Old 04-17-2015, 05:56 PM   #21
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
home sweet home ran perfect. governed out 62-63, just like you guys said i put the pedal on the floor. anyone know what size fuel tank this bus has?had some in it and i put 50 g in it showed 3/4 but pump shut off. thanks
my build pics
Old 04-17-2015, 10:58 PM   #22
65 gallons maybe? Thats what mine holds but totally different buses.
Old 04-17-2015, 11:06 PM   #23
Can you get measurements on it? From there the calcs are pretty easy to work out.
Old 04-18-2015, 11:28 AM   #24
Engine: 190hp 5.9 Cummins
Mine is a 60, some longer ones here have a 80 gallon.
I have seen trip buses with two 80 gallons.
Old 04-19-2015, 06:04 PM   #25
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
taking the seats out
my build pics
Old 04-19-2015, 06:10 PM   #26
Engine: TE 444
Rated Cap: 12
those are much nicer seats than standard school bus, wish you were closer, could use 2 sets
Old 04-19-2015, 06:11 PM   #27
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
the ceiling panels are screwed on, hooked up the radio to another battery and i bought a battery tender from ebay for the coach batteries. looks like the ac lines are flexable so i can just set on floor till i install a ceiling.
my build pics
Old 04-19-2015, 06:48 PM   #28
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
better yet i think ill leave them ac units on the floor and run a return from up high.
my build pics
Old 04-19-2015, 07:05 PM   #29
I love the demo part.
I just pulled the seats out of a similar bus yesterday. Took me 2 hours with a 9/16 wrench, and brute force. Only had to cut 3 bolts with the angle grinder, the rest snapped.
Looking good.
Old 04-19-2015, 07:29 PM   #30
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
outside rail i used an air ratchet and a wrench,all the ones on the floor i have to grind
my build pics
Old 04-21-2015, 05:56 AM   #31
Sweet!! That's a lot more bus than you were initially thinking, but you will definitely have enough room for all your dogs!
What a sweet ride! And head room, no outside painting necessary... Nice score!
~Pamela
SassyLass is offline   Reply With Quote
Old 04-21-2015, 06:08 AM   #32
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
yes its more than i was looking for, funny how that happens.
my build pics
Old 04-21-2015, 04:26 PM   #33
This is proof that everything you need will come to you if you wait, and make the right choices.
Old 04-21-2015, 07:36 PM   #34
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
got a quote from a spray foam company for 1500 bucks, he said he would spray what ever i wanted. closed cell at least 2 " thick, all prep and cleanup. what say you?
my build pics
Old 04-21-2015, 08:02 PM   #35
That's a really good deal.
Old 04-21-2015, 09:32 PM   #36
Sounds like a pretty sweet deal to me. I'd almost pay that much just to have someone clean up behind the grind down.
Old 04-22-2015, 05:41 AM   #37
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
looks like ill be working some overtime! for now i need to figure my layout, run my conduit, insulate the floor, install a hitch and a new rv door. got the rest of the seats out, will post some pics tonight
my build pics
Old 04-22-2015, 03:11 PM   #38
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
working on the sheet metal under the windows, i cant pull it out from under the window. do I need to take the window out and the outside trim? or is it glued in there real good. thanks
my build pics
Old 04-22-2015, 03:34 PM   #39
These?
On my AmTran, they were spot welded every inch or less. I removed them with my air hammer and chisel bit.
Old 04-22-2015, 03:35 PM   #40
