Old 03-21-2016, 10:10 AM   #51
sammy's Avatar
Coachwork: Gillig
Chassis: Phantom Schoolbus
Engine: Detroit Diesel 6v92TA
FreedomPanda - did you build a steel floor, or just rebuild a new wood floor? Seems like if the old floor lasted 40 years, then it's not a bad technique? But what would the downsides be to a wooden floor without the steel under it? You could still put 2" of insulation on it, and then your finished floor on top of that, correct?
sammy is offline   Reply With Quote
Old 03-21-2016, 10:28 AM   #52
Best be marine grade plywood if it is to last more than a year or two.
Old 03-21-2016, 11:05 AM   #53
Coachwork: IC
Chassis: CE300
Rated Cap: 32
stuff like this
https://www.marine-plywood.us/mahogany_okoume.htm
http://plywood.boatbuildercentral.com/help.php
Roll Your Own Build Thread
Old 03-21-2016, 11:11 AM   #54
sammy's Avatar
Coachwork: Gillig
I'm assuming that's what Gillig would have put in?
Old 03-21-2016, 12:14 PM   #55
Out of curiosity, is marine plywood fireproof?
I was familiar with fireproof plywoods but less with marine grade ones.
mrblah is offline   Reply With Quote
Old 03-21-2016, 02:28 PM   #56
Year: 1973
Coachwork: Gillig
Engine: 1160 V8 Diesel
Rated Cap: 79
Oh! I was going to share what my cost was for the 20g steel for my bus...I spent $275, which included the cutting.
"Using our freedom to help gain theirs."
Helping victims & survivors of human trafficking regain their lives.
www.oasisprojekt.org
FreedomPanda is offline   Reply With Quote
Old 03-21-2016, 03:34 PM   #57
sammy's Avatar
Coachwork: Gillig
Originally Posted by RyanM View Post
Getting this rubber flooring off the plywood is a pain, but it looks like I'll be able to reuse a lot of the wood. Only deterioration I've found was around the passenger side front wheel well. The rest seems solid!
What was the best technique for getting the rubber flooring off?
Old 03-21-2016, 04:49 PM   #58
Years ago I borrowed a neighbors shingle spade and it worked like a champ. As the name implies, they are made for removing roofing shingles but it was great at getting under the old rubber. Note...mine was not glued down that heavily.
Old 03-21-2016, 05:52 PM   #59
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Mine wasn't even glued down really at all. It was super easy to get out.
Old 03-21-2016, 09:42 PM   #60
Year: 1973
Coachwork: Gillig
Engine: DD 6V-71
I went to Lowe's and bought a floor scraper. It's a long handled tool with a sharp, replaceable blade on the end. It's time consuming, but productive. The rubber in Delores is stuck pretty good; makes me wish I knew what they'd used to make it stick in the first place!
RyanM is offline   Reply With Quote
