Old 02-27-2010, 01:13 PM   #71
Diesel Dan's Avatar
Engine: DT466/AT545
Re: Diesel Dan's Skoolie
Originally Posted by Redbear
Originally Posted by Diesel Dan
I'm glad to have a friend who is an electrical engineer!
Electrical engineering is a sickness. Given a choice between a soft seat and a beer, or the chance to put a meter on your wires to figure out what the guy who put it together was thinking, and the toolbox will come out every time!
As it turned out, he got to have his beer and his wiring puzzle too!
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 02-27-2010, 07:25 PM   #72
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Engine: Ford 370 Propane
Rated Cap: 48
It may sound crazy, but I reverse-engineered my bus's electrical system almost as soon as I got it. I opened up the panel and removed everything that would be unnecessary. No more blinky's, no more buzzers (thank goodness), fixed the electric portion of my brake system, etc. Now that all the wiring is cleaned up, and the switches are moved to a more ergonomic position, I don't mind working with the wiring. More than once I had to wonder what the hell the guys were thinking that wired up the bus!
Old 02-27-2010, 08:12 PM   #73
Year: 93
Chassis: ?
Im kinda dreading getting into that. I like wiring stuff up but i do not care for figuring out someone else's "good idea" even with a schematic.
swhite832 is offline   Reply With Quote
Old 02-27-2010, 08:22 PM   #74
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Rated Cap: 48
One of the things I thought was strange is that the tail lights, and lower marker lights come on with the headlight switch, but there is a separate switch on another part of the dash that turns on the marker lights at the top. Why wouldn't these all come on together with the headlight switch? I am not going to run some and not others...it just means I need to turn on two switches...if I don't forget. I may be rewiring this.
Old 02-28-2010, 06:53 AM   #75
Originally Posted by jkindt
It may sound crazy, but I reverse-engineered my bus's electrical system almost as soon as I got it. . . . . More than once I had to wonder what the hell the guys were thinking that wired up the bus!
That's one of the sanest thing's to do. Now you can maintain it. You don't want a mechanic doing the wondering for you at $$$ per hour.
One thing professional drivers do is to blink the markers off to say 'Thank You' if a vehicle being passed signals that it's clear to pull back into the driving lane. Although in the last couple of years, I've sometimes seen 4-way flashers briefly lighted instead.
I could picture running through a campground or on a forest road without the markers lighted, but it would be a rare occasion. YMMV
The other thing I could picture is trying to get off the highway at night after an alternator/belt failure, and dumping the markers to try and extend the battery power to the head and tail lights.
Old 03-01-2010, 09:20 PM   #76
Diesel Dan's Avatar
Engine: DT466/AT545
Flooring Progress
As mentioned previously, I'm finally making progress on the floor. Here is what it looked like after I caulked all the holes from the wheelchair plates and seats:
Here are my boys helping with the rosin paper and 1/4" insulation sheathing:
Gallery:
Conversion Thread:
Old 03-01-2010, 09:32 PM   #77
Diesel Dan's Avatar
Engine: DT466/AT545
First piece of plywood goes in:
We actually got a little sprinkling of snow here in Central Texas:
Which reminds me... when we were playing with the wiring, I fired up the bus for the first time in probably 3 months and it started up instantly and was just purring contentedly. Well, okay, I suppose diesels don't really purr. So it was clackety-clacking contentedly. Wonderful!
Gallery:
Conversion Thread:
Old 03-13-2010, 07:48 PM   #78
Diesel Dan's Avatar
Engine: DT466/AT545
Subfloor is in, windows are out
I finally got the subfloor done and bought some laminate/resilient flooring that I haven't put down yet. I also started screwing some furring strips on the walls and managed to remove the windows I will be skinning. The first window took a long time to get out, but then once I figured out the removal strategy the rest came out faster. I'm leaving the front 3 windows in on both sides, then removing 2 and another 1 where the kitchen and bunk area will be. I'm leaving one window in the middle of each bunk for ventilation and light (The bunks will straddle the wheel humps and will double as a passenger area), and I'm also leaving the farthest back window in where the toilet will be so as to vent any noxious fumes.
I scored some angle iron for free on craigslist. Some sort of shipping crate somebody was giving away. I plan to use it for several things, but first will be a support to attach the top of the window skins to.
I'll also use it to frame the edges of the entry stairs once I finish them out.
Next steps are to finish the furring strips around the walls, and get insulation put up on the walls. I also plan to get the windows skinned, hopefully next week, since I can't really finish the walls until those are in.
Gallery:
Conversion Thread:
Old 03-16-2010, 12:54 PM   #79
Diesel Dan's Avatar
Engine: DT466/AT545
Sheet metal purchased - sprayer question
Picked up my custom cut sheetmetal pieces for the window skins this morning from the sheet metal shop. Great thing about living in/near a major city is access to most anything you need to buy. It cost me $135 to get skins for 6 windows. I'm taking the day off from work on Thursday and hope to get them installed. Meantime, I need to get them primed. Of course since I removed my windows it's been raining the past two days. It's supposed to dry out tomorrow, so everything should be good and dry for Thursday. I'm going to go to Harbor Freight tonight and pick up this sprayer:
http://www.harborfreight.com/cpi/ctaf/d ... mber=93305
What's weird to me is that although this one is listed as "HVLP" the other one just like it, with the same specs is not listed as "HVLP":
http://www.harborfreight.com/cpi/ctaf/d ... mber=93312
Gallery:
Conversion Thread:
Old 03-16-2010, 03:10 PM   #80
browncrown's Avatar
Rated Cap: 79 at Birth
Progress looks great DD...you'll have those windows covered in no time.
BC
1986 Ford Diesel skoolie runs great Das Mel Classifieds | Buy, Sell, Swap 3 05-10-2013 10:01 PM
New Skoolie Conversion and Old Skoolie Remodel jlhollowx13 Skoolie Conversion Projects 0 01-22-2013 01:41 PM
1986 Diesel skoolie 90% converted chev49 Classifieds | Buy, Sell, Swap 3 07-24-2012 07:14 PM
Mountain driving w diesel skoolie? Seeria On the Road | Travel, Trips, Camp Sites, Tailgates 6 07-16-2011 08:07 PM
4x4 Short Ford diesel skoolie (another find by easy rider) easy rider Classifieds | Buy, Sell, Swap 1 01-16-2011 11:02 PM
