Old 08-17-2010, 09:20 PM   #41
cheezypsnookle's Avatar
Coachwork: Bluebird tc2000
Chassis: 3401-3502 ???
Engine: cummins 5.9
Re: Daddy's Dog House
im adding a accumulator after my pump to save on wear... i dislike the sound of a pump trying to prime over and over
cheezypsnookle is offline   Reply With Quote
Old 08-18-2010, 04:00 AM   #42
Engine: DTA360
Rated Cap: 16
As far as painting galvanized, here's what a paint guy told me to use... Haven't done so yet, but you may want to look into it...
http://www.marinenutz.com/products/5...%20PRIMER.html
dirtygoat is offline   Reply With Quote
Old 11-20-2010, 06:42 AM   #43
houskou's Avatar
Coachwork: flatnosed
Chassis: amtran/bluebird/thomas
Engine: diesel
where have you gone Joe Dimaggio?
The sun is the same, in a relative way, but you're older; shorter of breath, and one day closer to death.
Pink Floyd - Dark Side of the Moon
houskou is offline   Reply With Quote
Old 03-07-2011, 06:57 AM   #44
houskou's Avatar
Engine: diesel
Much progress shown on his blog...
Old 06-14-2011, 01:17 PM   #45
Hex
Hex's Avatar
Coachwork: Bluebird, Model 3800
Rated Cap: 42
Looks good ...
And I don't know why you couldn't use flexible stuff, so long as you're making sure it's not in a place it could kink. (What a great idea, BTW!)
Hex is offline   Reply With Quote
Old 06-16-2011, 09:13 PM   #46
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Engine: Ford 370 Propane
Rated Cap: 48
Originally Posted by emberglow
...Do consider that rain comes in the roof vent...
Why would rain come in the roof vent? Wouldn't you use a vent cap? I used one and there is no way rain is getting in my vent pipe, it has been raining here for a couple weeks, my vent pipe isn't finished yet and is open to the inside of the bus, no leaks at all.
Old 10-24-2011, 04:48 PM   #47
lornaschinske's Avatar
Rated Cap: 89
Originally Posted by bcschro
... I will have a female outlet next to the junction box that is wired to my generator. When I want to use the generator, I will plug into it with my shore power cord. When I have access to shore power, I can unplug from the generator, pull out my cord and plug into the shore power outlet.
I could put in a transfer box (about $200.00), and it can go out and I can replace it. Or I can do it this way and do it manually. Later if I get lazy, I'll do the transfer box...
This is the best, most "idiot-proof" way of making sure you don't accidentally have the generator running AND the shore power on at the same time. I've heard a lot of stories about auto transfer switches kicking on the genset while plugged into shore power. The results were... not good. I wouldn't do the transfer switch. But that's us. We are using the same method because we never know when we will have a "blonde moment".
Fulltime since 2006
Old 10-24-2011, 09:40 PM   #48
BTW..regarding painting galvanized? --- Most auto parts stores now carry "self etching primer" to prep galvanized, aluminum & stainless for paint. Handy stuff.
Old 10-27-2011, 01:38 PM   #49
bus-bro's Avatar
Engine: 3208 na boat anchor
You live and learn.
I also have found that to be true in regards to doing a bus conversion. Some folks here do very good work; in my case I'm still living and learning.
Old 10-27-2011, 05:09 PM   #50
just for the record...most "etching" primers need to cure a minimum of 24 hours and I've seen some that recommend a week. Ouch!
House Batteries Stuff Electrical, Charging and Solar 12 06-06-2012 08:52 AM
House burned down. :( ezbme Everything Else | General Skoolie Discussions 1 05-16-2009 11:25 AM
my new house....maybe lapeer20m Everything Else | General Skoolie Discussions 9 01-17-2009 09:55 PM
Do I need house batts? the_experience03 Conversion General Discussions 3 10-07-2008 08:29 PM
Bus Boat House nyrockingchairs Everything Else | General Skoolie Discussions 2 07-20-2007 01:35 PM
