoxy primer.
Old 07-18-2010, 07:29 PM   #38
Coachwork: THOMAS
Chassis: SAFE-T-LINER
Engine: CAT 3116
Rated Cap: 83
Self etching primer is usually used on bare metal first. 2 part epoxy primer is GREAT STUFF and is usually used on an already coated surface (color change etc..) or after self etching primer is applied.
The nice thing about the 2 part epoxy primer is.. Its just the primer and catalyst (harder). There is no reducer required. You can reduce it to make it thinner depending on your application. But most of the time The epoxy primer is used for filling in minor imperfections because of its high build properties. It also covers very nicely.
Dan
BUSBOZO is offline   Reply With Quote
Old 08-11-2010, 05:38 PM   #39
Engine: cummins 5.9
i weighed about i/4 of the way in im going to reweigh when im close to done also ..
i went to a truck stop outside of town and used the cat scales
my weight was 15456
Old 08-12-2010, 09:43 AM   #40
Diesel Dan's Avatar
Engine: DT466/AT545
Originally Posted by bcschro
Oh I forgot to ask. At what point did any of you Texas skoolies weigh you bus for registering it as a RV. Before you build out the interior or after?
I had no requirement to weigh my bus for registering as an RV. I just gave them the GVWR off the title.
Gallery:
Conversion Thread:
House Batteries Stuff Electrical, Charging and Solar 12 06-06-2012 08:52 AM
House burned down. :( ezbme Everything Else | General Skoolie Discussions 1 05-16-2009 11:25 AM
my new house....maybe lapeer20m Everything Else | General Skoolie Discussions 9 01-17-2009 09:55 PM
Do I need house batts? the_experience03 Conversion General Discussions 3 10-07-2008 08:29 PM
Bus Boat House nyrockingchairs Everything Else | General Skoolie Discussions 2 07-20-2007 01:35 PM
