Old 01-04-2010, 08:01 AM   #1
Re: Daddy's Dog House
First, let me say welcome to the madness. That's a nice looking hi top thomas you have.
This is just my opinion, but it seems it would be a lot easier to deal with floor issues before a lot of things are sitting on the floor.
If you're just going camping, I probably would just poke a screwdriver at the floor in a lot of places looking for a soft spot indicating a problem. Not finding a problem, I would likely use the existing floor as is.
If you plan to live in your bus full time, I would go ahead and pull the floor, and *know* the condition of every piece of the interior living space.
Again, this is just my opinion.
hope this helps,
jim
baadpuppy is offline   Reply With Quote
Old 01-04-2010, 07:42 PM   #2
Popular Opinion is to remove the floor rubber and wood. Check everything and clean/scrape/sand any problem spots then use rust inhibitor.
Better to know now what you have to fix, while its still cheap, then find it later when it costs ten times as much to fix.
Old 01-04-2010, 10:14 PM   #3
Year: 1983
Chassis: Carpenter
Engine: 8.3
Welcome, I agree you don't want to have to tear down after a build because of a rust issue that you would kick your self about later for not doing the diligence to yank the rubber and check it out.
I love your bus... It's a monster, and the high top is going to be awesome... You've got a sweet rig good luck and keep us posted.
seth
"grease buddy" and all around nice guy
madpsalmer is offline   Reply With Quote
Old 01-05-2010, 09:13 PM   #4
Coachwork: THOMAS
Chassis: SAFE-T-LINER
Engine: CAT 3116
Rated Cap: 83
CONGRATS!! I have the same bus!! I'm jealous though... You have underbelly storage. Anyway, you will love it!! These ride so nice down the highway! And the 250 HP Cat has plenty of power.
I put down 5/8 plywood and 1/2" foam insulation on my floors. And still plenty of headroom! My bus came from Maine and had some pretty badlly rusted areas around the wheel wells. My advice to you is.. Take a good look inside the wheel openings and look for undercoating worn off and holes in the sheetmetal. The water gets thrown up through the holes and inside the bus rotting the plywood and metal floor.
I also ripped my walls apart because I had leaky windows. (still trying to chase down all the leaks). The water would leak down the pillars and out of the chair rail onto the floor.
You can check out my conversion project on here. Look for "Changed again.This will be it!!"
There is only a handful of us Safe-T-liner owners on here. WELCOME!!
P.S. Let me know if you find any service manuals for our buses. I'm having a hell of a time finding them.
BUSBOZO is offline   Reply With Quote
Old 01-05-2010, 09:15 PM   #5
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Hey, how did you get the "THOMAS" logo on your signature? I can't seem to figure that out.
Old 01-06-2010, 06:26 PM   #6
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
GOOD PROGRESS SO FAR! Is that hose appear to be some sort of drain hose? Or is it a hydraulic hose with fittings on each end?
Old 01-06-2010, 06:32 PM   #7
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
I just went out to look at mine. And it appears to be a coolant overflow hose. Unless yours is set up different. Hmmm...
Old 01-07-2010, 05:24 PM   #8
Chassis: IH
Engine: 466
Rated Cap: 64
Is the "turbo cooler" the intercooler? If so, is it air to air intercooled? Could be a leaking seal in one of the turbo bearings, allowing engine oil to get into the intercooler, and then draining out the drain hose. The drain hose would be there to drain excess moisture out of the intercooler due to humid air, and you don't want the water to go on into the intake. Just a thought! Anyway, I bet your bus probably has around 150,000 to 250,000 miles on it, that is usually about the distance many districts put on thier buses before they dispose of them. Look at the wear on the brake and throttle pedals, that can tell you alot about how many miles are on a vehicle. And the steering wheel! 13,000 hours seems like alot of hours, could be the meter is inaccurate?
I hope to upgrade to a Thomas rear engine bus this coming summer. One of the local school districts will be selling two buses, both with 3116 CATS, Allison MT643 autos, and about 150,000 original miles. They sell them by sealed bids, so you can get lucky, and sometimes you get aced out!
dburt is offline   Reply With Quote
Old 01-07-2010, 06:36 PM   #9
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Yeah, what dburt said. The turbo bearings are usually lubricated by the engine oil. So you could have a bad seal. Is it blowing any blue smoke?
Old 01-08-2010, 08:05 PM   #10
busdriver_phil's Avatar
Coachwork: AmTran RE
To answer a couple of your questions:
Not every bus has a plywood floor. It's a popular option, but the base spec for a Thomas is rubber over steel.
No vehicle averages 65 mph over its entire service life. The 13,000 hours includes lots of idling time and stop-and-go driving. I drive a school bus in a somewhat rural district (longer than average distance between stops), and my bus is used for about 90% of long-distance field trips in our district. Dividing my odometer by my hourmeter I get close to 25mph. I've seen school buses average as low as 10mph. At a lifetime average of 25, your bus would have 325,000 miles, which is quite reasonable for a 17 year old pusher that's been well maintained.
The conversion of Miss Euphegenia, a 1999 AmTran RE: http://www.skoolie.net/forum/viewtopic.php?f=9&t=5704
House Batteries Stuff Electrical, Charging and Solar 12 06-06-2012 08:52 AM
House burned down. :( ezbme Everything Else | General Skoolie Discussions 1 05-16-2009 11:25 AM
my new house....maybe lapeer20m Everything Else | General Skoolie Discussions 9 01-17-2009 09:55 PM
Do I need house batts? the_experience03 Conversion General Discussions 3 10-07-2008 08:29 PM
Bus Boat House nyrockingchairs Everything Else | General Skoolie Discussions 2 07-20-2007 01:35 PM
